Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
gotoluc
T-1000
Quote from: gotoluc on April 12, 2018, 04:46:26 PM
First output coil test
Video demo:  https://youtu.be/9ybgmyOsFdM
Nice test Luc :)
In regards to polarities on output core you probably will want some rotating magnetic field detection probes installed. That might be multiple hall sensors inside of diamagnetic material pointing to different directions for seeing 360 degrees rotation or similar setup.
Cheers!
gotoluc
Thanks DreamThinkBuild
The below video is the last for today and the results of reducing the center I core to contact with 4 I stator surfaces. It's a small improvement but not as good as I was hoping for.
Fr.  La vidéo ci-dessous est la dernière pour aujourd'hui et les résultats de la réduction du noyau centre I à contacter avec 4 surfaces de I dustator. C'est une petite amélioration mais pas aussi bonne que j'espérais.
Video demo:  https://youtu.be/EIdsx61qGec
seaad
Luc
I saw on the scope that the peak voltage across your primary coils?? was some volts below your feeding voltage so some power loss is hiding somewere.
In my over unity contraptions I have to use a higher reisistance value to the  resistive load, than  the resistance giving maximum power, to come above the ingoing power. And a short  circut (or open) output barely affected the input parameters.
Regards Arne
gotoluc
Quote from: seaad on April 12, 2018, 07:48:57 PM
Luc
Regards Arne
Those voltage readings are 2 of the Arduino outputs triggers to the H=Bridges. They are there for reference.
Luc
