hansvonlieven
Quote from: Cherryman on May 19, 2009, 05:32:55 PM
Or the driving mechanism of this attached :
No, this works only on the forward stroke, you need it to work in both directions.
Hans von Lieven
Cherryman
Quote from: Nabo00o on May 19, 2009, 05:25:44 PM
True, but you could use a double ratchet system like Tommy Lee Reed did, it converted 100% of the linear force directly into torque, practically without loss.
Combined with this setup the pendulum would be very efficient at driving a wheel.
Sounds good, do you have a picture?
hansvonlieven
Cherryman
Quote from: hansvonlieven on May 19, 2009, 05:35:07 PM
Hans von Lieven
That would double the output, indeed.
It's the flywheel system i like, it will gain speed as you squuezes..  and every re-squeeze whill add speed.. ( hope i make sence)
I have no idear how that works, anyone any info?
Nabo00o
No, it wouldn't double the output but make it near 100 % efficient.
Too bad all of Tommy's videos where removed, I learned a lot from watching those.
Right now he is trying to get a patent on the ratched engine and a rotating piston design.
If the ratched engine was able to reach the market it would completely revolutionize the car industry, and every other industry as well which uses gas driven motors.
The fact that this design is so efficient would allow all cars to run on air, and get very far.
In my view batteries can't compete with air cylinders at all. Gas tanks can be refueled in seconds, and will take very long to wear out. In addition there isn't much pollution generated when trashing one.
Static energy...
Dynamic energy...
Two forms of the same.
