0 Members and 25 Guests are viewing this topic.
r2fpl
Quote from: rakarskiy on July 18, 2023, 04:59:08 AM
I have finished my contribution. Maybe someone will be interested:
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
I really like your version of the current amplifier that it is a step down transformer. It has already been mentioned that this element #9 is nothing more than lowering the voltage and frequency.
...Just raise the voltage to kV and then lower it. Do you think that's true? and why doesn't it happen?
rakarskiy
The original screen sketch of the reactor, which is associated with Kapanadze.
I see the focusing of the magnetic flux from coils (by analogy with Russell), between which or inside of which coils (with a different number of turns) are inserted, connected in parallel. If a voltage is simultaneously applied to them, then a corresponding difference in magnetic intensities will arise inside these coils. Similarly, the EMF of the electric field will be greater from the side where there are fewer turns in the coils. Thus, if you follow the logic inside the channel throughout the entire sausage, there will be an EMF with a potential difference. The magnetic flux in the rings will provide focusing of the EMF (according to the ANAPOL system). The outer layer of thick wire will provide the pulsation of this sausage, thereby providing a change in parameters. The wire laid inside will have both eddy emf and commutation with earth load. Earth is needed just for the same purposes as the grounding of one phase of the output in electromechanical generators.
If my analysis is correct, it is a generator, a pulse generator with a corresponding reactor.
rakarskiy
Quote from: r2fpl on July 18, 2023, 05:29:49 AM
For this to happen, it is necessary to exclude the intercircuit current coupling, leaving only the capacitive one. In this variant, we need a push for this change, it is assumed that the first source will provide the starting current movement in the desired direction. And the current from the second source will not prohibit the circuit.
By the way, I did not invent anything in this variant, but only dismantled, Budenniy's system, not Kapanadze's.
rakarskiy
Quote from: Sergh on July 18, 2023, 05:36:04 AM
The same thing, buy a ready-made amplifier and do not suffer:
https://aliexpress.ru/item/1005005575276437.html
;D
"Binoculars" is for antenna. But very similar, the solutions are the same. There are also welding ones on such core configuration.
https://www.pinterest.com/pin/510243832785975017/
