Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
Thaelin
And what does this have to do with pierre? I call spam hit and a noob too.
fer123
Hello, has anybody news about Pierre and the DZ generator?, any way to contact him, mail phone etc? Will be wonderful he come back and continue showing his marvel generator and teach us how to reach there. PIERRE I HAD REMOVE ALL YOUR VIDEOS FROM MY YOUTUBE CHANNEL LIKE YOU ASK ME, SORRY FOR NOT ASK YOUR PERMITION, HOPE YOU DOING WELL, WE MISS YOU. MERCI A TOI POUR NOUS ENCOURAGE AVEC LES DZ GENERATOR. :) :) :)
alan
DZ gen looks real, but we can't know, if it's a fake then the center coil has a heavy battery. How does he get a 60Hz sine from a 1-2Hz rotation?
The primary coils get hot when the output is loaded, so Lenz is still there being fed-back, this may be caused by the technique to cancel the Lenz feedback by a high pressure zero vector sum between 2 partnered or paired bucking coils, or another redirection, Lenz is strong and so back EMF is high because output power is high, just speculating.
Ufopolitics
Quote from: alan on June 01, 2022, 07:55:57 AM
Hello Alan,
Simple...Pierre has 6 Poles on his rotary field...that cuts the frequency in like 1/6th...like in a 4 pole exciter generator it only requires 1500 RPM's to make 50Hz...or 1800 (1/2 of 2 poles @3600RPM's) to go 60Hz
Quote from: alan on June 01, 2022, 07:55:57 AMThe primary coils get hot when the output is loaded, so Lenz is still there being fed-back, this may be caused by the technique to cancel the Lenz feedback by a high pressure zero vector sum between 2 partnered or paired bucking coils, or another redirection, Lenz is strong and so back EMF is high because output power is high, just speculating.
Of course Lenz would always be there...but Lenz can not act over a massless field displacement...Lenz acts only over steel mass cores. The most it would do is to increase the Input currents, but much less tan whenever trying to stop a physically rotating mass of steel and copper coils...just "nickel and dimes"...or like 0.20 to 0.50 amps.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
alan
Quote from: shylo on October 31, 2018, 07:14:27 PM
Mechanical switching can get very complicated ,I've tried
Electronic is the way to go if you have the knowledge, which sadly I don't.
Using the reverse fields is part of the solution I believe
Like you say I don't golf, fish, hunt, take trips, I enjoy tinkering to each his own.
Thanks for sharing and good luck
artv
Timing can be calculated like this:
f = 2hz or field rotations per sec
n = 36 coils
T = 1/2 = 0,5 sec per rotation
T per coil = T/n = 13,89 ms
