Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
jerdee
Look very carefully at the code differences between PMGR and Pierre's code posted from
http://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued -moderated / msg518835 / # msg518835
There is an OFFSET !!!!!
THERE IS A FULL ON / OFF POSITION AT THE BEGINNING / END of Pierre's Code! This would allow a very strong SINGLE coil magnetic field to be placed with no overlap!
The offset allows for the inductive kickback to be pulled around for a full cycle before released!
alex77
Hello, I am following this thread from the beginning. I was very impressed by Pierre generator. Very professional thread, all which are involved here have a lot of experience in these issues.
All my respect to Luc, his prototype is very impressive and expensive.
I am not an expert, not even a professional, I am more like an amator.
I want share with my point of view, because I know that if you focus too much to one idea, you miss other solutions.
From my point of amator view, there no 30/36 coils energized all time, as you Luc mentioned in the last video. I believe that only the coils which are energized are exactly the coils where the LEDs are on. When led is off, the coils not energized anymore, allowing bemf to go to caps. If all coils are energized, how bemf can take place?
I believe like this: all the time is on three coils from stator and Pierre made the "rotor" with a certain number of turns like in a normal transformer. So all the time only 3 coils are inducing the current to the rotor.
Again, I am just an amator, please ignore if this is wrong.
Cheers!
Alex
konehead
Hi Luc
Three suggestions:
Put in some proper backemf/recoil collecting steering diodes!!!!!
Pierre said plain as day this is the secret.
Do not rely on the internal diodes within the H switches to do anything at all....they certainly will not be filling up any capacitors!!!
Squeeze in a big vise the stator assembly so that it actually squeezes the stator onto the rotor and there is very good contact between the rotor and stator and near no airgap.
You can see how Pierre has hard time installing his rotor and it is very tight squeeze plus looks like good contact between rotor and stator surfaces. and no airgap.
Use the same wire and same length of wire as Pierre uses in his rotor - parallel bifilar 20 GA and I think it was 900 feet in each bifilar half??? that rubeer coated wire I saw you use will be very lousy stuff to use my opinion
Anyways keep going don't stop!! Stay positive don't give up until it loops. (then work on it even more)
ARTMOSART
Quote from: ARTMOSART on April 14, 2018, 05:03:51 PM
luc ,
j'ai visionné ta vidéo je remarque que seul 6 led sont actif ,si je comprend bien le schéma de pmgR ,il faudrait 12 contacte actif
par pas ,on dirais que dans ton cas présent 3x10 bobine sont actif au lieu de 6x5 bobine ?
Mosha
I saw your video I noticed that only 6 led are active, if I understand the diagram of pmgR, it would take 12 active contact by step, we would say that in this case 3x10 coil are active instead of 6x5 coil?
hi,all
désolé  ,j'ai mal interpreté l'action que représente  une LED actif ,merci à L192  d'avoir clarifier les chose .et pardon pour cette
confusion .
cordialement ,Mosha
sorry, I misinterpreted the action of an active LED, thanks to L192 for clarifying the things .and sorry for this confusion .
