Calculated COP=10 Active Antenna System
Started by panyuming, April 26, 2018, 06:32:36 PM
panyuming
Quote from: Sergh on April 30, 2018, 04:43:03 AM
Yes of course:
https://en.wikipedia.org/wiki/Active_antenna
hank you for your reply
Now I know that maybe I used the wrong word. Should use "Initiative Antenna"
The antenna system mentioned in the field of free energy is to say that many radios around the transmitting antenna of a radio can 'passively' receive the energy emitted by the radio. But every radio receives very little energy.
panyuming
Even with directional antennas, the energy received at the receiving end is much smaller.
panyuming
If every radiation of S is achieved by a certain current of a device, it is equivalent to this S-radiation-generating current charging capacitor C. This current is obviously not affected by the voltage on capacitor C.
According to the capacitor energy storage formula W=0.5CU^2
The voltage on C can increase without limit, and the energy in the capacitor is stored according to the square of the voltage, there is always a 'critical voltage'. Above the threshold voltage, the sum of the energy in the capacitor exceeds the sum of the current energy charged to it. Extra energy appears.
To repeat: Charging the capacitor directly with the power supply is energy conservation. With radiation, the energy can be increased.
To put it another way, we don't care where the waves from the antenna go. When the waves are sent out, there will be antenna currents. There is also a ground current. When the ground current is rectified, the DC voltage is obtained.
Instead of using an antenna to receive energy, we use an antenna to emit energy,
which means ' Initiative antenna'.
Collapsingfield
Don't forget that the diode will kill the effect. Before opening it is a small serial capacitor with an inverse voltage eq to collector cap and after every step it will be harder to open it and the impedance will be high till the opening.
