0 Members and 76 Guests are viewing this topic.
magnetstoo
Mr. Wesley...Sergey Panov showed the  "Fish Pattern" in Ruslan Kalabuov device,and said to inject your signal there. Here are some screen shots with the "fish pattern" from my device using 48MHz instead of 20 Kv.. I find Hv and Hf have similiar properties in that they both migrate, penetrate,and carry much energy as per Don Smith.
I had to colour enhance these to bring out the detail because the lighter colours started blending with the white.
Anyway ch1 is the home gnd.....ch2 is the outside gnd...the center shows the channel(s) MATH,
2 pictures show (center) a Fourier Analysis-1 picture  for ch1 and 1 for ch2...Since Im using coil pickups the inputs are low volt and the scale is 200mv/div.
The third picture--you cant miss it---center shows ch1 / ch2 at which point I had to increase its scale to 1 volt.It shows a voltage swing of ~8:1 relative to ch1 and ch2...If you draw a line from ch1 to ch2 you will see about 20 deg offset p-p.
This is what Im trying to do, resonate it out of the ground,and control that offset and see what max I can get out of it.But adjusting a 48MHz signal obviously is not easy with the rf migration and rf losses and its attachments to objects.
Also,this Hantek scope does not have the resolution the PCSU1000 had,... but it does capture random screens like these because it does not "pause". .Very little operating instructions and no "Spectrum Analyzer" screen like the PCSU though it does have selectable data that is quick.
stivep
Quote from: onepower on December 24, 2022, 03:36:45 PM
For example, does a radio signal propagate outwards or does it disturb a medium
AC
Radio waves are electromagnetic waves. Electromagnetic waves differ from mechanical waves in that they do not require a medium to propagate.
https://www.quora.com/Do-radio-waves-require-a-medium-to-travel
Wesley
magpwr
Hi stivep,
Satellite as you already knew with the main component magnetron which the electron velocity is accelerated without the need for "Earth grounding" or counterpoise.If there was Earth grounding involved as the requirement i would not be interested in the kapanadze device a long time ago.
Eric dollard device is a negative-resistance device because of the counter winding which reduce the resistance of the entire winding by "half" if measured from end to end.
Too bad the scope merely reveal flat 2d waveform.It is difficult for many to understand how "electrons" movement create the electromagnetic fields.
Electrons are slow down by "resistance" but electrons can also be accelerated by "negative resistance"  :D
  People have seen  ring-down waveform many times but they were not shown/explained clearly why the amplitude is decreasing over time.Answer is revealed in the above sentence.
If anyone of you have seen ring-down waveform it is because of "resistance" created by one continuous winding.
People need to understand almost all the elementary formulas eg:V/I, V/R and many etc were derived from actual experiments before the formula even existed.I hope you understand what i am trying to convey.
stivep
Quote from: forest on December 26, 2022, 09:42:29 AM
https://www.youtube.com/watch?v=nhPkIH9G6Iw
magician knows his tricks.
It is a commercial. A Russian Man in goggles and gas mask
naming a price for it of a €10,000.
Wesley
