Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
d3x0r
Can someone(everyone?) share some specs about their coils?  What is the resistance of a drive coil?  how long is it? how many turns? what is the measured inductance (without the pickup core)?  what gauge wire?
how many strands can fit in one of those slots?  (Yes, more for higher gauge) so...
seaad
You can find it here:  gotoluc,   listener192,  r2fpl, ariovaldo and my posts.
Re: 170 watts in - 1600 watts out - looped - Very impressive build and video
« Reply #402 on: March 21, 2018, 10:55:04 PM »
« Reply #403 on: March 22, 2018, 12:32:11 AM »
Or here:
Re: Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
d3x0r
Quote from: seaad on April 23, 2018, 07:18:28 PM
Or here:
??? (where?)
Thanks.  You can right click on the link-title just above the 'reply#' and copy the link.
[ url=<paste>]short text [ /url]  (without the leading space)
Edit:
according to...
http://hyperphysics.phy-astr.gsu.edu/hbase/Tables/wirega.html
500 feet of gauge 10 wire would be 0.5Ohm.
Is that 0.526K Ohm?  Hmm no; because you'd need 20,000 feet of 24ga wire...
cheors
Quote from: seaad on April 23, 2018, 01:54:03 PM
cheors On your CurrentVariation pic : I'm Not convinced that Pierres diodes goes to both plus an minus ? See an earlier post of mine. Reply #477 on: April 16, 2018, Page 32,
Regards  Arne
Yes, impossible because the diodes are wired the same direction, anode with anode. I did not pay attention !
Were to connect the 2 cathodes ?
Not at the same point. They would be in parallel and the only justification would be a problem of power.
But it would be better then to choose more powerful diodes or to add heatsinks.
The only possibility is to find 2 different positives points.
Like this: what do you think?
listener192
Quote from: seaad on April 23, 2018, 07:15:52 AM
Jeg, " at 120Hz  can be used for sync" .  Agree. This is an odd connection with thin wire. Just a signal current?    About the freq. just leave that  :D :D
Has it to do with the current consumption to his big transformer during charge and under operation?
My pics showing Volt and Amp with the Microwave Oven   OFF  and   ON.
Does anybody know "APME" the label on the Micro Oven?  A company??
Thats just an inventory label. Its a GE MO.
This is the model.
http://www.geappliances.ca/en/products/cooking/microwaves/applproducts/JES1138SNC#tab-Details
@41lbs This has a 60Hz line transformer.
The power 1500W @13A.
L192
