Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
konehead
Hi all
Here is attachments is what Gary Porter (Skipperbythesea) has built so far.
He ordered a big PCB board to mount mosfets and arduino stuff too (cost 500USD)
He is serious builder, fully understands the power you get from the backemf/recoil as well, and knows how to harness and store it.
His stationary-rotor is going to be square shaped, made from a HV transformer core he as got already....
Note his bifilar coils in his stators - idea is to flip polarity very simple, pulse one bifilar half one way, other half the other way. Now also un-used half gets some tight induced power into them as well.
d3x0r
I thought i would do a search 'magnetic flux rope'
to get an idea of what the world might think what I'm saying means...
https://physics.stackexchange.com/questions/182659/what-is-a-magnetic-flux-rope-and-how-does-it-differ-from-magnetic-flux-tubes
More rope-like images   Seem  only be able to capture them from the side, while top-down on a sun-spot just shows blackness...  And only when charged with plasma.
my attempt to get more knowledge about knowledge of magnetic flux ropes (they are no help; probably should find a better thread to interject on)
Separate poles are not going to work very well...
r2fpl I don't know how hard it is for you to reconfigure...
But if you started with the simplest case... north on one side and south on the entirely opposite side.  (A total of 2 or 4 coils energized), and swept them through 180 degrees... and position the pickup at the 90 degree mark should get something resembling tension on the pickup?
marathonman
d3x0r;
I see you are a troll and a shill. why do you insist on interrupting threads with your total bull that has nothing to do with the thread. people like you should be barred for life and your IP address blocked.
you should be a shamed of your self for having no class, decency or respect for others.
respect these peoples thread and drop your BS or better yet GO AWAY !. you will be reported as a troll and a shill.
Marathonman
d3x0r
Quote from: marathonman on May 01, 2018, 06:11:02 PM
d3x0r;
I see you are a troll and a shill. why do you insist on interupting threads with your  and bull that has nothing to do with the thread. people like you should be barred for life and your IP address blocked.
Marathonman
Says fake news...
I hesitated to respond, on topic, in the topic related to the post that was also duplicated by saad.  I knew I would draw your eye with disagreement; so I said, respectfully, I disagree.  And dropped it.
This, however, is on topic here, and relavent to the MO.
But; as always, can lead a cat to food but can't make them eat.
T-1000
Quote from: r2fpl on May 01, 2018, 02:31:07 PM
This is the modified version as a curiosity. Normally it is just like Pierre, and nothing happens after the move. The field is spinning but there is no tension on LOAD.
Possibly the ending of previous coil are too tight with beginning of new coil on each pin? If that is a case it is getting cancellation. It have to be at least few centimeters distance between coils. And it is main reason why I am still looking for hard-to-get stator which would allow fill space with core between those ends.
As in the movie: https://youtu.be/0IKX8MeVQio (= original programm Pierre 1on-2on-1off ...)
Probably the coils must be cw-ccw-cw-ccw .... or else.
In that video each pin around a ring have individual formed magnet with opposite to the next pin I guess?
Also all coils need to be in same direction. But the current flow need to be opposite on every 6 coils from 36 around stator.
P.S> We need to generate moving field to be same as we would turn rotor with 3 phase magnets inside of stator. Not just rotating magnetic field around coil axis.
