rakarskiy
Quote from: bistander on June 29, 2023, 05:14:37 AM
He shows a purely resistive load of 3 Ohms.
The problem is rakarskiy just plugs numbers into any old equation without knowledge of meaning of the equation and physics fundamental to the analysis.
And then insults everyone.
bi
QuoteVoltage drop is the gradual decrease in voltage along a conductor through which electric current flows, due to the fact that the conductor has an active resistance.
The formula for calculating the voltage drop is
dU = IR, where
dU - voltage drop
I - current strength
R is the active resistance
QuoteCalculating the alternator power to charge the battery.
To calculate the amount of power that the alternator will supply to the battery, you must calculate the amperage in the battery circuit.
According to Ohm's law:
I = U/R+r
Where:
I is the amperage;
U - difference between alternator voltage and battery voltage (U = Ug-Ub)
R + r - resistance of external circuit elements and current source.
Serg, you were right, my condition will be fulfilled at resistance of 8 ohms. But it does not change the essence of the EMF is always greater than the actual voltage in the network with the load.
pix
Quote from: stivep on June 28, 2023, 07:39:36 AM
Professor Michael Bank
Despite of what kind of value has his video channel  he is  giving us for free that what could be  turned to money.
So we are not talking about controversy here  but about willingness to share
Some information:
Jewish  speaking perfect Russian (educated in former Soviet Union)
https://www.youtube.com/watch?v=oHuDz29PT6w
Single Line Electrical (SLE) system of Prof. Bank.
https://www.youtube.com/watch?v=FscVyLtSk3k
One wire three phase system of Michael Bank.ru
This article is published and it is in close relation  to the subject  currently published in sequential parts
in here :  https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg579484/#msg579484
Summary : all at the end will come back to Tesla Coil and energy
Wesley
In my opinion in this "single wire" system of Mr. Bank an earth connection is the second wire.
Even if they make "nullifier" by isolating part of the soil from the rest of the ground with insulating foil, as they showed in the experiment- they just created a capacitor.
And as we know capacitors will pass altarnating currents.
And last but not least- if you draw electric field lines from the "single line transmission" of Mr. Bank- they will go towards ground and Poynting vector is directed towards the load.
Without "ground connection" this system will not work.
pix
Quote from: stivep on June 28, 2023, 08:16:13 PM
I had conversation  with BUNK
Yes -the same Russian guy in the mask and the gloves who presented his device on YouTube some time ago.
He told me his last name too.
more  details later
Wesley
That will be very interesting Stivep.
dsquared18
Quote from: Thaelin on June 29, 2023, 04:28:29 AM
This is why I quit reading a lot of threads here. If you have discourse with something, discuss it like adults and bring your proof with you. Try this on Fermi Labs and see what happens.
So right!
D2
kolbacict
Quote from: rakarskiy on June 27, 2023, 04:41:34 AM
Any electrician who will tune an electrical circuit from an alternator with permanent magnets in the rotor knows this.
Not Any. :D
