0 Members and 40 Guests are viewing this topic.
pix
Quote from: r2fpl on April 27, 2023, 04:38:14 AM
I'd like to see it in action. At least 10 years ago this was discussed but maybe you can show it.
Many thing has been discussed.
Tesla magnifier works, Kapanadze presentation in Turkey (TMZ) works and setup is stunningly Tesla-style.
Mechanical devices based on that exact mechanism works and exist. See my previous post with attachment.
Math do not lie, forced resonator with very low damping factor is accumulating energy with amplitude squared tempo.
Why nobody is questioning COP>3 of a heat pump or air condition unit?
I thing the answer is simple ( as Kapanadze  said once), right under our noses.
But people do like overcomplicate things.
It is my plan to put my hands dirty on this project.
Once time allows.
Cheers,
Pix
pix
Quote from: kolbacict on April 27, 2023, 03:25:43 AM
I read about it ten years ago. At Atsyukovsky.
Yeah.
Everybody did read and what?
Too simple to be true?
There is a Melnichenko patent on this .
And Kapanadze said once that Melnichenko was very close. He didn't specify on what Melnichenko was very close, but I guess it is this one.
METHOD AND DEVICE FOR GENERATING ENERGY ALONG WITH THE RESONANCE INTERFERENCE OF ELECTROMAGNETIC WAVES - MELNICHENKO ANDREI ANATOLIEVIC (freepatentsonline.com)
Funny, because Melnichenko did patent Tesla magnifier process. :o
Cheers,
Pix
r2fpl
PIX:
The GIA said there is no resonance there, at least not like normal. Let's think about resonance? What is resonance? When the swing is in motion, we have resonance. Unfortunately, electricity is not the same for a simple reason. Will the seesaw work on a spaceship? NO. Why ? because there is no gravity.
The same is true with electricity. Only here we always have BEMF and every oscillation produced we lose the same or more energy. There is no math of doubling without adding external energy. Resonance works only because we have a non-stop supply of energy. If the LOAD is 10% you will feel like you have more. That's all true.
I will agree only in yen, to talk about FE with resonance, you must have a mass like a bridge. It seems that it should be a magnetic field but maybe something else?
What Kapangze meant about Melnichenko. As far as I know, Melnichenko himself does not know this. Looking at his YT channel, it's hard to say why he wasn't successful. Did he go crazy from it?
The most important thing we see is 25A on the ground wire. There is <400Hz because this is the range that the clamp meter has.
Please understand that this is very important information for us. If there are two grounds then the AC is between them. If there is only one ground then only the open circuit version of the Tesla coil will give this effect. However, here is the problem with 25A! how to make TT at 25A at <400Hz? I don't know.
AlienGrey
Yeah perhaps your right but no we are forgetting perhaps part of the equation is more simple
The greedy, are using 50 or 60 hz it's one of  the Highest most wasteful frequency's they could have used
In fact any frequency below approx 20 khz is. So FE isn't free energy after all, you're paying for them to waste it.
Tesla said and many others on the net (you tube) mostly that at a certain frequency electrons travel in wire
with all sorts of restrictions (impurities) in the wire, that the same reason electricity will fry the in side of your body
some evil git called Edison proved that by killing huge animals in the street (perhaps because of greed).
However once above about 20 khz electric becomes like a gas (Tesla's words) because it starts to travel
on the out side surface of the wire It there fore becomes more efficient. So it's not free !
Sil
Sergh
Quote from: r2fpl on April 27, 2023, 08:33:31 AM
Not 400 Hz, but almost exactly the standard 50 Hz. They measure the frequency on the GreenBox video.
Quote from: AlienGrey on April 27, 2023, 09:19:58 AM
Everything is quite the opposite.
QuoteThe most important effect of skin effect on the impedance of a single wire, however, is the increase of the wire's resistance, and consequent losses.
https://en.wikipedia.org/wiki/Skin_effect
QuoteSkin Effect Resistance  Calculator
https://voltage-disturbance.com/engineering-calculators/skin-effect-calculator/
etc...
