d3x0r
Re: 3. Vortex Tubes
These aren't either Shauberger or Dyson Air Mulitplier....
while interesting, Viktor Schauberger had literally curled tubes... which for certain capacitiies of fluid velocities reduce flow rates... but they require tuning to operate in a certain range...
d3x0r
(although as I was considering it; certainly Vortex Tubes shouldn't be ignored)
So... they say dolphins and other fish will make vortex rings to eat... It didn't really click how that would work until I saw this
https://www.youtube.com/watch?v=AqATMuyAhPo 'How To Build A Fire With A Plunger' is a terrible name for the video.
8:27 Intro to clip of fish doing so
11:31 goldfish crackers get caugnt, and swept along ring
Which... I'd suppose if there was small things like plankton they would get caught up also, and (perhaps) the vortex is slurped up like a straw full of micro food stuff
Vortex Rings... I saw a coanda quad copter today also; wasn't very good... I think there's something missing, either fins to divert the airflow circularly, or a lip, or ripple to cause rings to happen... but then I guess rings are self-stable and don't influence the outer flows very much
Vortex rings ~ Ampere-turns circum-venting/swirling the coil ( out-side / in-side) :
                                               peripetal and/or centrifugal movement
                                    Up to 990 KW output/ ? weight
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP#
                                    Up to 1 MW/ 27,2 Kg ( 60  lbs )
https://www.google.com/url?q=http://www.wonksmedia.com/dec.pdf&sa=U&ved=2ahUKEwiE7q_35MnkAhUpA2MBHWH2BGkQFjACegQIBxAB&usg=AOvVaw1bVcXEBtDsFIpTC0QlPVz2
                   per KW installation : 10 Euros/KW private endconsumer/industrial consumer price  ?
                       1 MW x 10 Euros = 10000 Euros / device weight : 27,2 Kg =  367 Euros/Kg
Imris generator production costs calculation( permalloy, copper, capacitor,...)  32 Euros/ Kg (2012 list prices)
By material value 10 Euros/KW( included well margin )  generator will become real  and an alternative to
                                            1500 Euros/KW solar/Wind/Biogas "farming".
For me only known higher power-to-weight ratio devices :
                                   https://patents.google.com/patent/US8847720B2/en
And
                   https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=45&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A#
https://www.google.com/url?q=https://www.sciencealert.com/world-s-oldest-nobel-prize-winner-says-his-new-device-will-give-clean-cheap-energy&sa=U&ved=2ahUKEwif2Ye47cnkAhWlx4UKHbgWBRAQFjAAegQIBBAB&usg=AOvVaw3MFcU2G_SFVRKzLOQLzNeo
or instead
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870527&CC=DE&NR=3540683A1&KC=A1#
                                   10@7 W per sqm=  10 MW/sqm = 1 KW/sq-cm conversion possibility
                  https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A#
To compare the Zielinski/Sines generator fair :
the Harold Goldbaum with Zielinski apparent power-to-weight ratio :
Zielinski ( 4500 Ampere x 220 Volt/50 Hz) / weight
Sines 1 MW : ? Hz/27,2 Kg
Goldbaum : if with 400 Hz 60 KW per hour then with 50 Hz = 7,5 KW per hour dividing  with weight 705 ccm x 7,5 g
= 7,5 KW/5,3 Kg power-to weight ratio
Resume :
Goldbaum generator by weight and same output frequency more than 25x times heavier than Sines/ Zielinski generator
Technology for superconductive devices becomes cheaper :
https://patentauction.com/patent.php?nb=13984 by Anatoly Rokhvarger and Lubov Chigirinsky and M.Topchiashvili ( 2000,2004)
91° Kelvin :  ::) hmm,  mit der Schukeyschen Delta-Omega Maschine, kaskadiert : =  - 180 ° Celsius
Kelvin Zeropoint to Celsius Zeropoint  ?
https://pt.m.wikipedia.org/wiki/Motor_Schukey
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.thermodyna.com%2Fjuergen-schukey.html
Ed Sines US Navy work :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
Based by their priority dates : Schukey, Sines/US Navy and the HTS coil : global open source ( excl. US 2004 application https://patents.google.com/patent/US7632784 )
civil and military carrier technology for land,sea and air
High power electric beam tool/weapon :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=68&ND=3&adjacent=true&locale=en_EP&FT=D&date=19891018&CC=DD&NR=272727A1&KC=A1#
High energy focus-point delivery : Mega- up to Gigawatt
Un-/friendly application possibility :
Fast cutting house walls, granit cavity engraver( for new water delivering channel f.e.),closed Tresor opener,
military tanks and jets internal heat increaser ( soldiers" cross" like fried chicken) ,
bridges/dams and tunnels e-cutter ,
nuclear solid/liquid waste incineration,minerals smelter et cetera pipapo
Ready for the future eWar without frontier  !  This, WE ARE : from cold war era to eWargames competition  !
Telemetrical : by joy-stick  ;D for Collateralwins
stivep
summary:
The  real  power used by  Tx  was  quite small and insufficient to
provide coast to coast communication.
However total power used to power Tx  was huge.
Spark gap created    spectrum  of   frequencies having  one dominating center  of  the lob
where  the amplitude was  at  its  highest.
So when receiver or transmitter  shifted from  desired  target frequency  than adjacent frequency was immediately available to be used due to existing wide  spark gap spectrum.
The  bandwidth   of  Rx and Tx circuitry was  so wide, so Rx  and Tx  was always  tuned for communication.
look here :
https://youtu.be/XOTLfnMOSqQ?t=939
By comparison Tariel Kapanadze used  at  his first devices Tesla Coil and spark gap.
So  the spectrum of frequencies created exactly the same lob  with ready to  use   frequencies.
but now     our Tx  is made by nature.
There   are many  different  ways of activation:
https://youtu.be/XOTLfnMOSqQ?t=990
Due to Tesla coil characteristic  when you  have Top Capacitor on the  top of Tesla coil  RF signal is only present in near  field and than is vanishing.
by rules of Brewster Angle
https://en.wikipedia.org/wiki/Brewster%27s_angle
So we may think that Marconi used big masts and aerial  antennas in Tx .
however in Rx he used   balloon  with straight piece of wire.
And  that receiver is our key point
The receiver could only receive surface  wave  as it was sensitive only to that what could exist in near field of Rx
the receiver and transmitter must be alike  but acts  in reverse.
Tx  is transmitting  to   primary  coil and induces   voltage in HV secondary winding.
Rx is receiving signal  using HV coil and   is   inducing it into Low voltage  coil.
Note:
Quoteboth  the receiver and transmitter must be alike  but acts  in reverse.
that means  Rx and Tx don't have to look  alike but  they must act electrically  as if they were  the  same.
Wesley
