stivep
stivep
Dear magnetstoo thank you for your  experiment
I need some more time to understand    it.
For past few months I'm in and out,  not even having  time for   my videos
Wesley
kolbacict
Was there anything other than radiation in the experiment with the Coleman tube? Electricity from the output. ?
magnetstoo
   Mr. Wesley..I can only imagine how busy you are from all your videos....I have since increased the output by 50% and perhaps achieved nearly 66% efficiency compared to a direct 120v outlet connection.I have eliminated the 50 turn and the inner copper liner, I have also eliminated the 5th coil and now using a previously unused thread of one of the antennae coils...Im now running only the 15 turn inner winding for input....It is a delicate balance but I have a ( what appears to be ) 33% lighting of a 20watt, .16a , 120v, 66.5 ohm  Xenon bulb with only 43.5 volts @ .2 amp @ 90 kHz...This would equate to approx. 130 volt @ .07amp for this 120 volt .16a bulb running at about 33%..I can turn my AM radio on also  and NOT get the static background but a nearly clean AM broadcast because the system is "locked in" as it were.. The spectrum analysis shows multiple peaks up to 3+ MHz at the output of the Ferrite ...My OPA541 amp is only good to 40 volts.I have not received the big one yet.I have some minor heat loss in the amp ( do not need a fan now) and the 15 turn winding. I am also using a 2.4 volt (square, sine,triangle...does not matter much  )input @ ~ 180 kHz from my "Wavetek" signal generator into one of the unused coils for a back resonance.There certainly is not  much current in these coils as they are 38 and 40 gauge wire @ about 11mH. Input voltage to the OPA541 from the antennae appears to be .1v..or perhaps 1v when measured with an analog meter.....Frequency should be 90kHz. Input frequency = output frequency...
    I am hoping to add and receive some insight into how to increase the magnetic field output..I am applying some of Don Smiths ideas also.If any one else
has some ideas and a near working model,Id like to hear of what else I can do, short of winding a grenade coil which I may end up doing, as it looks as if I have reached the end of efficiency with this present set-up..because I have tried to update what I can..I will post to Y-Tube when I get organized...All in all it all appears to be ( must be ) a smooth transition between input and output As Don Smith said  "They must talk to each other"...My output amp is running far far cooler than it did, to light the same bulb at the same brightness.
sm0ky2
If you wind the secondary coil in the opposite (left hand) direction
The magnetic field induced will oppose the primary
(current will run in the same direction in both coils)
This will amplify the magnetic field in the core (ferrite/air/etc.)
[note: this only works with connected core transformers.
          Toroids, square/rectangle loops, connected plates,
           "U" transformers, etc.
           Where the magnetic field loops back on itself.]
            {air cores are 3-dimensional spacial fields
              independent from the physical coil}
