Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
Jeg
Quote from: pmgr on May 16, 2021, 02:09:40 AM
There is no way that the output rotor coil can have any (steady) A/C voltage if the relay pattern is not moving yet
In addition, there is a cable connected between the last two supercapacitors in the raw of his cap bank. It gives me the impression that current from the source of his mosfets goes there and charge the last capacitor instead of wasting it to the ground of the system. But this is just an assumption of what this cable is doing there! Only Pierre knows for sure.
Hi guys :)
ramset
Well
As of this writing
It seems there have been technical issues that
Hindered replications .
And I must add
Incredible efforts were involved
Years long !!
However, there still might be help offered by Pierre at some point if he can find the issue ?
I do not ask anyone about specifics
Just generic ...how's it going ....?
Respectfully
Chet K
Thanks Grandma
listener192
It's a hoax. Logically it cannot work for all the reasons I provided previously.
Pierres new build tries to keep the flux in the stator except when in registration with the rotor. This was the fundamental flaw of the original design, a lot of energised coils with low inductance and no flux coupling. The only result I achieved was with a static set of coils and a switching pattern that varied the current through those coils.. about 40% coupling. In the end I used bidirectional MOSFET switches to simulate the relays. A transformer supplied half wave supply was used to vary coil current as another method.
In a real generator the DC energised rotor is producing induction in the stator coils through 360 degrees. How can simulating the moving field in the stator hope to have any efficiency when only a small number of degrees of rotation will couple the stator to  the rotor. I use the word simulating rather than emulating as you cannot emulate a field moving through space with stepping discrete coils.
I don't believe that lenz aw can be circumvented, so on that premise .. where is the additional energy source with this device?
L192
JaydenHE
Has anyone had any success with this?
Can we have a telegram group where inventors and engineers come together to crack the cheapest most effective way of free energy and start fixing this planet and fucking over energy companies as soon as possible please?
Thanks
Jayden <3
sergenet
Quote from: JaydenHE on September 24, 2021, 11:10:50 AM
Thanks
Jayden <3
that would really be great
