rakarskiy
Quote from: r2fpl on July 18, 2023, 06:12:42 AM
aha, so there is a word in this picture probably from the Georgian language? This raises the possibility that Kapanadze may have been present at its creation... at least that's what I'd like.  ;D
This drawing has a lot of features that appear in the green box and 2004 orange coil!
The probability is very high, while we must remember that the evolution of Tesla transformer, ends with a cone coil.  In the figure we see a cone of coils, while there is still Russell with his magnetic lens, make a sandwich of coils of the lens only paired winding leveling magnetic flux, we get a channel with electric potential difference vortex field, ready EMF. Run a wire inside this is the output winding.
By the way, element #9 can also be made by pair winding, and we will get the element I described, it is like a homework.
From here, it is now clear to me how the Zatsarinin Transformer works.
I'm done with it today.
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
r2fpl
1.2.3.4.5.6.7.8.9.10  this is the amount corresponding to the impulses we hear! when the device is turned off! 2004!
What a coincidence ! right ?
3x sound
r2fpl
Quote from: Sergh on July 18, 2023, 06:16:34 AM
Better think about what is "Sol borenia"
https://www.google.com/search?q=%22Borenium+Salt%22
I tried to study before. Fine chemistry. Physical chemistry.
Such compounds can act as a catalyst and attract electrons. But it is not strong enough to give a lot of electricity.
Why Borenium Salt ?
Sergh
Quote from: r2fpl on July 18, 2023, 06:23:20 AM
No, but this is what breaks all mass theories...
This sound and the operation of the generator after the primary energy source is turned off means that the bobbin with its contents is able to work independently for several seconds after the spark is turned off!
The mechanical squeezing of electricity cycles resonate with the bobbin winding and the load, and so the coil continues to produce power without a spark.Mechanical quantum resonator.
Kapanadze talks about this in a new translation of the video of this generator, links to which I have recently provided.
Then the participants in the conversation come to the conclusion that it is possible to make the device to work without a spark.
We can see the result of this in the Kapanadze "Aquarium" video, where at the beginning the arrester fires aperiodically and rarely.
If the device is healthy, it has enough of the necessary ingredients, and if it is finely tuned to 50 Hz, the arrester rarely fires. If conditions begin to change, heating occurs,  concentrations change, etc., the arrester operates more often. If the state of the device deteriorates greatly, the arrester starts to work continuously. Next, you need to turn off the device to find out the malfunction, which is what Kapanadze does at the end of the "Aquarium" video.
Quote from: r2fpl on July 18, 2023, 06:59:00 AM
Why Borenium Salt ?
How do you propose to understand "Sol BORENIJA" from this image?
What do you think about chemical compounds of boron? Some can be very secretive and toxic, such as:
https://en.wikipedia.org/wiki/Diborane
But I assume that "Borenium Salt" is one of the minor components or a catalyst. The main components are not indicated on the image.
r2fpl
are you talking about this word?
but that would be barium salt
Could it be Barium as an element that is in ferrites? Barium Ferrite ?
rakarskiy can verify this please.
