0 Members and 35 Guests are viewing this topic.
a.king21
Quote from: r2fpl on April 22, 2023, 02:25:42 AM
a.king21: Charging only one side of the capacitor requires one plus or minus sign. Depending on this sign, the earth gives or gives equalization of the charges in the capacitor.
The simple way is the Van der Graaf generator. Here you get only one character at the top. To get only + you have to separate the plus from the minus beforehand. It takes as much energy as connecting it to the ground!
I don't know of a cheaper method of producing only pluses.
I was wondering about this a few years ago. I was doing some static tests with discs and then I understood.
What you mention now is really beautiful and could explain how Kapanadze's devices work, but show me a cheap way to charge a capacitor with one side to ground. It's going to be easy ;)
Dom Smith shows us a trick and either doesn't understand what's going on himself or makes the audience look like idiots.
As I have shown, it has a connection to the ground on both sides. It is not even grounding 10m away, he just firmly connected the right side to the pin in the grounding socket.
Secondly, I did this experience. The plates carry the voltage in the form of plasma or thin discharges that we cannot see. It's another trick but not seeing the cause.
Sorry to burst your bubble. Listen at 1.06
The HV HF generator is battery-powered to avoid the ground loop.
https://www.youtube.com/watch?v=tASY07r9AD0&list=PLmf6BEWAWzyTeshjqaZH76NuyTgBqMi5D  1 hour and approx 6 minutes in.
Re pulsing one plate: Kapanadze advises a High-Frequency frequency generator.
The question is how high?  160 kHz? 150Mhz? Well as the patents usually say - it is for those "skilled in the art".
As an adjunct:  When I suggested his device uses High voltage Kapanadze contradicted me and said High Frequency.
I just assumed that it would include HV- but maybe not. I assumed it included HV because we can all see his spark gaps.
It could be that when looping back not only does the device increase the amps but maybe the volts as well.
In fact, thinking about the loop-back, it must also increase the voltage. hmmm
I see a few experiments........
pix
Quote from: kolbacict on April 22, 2023, 06:32:07 AM
The multiplication of electrons by the dinatron effect, for example, in photomultipliers, consumes the energy of the power source, which creates a potential difference on the electrodes and an electric field inside the lamp. Is not it ?    Turn off the power supply, and multiplication will stop.
"Current multiplier" isn't it?
Volts converted into amps, without transformer. Just a electric discharge in arc region.
Electric discharge - Wikipedia
r2fpl
Not true; because the effect is resonance. Ping-pong.
Requires minimal amount of energy to take off. It can even be a flashlight.
r2fpl
a.king21: The patent says - high frequency and several times. There is no word about HV. That's true.
Tell me what experiments you want to do and I'll tell you if I've done them before or not.
kolbacict
Quote from: r2fpl on April 22, 2023, 10:42:51 AM
Honestly say,i don't understood what is here doing resonans ? Besides, where would the extra electrons come from, if not from a power supply ? Now, if the electrons would come out of nowhere, and without external power sources ... I am dreaming... :)
