0 Members and 55 Guests are viewing this topic.
rakarskiy
Quote from: Sergh on July 21, 2023, 05:10:54 AM
3. A magnetic field cannot produce more energy than it takes to create or manipulate it.
Suppose the transformer core has a primary and secondary winding in the first n1 - 250 turns. in the secondary n2 - 100 turns. Excitation voltage 13V frequency of alternating current of the primary winding f - 400 Hz. Magnetic field in the core changes direction with a frequency of 400 Hz, the core has a gap of 0.1 mm, so the magnetic induction resulting in 1.1 Tesla. (Magnetic induction was calculated by the inverse EMF of the primary winding. based on its inductance) Conductor cross section 10 mm * 20 mm (=0.0002 m2).
We have everything to calculate the secondary winding EMF:
Е = 4,44*n2*B*S*f  =  4,44 * 100 * 1,1 * 0,0002 * 400 = 39V
In reality, the voltage was between 4.9V and 5V. When the frequency was changed to 300 Hz, the voltage increased by 0.1-0.2V.
A must have changed E = 4.44*n2*B*S*f = 4.44 * 100 * 1.1 * 0.0002 * 300 = 29V
If we take an ordinary magnet and a core with a winding according to the scheme of the simplest generator with the conditions of 50 turns and magnetic induction in the core, we get this result.
E = 4.44*n2*B*S*f = 4.44 * 100 * 1.1 * 0.0002 * 300 = 29V at idle.
Data from real experiments.
No, this is another ordinary things.
There is a 180 degree bend in the picture. It has inductance. Consider that this is not a short circuit, but a high-frequency choke between the leads of the bulbs.
Inductance, you say!
QuoteThe inductance of a coil depends on its geometric dimensions, the number of turns and the way the coil is wound. The larger the diameter, winding length and number of turns of the coil, the greater its inductance. When voltage is applied to the coil, energy is stored in the magnetic field and the electric current gradually increases. The inductance of the coil is determined by the formula: L = Φ / I, where L is the inductance of the coil, I is the current strength, Φ is the magnetic flux.
Can you, the effect of Tesla's experiment be confirmed mathematically?
If you want to calculate the inductance of a single wire 1 meter long, you need to know the diameter of the wire and its material. To calculate the inductance of a wire, you can use the formula L = *10^-4 * d^2 / (4 * (d/2 + l)), where L is the inductance of the wire in Gn/m, d is the diameter of the wire in mm, l is the length of the wire in m
rakarskiy
https://youtu.be/W9mBbjcRuRw
I've analyzed the drawing of the inside of the Kapanadze reactor. I came to the conclusion that it has a capacitive converter. Decoded one word and got "capacitance bifilar." I just on this suspended in 2019, my work on the book "Resonance - The Mystery of the Parameter" . This is a completely unexpected turn for me.
stivep
Quote from: rakarskiy on July 23, 2023, 12:38:00 PM
can you tell more about it  please
Wesley
rakarskiy
Quote from: stivep on July 23, 2023, 01:53:15 PM
Wesley
The closest word "tesia" can be translated as the name of the deity of the female name "beginning" The second option is closest to the word "bifilar", if we take into account the peculiarities of the Georgian language and slang declensions to simplify the names.
Perhaps this is the name Kapanadze gave to a paired coil with different winding spins, I have worked with such coils too.
In the picture we also see that the ferrite rings are grounded. The core of powerful high-voltage transformers is always grounded (http://boginjr.com/electronics/hv/flyback-driver-2/).
such a good patent:
https://patentimages.storage.googleapis.com/a1/5c/92/9d5d22ec6f82d4/US2521513.pdf
At one time on the forum "Charge"  there was this guy, he made a similar converter with the secondary output winding as a capacitance of paired windings.  I'll find his drawing and post it, basically everything goes to this configuration which is shown on my slide where I compare it to the Smith dipole system.
slide
link to the Charge forum post
__________________________________________
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
Sergh
Do you have any idea how much capacitance is needed for a frequency of 50 Hz? And for current more than 20 amps?
Such a capacity cannot be created by any bifilar of this type.
In addition, manipulations with the capacitance also do not produce free energy in any way, as well as manipulations with the magnetic field.
No power source - no free energy!
