stivep
tnx LankaIV
here  for curiosity is :
What's Inside a Tesla Model S Battery Pack -- World's FIRST Tesla Swapped Nissan 350Z - Part 9
https://www.youtube.com/watch?v=ENu8uuPIss8
https://www.youtube.com/watch?v=ouOqWZM28Qwhttps://www.youtube.com/watch?v=oM8YKgSgfxs
Wesley
d3x0r
https://youtu.be/Z7rd04KzLcg?t=2201  See also this Eric Weinstein guy... Geometric Unity: A First Look which is about... well a lot of geometry babel :)  But essiantially.. trying to get to work within the base system (curvature) instead of the product of evaluation of curvature (matrixes/quaternions) which are what relativity is actually sort of based on - it's a truncate -1 to +1 system because of 'symmetry'
I'm starting this other thread... I won't bother you with this any more; but I do sort of want to share a lot of this.
https://www.youtube.com/watch?v=mBjBuP0oPbc  THis is just using some plastic yard trimmer line to make a neat fidget toy.
https://d3x0r.github.io/STFRPhysics/3d/index.html  I did make this demo to view rotations as natural angles instead of matrixes or truncated quaternions. (I know, mathy graphical things, but really, primordial to relativity (curvature), and quantum mechanical spin states.
If you move the Z slider .... no if you Click on the Z slider and then use the arrow keys to move it a couple ticks left or right.... and then click on the blue-ish ball and rotate to the right... You'll see some interesting shapes start to form... the primary curvature reminds me of a magnetic iso-potential flux line through a solenoid coil... where with very small rotations, the solenoid is tall and thin, and as you increase the rotations it becomes more circular - to the point of almost being circular... BUT that rotation line (which there's a curvature.md document in the git repository that describes this in more detail... and there's a link at the bottom of the demo to the repository)
https://overunity.com/18542/review-of-mobially-wound-coils12-abha
J
- There's no such thing in the real universe as a point, or a thing with infinite curvature.  there are things that go in a line with 0 curvature.
- 'curvature' and 'angle' mathematically are the same values and use the same functions; they're sort of like different units (degrees or radians, but more like cubic-centimeter and milli-liter) Angle sort of implies you had an origin you're rotating around, where curvature applies to the point whereever it is (if anywhere).
d3x0r
This is a double post. https://overunity.com/13925/toroidal-coils/msg547891/#msg547891
For the electrical engineers... If I count the turns, and count the radius, and get an LC, and measure that LC for a coil to be the same, the coil IS the same as any other coil of similar LC?
Then how would anyone ever know the difference.  This is NOT tough; and there is no trickery in the jump cuts.  No video I make and post or promote has ads or is expecting some personal gain from you watching it.
Edit: https://www.youtube.com/watch?v=u9kUO3Luzfw  (winding plastic coils with wire instead)
which becomes the test coil in these...
https://www.youtube.com/watch?v=zuIiA7TWzmY
https://www.youtube.com/watch?v=TUZyoQwoG9c
J
d3x0r
So... in the kapanadze aquarium video... there's this toroid slinkly like coil (apparently; you don't really know the inner geometry), with a spark gap that's a high voltage impulse generator.
The coils respond - transfer power, on the edges of a square wave....
and I'm just going to quote myself from somewhere else
My friend the skeptic kept saying - look it's just like every other coil, don't you think over the past X hundred years... yadda yadda .... And it's the same resistance everywhere, even from people that are open to new ideas...
I understand we're all a lot jaded - disatisfied by any, really, even interesting result...
I kept trying to give away my lab ... free to a good home....  But the above requires no special ferrite, a pulse generator probably would work best - a very sharp impulse since that's what the ringback is anyway
I also have come to understand that although what I'm trying to show is plain as day and simple for me - like if anyone half cared to analyze these videos like kapanadze videos they'd actually not have that had of a time.  ... but at the same time I'm showing you  glass of water, and I'm saying it's fresh water, and not salt water, but you can't touch or do anything with it yourself, so all you can do is say well, test it like this... but I don't need to it's quite fresh... that's an entirely different glass of water over there.... and ... maybe ... this can show you it's really not so hard to get a couple glasses of water yourself?
J
I do Hope all are well...
Me; I don't really have a lot of time to wait around for confirmations from anyone; I dodn't know who else to implore to take a few arm-spans of wire and tinker....
It has a few inches of usable wireless tranfer range ; probably more if you had a proper resonance....
I may not have stressed enough - the reaction to get power on the pick coil is in no way resonance; it's a 'high' frequency because the LEDS were really only lighting on the leading edge... and I needed a lot of leading edges to make it bright...
And maybe I should be skeptical of myself, and say, If there is any trickery I did, I'm not are of it, and can't imagine what sort of trick I might have pulled when I wasn't looking.
-- Correction --
I did have one of the coils shorted on the one case, I can't prove any difference this way.
Wish someone else would have spoted - hey... those two blue wires... they shouldn't be together? Oh, right.
I'll have to keep diggging. Sorry
