Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
gotoluc
Quote from: pmgr on June 10, 2018, 02:40:53 PM
In these videos, none of his coils are isolated.
PmgR
Question, if you opened (switched) one location around the 36 or 30 series coils would that give a result of coil Isolation?
See bottom switch in my drawing.
Luc
konehead
hi everyone
this is drawing just did showing my bifilar idea how to pulse the stator winds...
I did not do the windings between the energized winds shown but you get the idea how those will all hook up with reds to reds and blues to blues..... however it will be is how they will hook for best "mdoced pickup" output maybe combo of series and parallel
pmgr
Quote from: gotoluc on June 10, 2018, 03:49:56 PM
Luc
No, that doesn't work as you need to rotate the field, so the switch needs to rotate/move as well every time you rotate/move a coil. So it would require a switch like that for every single coil.
PmgR
jerdee
En:
Pierre,
Do we need to think of the three Norths and three Souths as ONLY 3X the FIELD STRENGTH?
I've been thinking about how to create TWO POLE system with rotation of thee times the FIELD STRENGTH.   I'm beginning to understand the importance of creating variation and intensity of the rotational field with extra wires on the stator.   36 to 12 wide for you, while 30 to 10 wide for us.  Did you solve by creating a TWO pole system with 3 times the field strength?
Very thankful for your help.
Jerdee
Fr.  Pierre,
Avons-nous besoin de penser aux trois Nord et aux trois Sud comme SEULEMENT 3X LA FORCE DU CHAMP?
J'ai réfléchi à la façon de créer un système à DEUX PÔLES avec la rotation de thee fois le FIELD STRENGTH. Je commence à comprendre l'importance de créer la variation et l'intensité du champ de rotation avec des fils supplémentaires sur le stator. 36 à 12 de large pour vous, alors que 30 à 10 de large pour nous. Avez-vous résolu en créant un système à deux pôles à partir de 3 fois l'intensité du champ?
Très reconnaissant pour votre aide.
Jerdee
pedro1
Vous pouvez faire seulement un nord et un sud a 10 de large  votre champ seras augmenter et oui la variation du champ a une importance
En.  You can have only one north and one south of 10 wide, your field will increase and yes the variation of the field is of importance
