0 Members and 162 Guests are viewing this topic.
PolaczekCebulaczek
Quotehttps://www.youtube.com/watch?v=7pE83oajjoo&feature=youtu.be
This is first video
Thx Wesley
Soo its time to dust off my granade coils and kachers? because I gave up on this and lost all hope.
PolaczekCebulaczek
Sergey Panov channel: https://www.youtube.com/watch?v=uUVybUtIdAo
Don't watch it unless you want to see spoilers in russian, next episode of wesley's news is coming soon!
aether22 Thanks for pictures, now i can see things better.
In case of Hendershot, I dont see any aether stuff, just a tricky yet consistent with electromagnetic theory method of extracting/converting energy from "slowly rotating big ball" and its weak magnetic field to "fast rotating small ball" with strong magnetic field, something like a transformer or a two small-big gear system analogy. It could work because of two factors; the fact that electromagnetism is relativistic and difference between true-geographic north and magnetic north (because of this earth mag field is rotating with earth, in faraday disk its not). Device needs tuning, very specific angles of magnetic field's are needed to make this work ( hendershot compass) and finally when earth mag field answers, the answer is in form of HF vibrating earth magnetic field, for that honeycomb coil is the best, its HF coil that can pick up wide spectrum of frequencies.Its not easy for me to explain this due to language barrier however right now I'm building a "proof of concept" a simulation where my earth is a weak slow magnet interacting with other things, I want to simulate the effect first to see if my theory is correct.They key is hendershot compass that I had replicated (I think i did), looking at hendershot solid state device wont tell you much however the magnet is there.
Hoppy
Wesley,
Thanks for your part 1 video. One observation about the ground wire length being a critical factor. When Kapanadze swapped over from the radiator to the water pipe ground in the green box video, the length was very much shorter and yet the device still functioned to light the lamps. Maybe Kapanadze's comment about his device having auto resonant tuning accounted for this.
There was no info about loop-back in the Ruslan circuit explanatory. I see this as a critical element to understand as it would surely affect front-end tuning, so should the loop-back be in place prior to tuning??
PolaczekCebulaczek
Quote from: Hoppy on July 24, 2018, 04:40:00 AM
Wesley,
First we should build the core device and see if we have some OU, even small OU would do, if the device is really outputting OU then it could melt when self looped OR perhaps not... if amount of energy grows to much then the device goes out of resonance for a while... free energy stops flowing, things cool down and after that back again to resonance and OU territory.
