Thanks to ALL for your help!!
Rene/Meissner EMF Higher Voltage Charger Variant
Started by SkyWatcher123, April 08, 2018, 11:52:40 AM
SkyWatcher123
Ok, after a couple charge/discharge cycles with the 37 volt input, the efficiency is almost 100%, if we just calculate what is flowing through the actual circuit, compared to the watt hours given back by the battery.
However, the total efficiency is close to the efficiency between the total input watts, relative to the actual watts flowing through the circuit, which is around 65% range.
I will make further tests with higher voltage, to see if i can get the battery to charge efficiently that way.
I should make you folks aware, the battery i'm using for these tests is actually not in the greatest condition, it is the one from our lawn tractor, so i will have to make these tests again on my good condition battery also.
SkyWatcher123
Hi all, just want people to know, battery charging/load test efficiency results are looking much better with the good battery.
Will run a couple more cycles tomorrow and share the data, then i will try higher voltage inputs as well.
Getting tired now.
peace love light
seychelles
HI MY 2 BOBS WORTH . THE BIGGEST PROBLEM YOU ARE FACING IS,
THE BATTERY.. I RECKON YOU SHOULD USE APPROPRIATE CAPACITORS REPLACING THE BATTERIES..
SkyWatcher123
Hi seychelles, thanks for the reply.
Yes, am aware of the battery charging efficiency, probably why Bedini, Turion, etc. use a bunch in parallel, to lower those losses.
And Bedini used those giant telephone tower batteries i think, that had ultra low resistance, closer to the ultra capacitors battery capacitors you are suggesting.
peace love light
