0 Members and 57 Guests are viewing this topic.
stivep
PART 3.
Quote from: r2fpl on February 17, 2019, 08:10:36 AMResonance alone is not enough to sustain the process. This is just a required element. The source must come from passing through another medium.
If we consider that we want to start with Schumann resonance, for example 26.4Hz for the first resonator and for the coil 1/4 = 105.6Hz, and this frequency is considered our second resonator we already have 422,4 Hz on the second coil. Assuming that we can do this many times, we get many repetitions.
The few ways :
One is to calculate all variables starting from four fundamental Maxwell  equations, with surface wave in mind.
calculate each section place two of them together, and check against the sample.
However  parameters of  polarization, phase and frequency can be known to us if we transmit from A to B. at first, and than use
our experience to move lower in frequency. So playing   at first with  Tx/Rx  pair is your mandatory experience  before you move to Schumann  waveguide surface wave components.
The same antenna of our Tx  or Rx (pair)  = our receiving antenna for our surface wave in Schumann  Waveguide.
Wesley
link to picture below:
https://patents.google.com/patent/US4751515A/en
r2fpl
Simple answer: this is the principle Kapanadze devices !
The standing wave is a reflection from the ground with the help of TT. This is the main rule! Spark gap is just an interlude for the TT inductor as in Tesla.
You can search for reflection by measuring V-SWR for antennas.
..middle picture is GIF animation. Please download to desktop if not run.
stivep
PART4
Yes  the mechanism you explained is one of mechanisms, behind Kapanadze/clones.
Other mechanisms:
1. Think about  vertically polarized standing wave.
It is bouncing  back and  forth in Cartesian XYZ space
(You can also imagine Euclidean geometrical  space)
At certain point, after  e.g 55 bounces velocity of envelope ( rybka)( the fishes) https://youtu.be/7pE83oajjoo?t=517 upper right corner
can be  50 times slower than free space speed.
Let's call it group  velocity.
And now you are able to take this signal and without losses feed it into
another (resonating at 1/100 of  lambda   CCW) , part of the coil.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/171961/
But this part of the coil  has its own Slow Wave factor caused by thick dielectric
of HV wire.
Now this section is coupled to resonance by pricking  insulation  of that  wire in right  position of
waveform,  traveling in that  covered with dielectric wire.
https://youtu.be/KLAPRNWuAn4?t=600  ( watch for another minute)
And yet  the two sections:
- the one before and one now,  are in perfect resonance  in its
fraction of  lambda.
However both together now work much better  at 1000th of  a lambda.
For better understanding let's take an example:
You have  two or more  1/4 lambda antennas,
It is not important if any of antennas is 20 cubic yards big or it is at the  size  of your  cigarette lighter.
Both of the antennas  must  RESONATE at first!!!!
Both of the antennas will do excellent job.
However efficiency of each one of the  antennas is a trade.
link to antenna should be  only for reference of (How to phase)
https://www.hamradio.me/antennas/improving-the-super-j.html
link to  coils in motors
http://www.davidsonsales.com/docs_pdf/CoilPitch.pdf
For these
we look at how slow is phase  velocity  for total distance from A to B. ( when you looking at  envelope)
The ultimate goal is to  actively match with our Kapanadze   clone coil exactly to the condition of surface wave at this particular point of interface ( air/ earth)
If we use active antenna instead of passive antenna than  our active signal can be  compared  with that very particular point  having geometrical  XYZ  on that interface.
This signal can be than  discriminated/ compared/ mixed/ demodulated  for our benefit.
And that is your Free Energy
Schumann waveguide has fixed XYZ diameters  and like every  waveguide its wall ( the interface can accept immersed probe like in the slotted line)
Slotted Line: https://www.daenotes.com/electronics/communication-system/slotted-line
Wesley
stivep
PART 4a
explanation:
man made surface wave is exactly the same as
nature made surface wave
but has different  polarization, phase angle , frequency
It has also different impedance than loved by us standard 50 Ohm.
Summary:
Surface Wave  known also  as Zenneck Wave is our focus media despite  the fact if we  plan to  transmit from A to B
or we trying  to extract energy .
We will be always looking at  interface and right match to  man made or nature made surface wave.
You do not care  about efficiency of any of sub-sections of Kapanadze/clone HV coil.
Efficiency is only important, when  you deal  with bits and pieces of energy to be preserved.
Our general assumption is that in the interface we have plenty enough energy in surface wave to deal with.
But at first  we must tune into it.
By method used by Corum brothers  it will be  big humongous   Tesla Tower. Even at 18kHz
By method used by Tariel Kapanadze  it will be  very unstable but small Kapanadze active coil assembly.
Both of methods must have proper ground.
Wesley
Ansis
I agree about Q factor and no-Radio type Kapanadze device.
Only created in place HiVoltage can make something usefull (if it is real) with Ground connected
device which "suck electrons" or create something unknown or make something like mC2 punch=> contra punch. Something like Second + Third Newton's law of motion. Only difference is we do that with Electric "hammers". We create Force in colision between mases and create contercforce on it.  Like when we magnetise and demagnetise material which than is captured with Coils.
I see only thease explanations.
