0 Members and 40 Guests are viewing this topic.
r2fpl
Quote from: kolbacict on April 20, 2023, 02:02:10 AM
I am generally convinced that the device must operate with different forms of energy.
That is, not to be only electrical, only mechanical or only chemical.
In one cycle, the law of conservation of energy will not allow an increase to appear out of nowhere. Work in a circular cycle is zero. You know it.
Maybe this is what you are talking about, Kapanadze's device has both hydraulics and electricity.
The problem is that it is difficult to look for pressure in plastic boxes, e.g. with 2kW films.  :o
Sergh
Quote from: endlessoceans on April 19, 2023, 05:53:28 PM
GUYS....there are no pumped fluids LOL not to gain energy off anyway.  IF there were its likely to be COOLANT.  You CANNOT amplify energy without first experiencing heat somewhere and that SOMEWHERE is usually at the switching.  These devices are about 4kw or so that Tariel made??  Something has to be cooled a little so if theres water or oil, it will be for that purpose.
  :(     You are jumping to conclusions too quickly... this is not a reality show. You should at least try to spend a lot of time to understand how it can work.
Let's say you have an ordinary hydraulic pump and an ordinary hydraulic motor from an ordinary agricultural tractor, for their usual pressure of 100 - 300 atmospheres.
The output of the hydraulic pump is connected to the input of the hydraulic motor by an ordinary pipe.
The inlet of the hydraulic pump is supplied with ordinary hydraulic oil, but with small air bubbles.
The hydraulic pump compresses oil with air from 1 atmosphere to 100-300 atmospheres.
What's happening? Yeah!!!
The same as in a conventional diesel engine. Oil burns with air from compression and adiabatic heating.
This phenomenon is known. Google "microdieseling". Harmful phenomenon in ordinary hydraulic devices.
What's next? The gas heats up even more, expands and the oil-gas mixture rotates the hydraulic motor with more energy than it takes to rotate the hydraulic pump. The hydraulic motor from  hydraulic pump 1 kW  turns the generator at 20 kilowatts.
You replace air bubbles with small HHO bubbles, obtained at low cost from the interaction of water with a quantum gravitational nanostructure, and you get free energy at the output of an electric generator.
The hydraulic diagram received from Kapanadze by a visitor from Bulgaria with the nickname Teofiliuss corresponds to the description.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg272350/#msg272350
January 26, 2011
Quote from: teofiliussThis is a principal scheme of the hydro-generator which was given me by Gia (Tariel's assistant).
https://sites.google.com/site/teslafreeenergy/_/rsrc/1296064809193/home/galeria/Hydraulic_circuits_275px.JPG
About principal of this device - Tariel says that he had constructed special hydropump, which have 1 kWt consummation and puts hydraulic pressure on oil: more than 200Bar. The power of this pressure is transform to the energy more than 18kWt. I think that its work with the help of hydroturbine. It is a good, if generator is more 1000 rpm. This was filmed some days ago.
https://www.youtube.com/watch?v=M2-8HkawRHo
https://www.youtube.com/watch?v=qUlLDQkqreA
Of course, Tariel did not tell him the main secret of low-cost hydrogen production. Therefore, it is necessary to try again to spend a lot of time to understand how it can work.
Quote from: r2fpl on April 20, 2023, 02:08:38 AM
Proton exchange membrane (PEM) for fuel cells
https://en.wikipedia.org/wiki/Nafion
But if hydrogen is obtained at the point of consumption, "on demand", at the contacts of the fuel cell, then the membrane is not needed.
Quote from: r2fpl on April 20, 2023, 02:08:38 AMis it the same capacitor? Is he really that big? What does big mean?
This is a 220 Volt -> 12 Volt transformer and an ordinary rectifier that Tariel's assistant made so that he can disconnect the car battery and power the device from the 220V output.
They talk about it in the video.
r2fpl
Gia is constantly present on the YT channel. I don't know if he really knows about the operation of Kapanadze's device. He hasn't done anything about it for so many years?!
AlienGrey
Quote from: r2fpl on April 20, 2023, 04:41:16 AM
So do you mean  'Geo' so what is the YT channel ? and how have we got onto car mechanics ?
talk about skater brain comes to mind, and there is this group of people who want to get rid of Oil
and funding war, and on an opposite group who want to prosecute the
(the get rid of oil campaigners as terrorists and associates as accomplices.
Power money and greed corrupts while they destroy the planet with poisons and toxins. SICK
AlienGrey
Quote from: r2fpl on April 20, 2023, 02:02:57 AM
a.king21:
Huge capacitor ?????
Tariel says there is a step down transformer with a capacitor to loop the device. If it was just a capacitor, there wouldn't be so many wires. It is exactly as seen in the photo.
You can even see the core of the transformer.
We need validated data to make progress.
Hairpin Tesla : is this the basis of the Kapanadze device?
There was a video on the hair pin circuit it works by generating Amps rather than Volts.
Another video shows a Tesla coil with nodes iluminating Leds on the nodes but to do that requires thought
and shorter wave length to do so. A car mechanic might have difficulty in acomplishing that fete  ;D
Imean my change the habit of a life time ?
