stivep
Thank you Serch. I didn't read entire text yet but here is a comment  of Tesla
describing  energy conversion of lightning.
QuoteTesla: THE THREE WAYS OF INCREASING HUMAN ENERGY
FIG. 1. BURNING THE NITROGEN OF THE ATMOSPHERE.
Note to Fig. 1.—This result is produced by the discharge of an electrical oscillator giving twelve million volts.
The electrical pressure, alternating one hundred thousand times per second, excites the normally inert
nitrogen, causing it to combine with the oxygen.
The flame-like discharge shown in the photograph measures sixty-five feet across.
I do thank you  for the link.
https://teslaresearch.jimdofree.com/articles-interviews/the-problem-of-increasing-human-energy-
This glorified  Tesla  had little  knowledge about lightning and  chemical reaction of components of  atmosphere.
His observation led to many mistakes  not supported proven and explained. Known to us modern science was not there yet.
Quoteburning, exploding, or decomposing nitrogen compounds to form nitrogen gas releases large amounts of often useful energy
Nitrogen is not flammable and not explosive 78% of atmosphere But.. can "become"/assist the quite "explosive" and "burning", under
very special conditions https://en.wikipedia.org/wiki/Nitrogen
Tesla's intuition  was genial :
Thunder Storms :
QuoteTesla:
normally inert nitrogen, causing it to combine with the oxygen. The flame-like discharge shown in the photograph measures sixty-five feet across.
science based explanation:
QuoteUnder very special conditions, nitrogen can be consumed as if it was supporting the
combustion of other substances.For instance, it can combine with certain unusually reactive metals
not ordinarily found in nature in elemental form, such as magnesium.
-it isn't nitrogen that burns, but magnesium. Nitrogen supports the combustion.
Magnesium isn't found in nature because it much more readily reacts with oxygen.
Thunder Storms
https://sciencing.com/nitrogen-combustible-5397514.html
One of the special circumstances in which nitrogen can be combusted occurs during a thunderstorm.
Lightning causes some nitrogen to react with oxygen to form nitric oxide
QuoteTesla:
discharge escaping on the top of the ball) one hundred and fifty thousand times per second
he was using 150kHz
In conjunction with phenomena   named by Tesla Rotating brush:
here: https://youtu.be/GeF2BB8gtbI?t=251
experiment was repeated by known from many false explanations author "appearing" close to the crew of Eric Dollard.
-e.g. he claims existence of longitudinal electromagnetic wave
more educated explanation is here:
https://youtu.be/GbMAvn7nRWo?t=62
Wesley
stivep
Less related but unique in  its value:
teslaresearch increasing-human-energy-with-special-reference-to-the-harnessing-of-the-sun-s-energy-magazine-june-1900/
QuoteTesla: circuit energized by the oscillator from the distance .
prediction of discovery of remote control.
QuoteTesla: an electrical wave is reflected, and the same evidence which is afforded by an echo
prediction of discovery of radar.
QuoteTesla: we may determine the relative position or course of a moving object, such as a vessel at sea, the distance traversed by the same, or its speed;
prediction of discovery of geolocation, triangulation- positioning
Quote// Tesla: use the earth as a conductor, // the earth may be looked upon as an immense
reservoir of electricity, which, I thought, could be disturbed effectively by a properly designed electrical machine.//
The progress // was  very slow//  I finally succeeded in perfecting a novel kind of transformer
//not only to transmit amounts of electrical energy for operating delicate electrical devices,//
The result obtained was all the more remarkable as the top end of the coil was not connected
to a wire or plate for magnifying the effect.
Discovery of Tesla coil
1891 //  Tesla: my apparatus was barely capable of lighting one lamp (which result was considered wonderful), \
I state that I have now no difficulty in lighting in this manner four or five hundred lamps, and could light many more.
In fact, there is no limit to the amount of energy which may in this way be supplied to operate any kind of electrical device.
- Tesla's misassumption , -however  leading to our Energy transfer.
QuoteTesla: Professor Dewar's beautiful experiments with liquid air, which show that germs of organic life are not destroyed by
cold, no matter how intense; consequently they may be transmitted through the interstellar space
Based on  existent science  - Tesla predicting that life could come from   space  into Earth  e.g germs, microbes -frozen in ice from space
some scientific  literature in this area: https://www.livescience.com/61515-astrovirology-viruses-at-large.html
Panspermia#:~:text=Some%20microbes%interplanetary
Mentioned  by Tesla researcher : https://en.wikipedia.org/wiki/James_Dewar
Quoterhythm? All life-manifestation, \\ is only a movement, to which the same general laws of movement which govern throughout the physical universe must be applicable.
Tesla was raised as an Orthodox Christian. Later in his life, he did not consider himself to be a "believer in the orthodox sense" and opposed religious fanaticism.
Tesla - Atheist
./Nikola_Tesla My respect.
My own prediction/ expectations:
Not far from today country leaded by officially recognized Far Eastern European terrorists, will collapse again
disintegrating into much smaller pieces than in 1990.
Civilized world including Americans will no longer fear to provide scientific tests in their perfect salt water areas there,
I'm interested  in area of
fourth-largest lake in the world Aral Sea .
This area  survived naturally hundreds of millions of years only
to be totally destroyed by these particular
savages between 1960 and 2007=47 years
https://en.wikipedia.org/wiki/Aral_Sea
opinion expressed is my own.
Wesley
kolbacict
Quote from: stivep on September 19, 2023, 10:15:13 AM
especially if the form of  high energy impulse energy transfer from A to B. into a resonating load.
What are you mean, is a resonating load ? How should it look like ?
stivep
Antenna acts  as a resonating load, to the signal source using  properly matched transmission line .
The same applies to any configuration containing  any load and any signal source with respect to medium or means carrying out
the signal.
Little mix-up:
-Newton's First Law of Motion states that an object in motion tends to stay in motion unless an external force acts upon it.
-Photon energy is the energy carried by a single photon. The amount of energy is directly proportional to the photon's electromagnetic frequency
The higher is the frequency the more energy is there (- more energetic is photon..)
Practically we do not care about it till frequency is lower than harmful to us ultraviolet.
-Photon cannot lose all of its energy till it does.
And it does  due to e.g. universe expansion or  interaction with matter e.g. load.
-Resonating load  allows us to make energy of photon benefiting our application.
Wesley
kolbacict
I mean in case use it as weapon. What and where there must blow up?
