magpwr
Hi everyone,
I reveal something from sergey video that will make people go crazy once more.
I have attached screenshot from the youtube at 4.59...5.01 Minutes into video.Have anyone wondered why Amps became zero from Power supply after Kapanadze device was powered up.
https://www.youtube.com/watch?v=7pE83oajjoo
---------------------------------------------Additonally one part of the circuit revealed by Sergey which i need to convert And gate to Nand to resolve circuit error in that circuit.I found out it is a divide by 12 circuit.
30khz example input frequency would be converted to 2.5khz.Please do not ask me why.
May be keen to know that the word "Electron accelerator" do exist today.But it does sound crazy talking about it couple of decades ago. :D
onepower
magpwr
QuoteMay be keen to know that the word "Electron accelerator" do exist today.But it does sound crazy talking about it couple of decades ago.
Strange isn't it?, a battery accelerates electrons due to a chemical reaction, a solar cell accelerates electrons due to excitation across a band gap and all our generators accelerate electrons due to a changing magnetic field. Where once the free electrons were uniformly distributed within the material now they experience a force which causes them to start accelerating and move along a conductor.
In many respects we could simply throw out all the math, equations, rules and regulations and all the complexity and say energy is produced whenever free electrons experience a force and start accelerating. It does not matter how the force on the electrons causing them to accelerate is produced only that it is produced in some way. In fact this is the only requirement...period.
Steven Marks got it right in my opinion... everyone is trying to build the most complex devices and yet they still do not understand the basics. Steven said all you need to understand is all the possible actions and reactions in a single piece of wire. If you can understand this one thing then you have all that is required to build a FE device. Oh I can just see all the supposed experts throwing up there arms claiming they understand everything however it should be obvious they do not understand. They have missed something so basic, so simple even a child could understand it found in the understanding of a single piece of wire.
One cannot claim to understand anything when they cannot produce the desired results and the only real experts are the one's with working devices sitting on their bench... that should have been obvious.
Magpwr, a little advice, what your looking for does not show up on a simulator and in most cases it does not show up on a DSO unless you know what your looking for. As Ruslan implied... throw all your fancy equipment and your complex theories out the window and use your head.
Hoppy
Quote from: magpwr on August 01, 2018, 10:34:28 AM
Hi everyone,
That's most likely because its powered from the grid on a 'hot Wire' straight into the device!
AlienGrey
Isn't that the 12 Volt input feed input from the start up battery ?
Think about this then for a change.
The Kacher suppose thats running with high voltage on it, how is that energy input into
the rest of the device ? The coil of wire with a few turns on it ? some things more basic don't add up.
AlienGrey
Quote from: onepower on August 01, 2018, 11:45:30 AM
magpwr
Well the signal comes from only 1 half of the 494 not both so if it's running from 12kh to 18khz the 4017 would only output
divide by 2 (input) and divide by 6 to 9  and then there is the 4013 divide by 2 again. some where around 1khz ?
But then whats the point of that ? but what it could do with a cap and resistor or two is test the PUSH PULL is running,
but I could think of an easier way to do that, but there again it's output goes no where! Oh and the logic is driven at 5Volts
But the TL494 could be run from 12 Volts or 24Volts, fun ain'it ?
