forest
 :-\  wrong again, better read something like that https://www.andre-waser.ch/Publications/NikolaTeslasRadiationsAndCosmicRays.pdf or http://tesla3.com/paulo-and-alexandra-correa/
or even think about what Richard Willis said to Dragons
We are like bird on the HV line.
Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe. This idea is not novel. Men have been led to it long ago by instinct or reason; it has been expressed in many ways, and in many places, in the history of old and new. We find it in the delightful myth of Antaeus, who derives power from the earth; we find it among the subtle speculations of one of your splendid mathematicians and in many hints and statements of thinkers of the present time. Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature.
What Tesla is saying is simple : if Earth magnetic field is static , induced once and never again then our hopes are in vain... but if this is a generator inducing and synchronizing our magnetosphere with external cosmic source then we can tap huge amount of energy easily and almost without cost. We can use it to catch CO2 from atmosphere , to stop pollution and burning fossil fuels and to make every people life a dream...
AlienGrey
Quote from: NickZ on September 03, 2018, 10:02:44 AM
   Forest:
   Some people may think that burning matter up (NMR) ,  is where it's at.
Although it can be "free" also, it's not what Tesla was after.
   While more nuclear plants are being built at this time, even though the one in Japan is still uncontrollable.
   Are we stupid, or just crazy? Or both...
    Wesley:  Please show us a safe NMR generator.
    Did you like getting sick, as you seem to like recommending poisonous solutions.
NickZ Hi i'm not Wesley no, your referring to a type of static  type of electricity (no magnetic charged current)
some call it radiant energy among other different other names. It draws energy from the environment or other things
or if not tuned can do other things which I wont discuss here, it's my guess you have no idea what i'm talking about
but it's another type of electricity that behaves so much unlike the conventional stuff we know. Are you sure that two
will ever be discussed on here?
stivep
some of my files that I have made for myself.
Examples of NMR in Ferrite  replacement of metal compound in within the ferrite by ion
caused by FREQUENCY
at the same time energy level of ferrite has changed. everything is done by changing frequency of oscillation.
http://www.sciencedirect.com/science/article/pii/0022369771900369
Nuclear magnetic resonance studies of Mn55
in the Mn substituted hexagonal ferrite Ba2Zn2-xFe12-yMnx+yO22
R. L. Streever, T. R. Aucoin and P. J. Caplan Institute for Exploratory Research, US Army Electronics Command, Fort Monmouth, N.J. 07703, U.S.A.
Received 22 December 1969. Available online 6 May 2004.
Abstract:
The nuclear magnetic resonance (NMR) of 55Mn has been studied in single crystals of the planar hexagonal ferrite compound Ba2Zn2-xFe12-yMnx+yO22 for values of x + y of about 0·5.
The spin echo spectrum at 4·2°K shows a broad line extending from about 300 to 470 MHz which has been identified with Mn+3 ions (replacing iron) on octahedral sites and two relatively
narrow lines at 555 and 585 MHz which have been identified with Mn+2 ions (replacing zinc) on the two types of tetrahedral sites which occur in this structure.
Both Mn+2 lines are observed to shift to higher frequencies with externally applied fields which is consistent with this interpretation.
The Mn+3 lines have also been studied at 77°K and the Mn+2 lines in the range between 77 and 200°K.
The hyperfine fields and the temperature dependencies of the resonance frequencies for the Mn+2 ions on the two types of tetrahedral sites can be consistently explained in terms of the
different electronic environments of the two sites. It is concluded that a large percentage of the Mn ions in the compound are replacing Fe as Mn+3.
From the relative integrated intensities of the two Mn+2 lines, it is found that the Mn+2 ions are substituting onto the two types of tetrahedral sites with roughly equal preference.[/c]
US Army experimented in 1967 with NMR and Transmutation.
From text above we see results of it.
It is stated that mechanism  of transmutation and  replacement by other  inorganic substance  was achieved.
But that includes energy transfer, and that is what we are interested with.(Lithuania Experiment)
Generation of metal–ligand cluster ion beams through pulsed discharge ionization and ablation
Ansgar Brocka, David L Cedeñoa and Carlos Manzanares Ia, , (Carlos_Manzanares@baylor.edu)
a Department of Chemistry, Baylor University, Waco, TX 76798, USA
Received 10 November 1998;    accepted 30 July 1999.
Available online 28 February 2000.
QuoteAbstract Pulsed capacitor discharge ionization in supersonic expansions was investigated for the production of intense beams of molecular cluster ions
from seeded and ablated compounds.
A pulsed discharge based on a triggered spark gap switch was designed and used as a method for ionization and ablation.
Several combinations of nozzle geometry and electrode arrangement in front of a pulsed valve, were made to optimize the intensity of the ion beam as well as its composition.
The cationic metal–ligand complexes Cu+–(methanol)n, Cu+–(acetone)n, Cu+–(toluene)n, Cu+–(water)n, and Al+–(water)n were synthesized by ablation of the metal from
metallic discharge electrodes in a discharge gas mixture of helium seeded with the ligand of choice.
The cluster mass spectra of the expanded plasmas show little background ion signal besides the metal–ligand species.
Charge exchange processes in the expansion guarantee high ionization yields of the desired species and account for low backgrounds.
Changes in the successive binding energy of Cu+–(water)n clusters n = 1–4 are clearly observed in the cluster mass spectra as step formation.
A similar pattern found in Cu+–(acetone)n suggests the same trend in the successive binding energy as known for water.
Important is :
Quote(phase, amplitude modulated) finite pulses run in parallel with all other events
https://kpervushin.wordpress.com/category/nmr-generator/
(Wesley: you do not need to  read this article)
This article is  interesting from perspective of spark gap and HV  involvement  in ionization that is frequently present in all of FE electrostatic devices,
by use of capacitor.
http://www.phys.ufl.edu/REU/2009/reports/AntonioLorenzo.pdf
APPLICATIONS -X-RAYS & NMR :
for me this is very interesting article about X-ray - means photons and  NMR but  this article is not for everyone
http://www.physics.usyd.edu.au/super/life_sciences/AN/AN6.pdf
http://www.youtube.com/watch?v=eBzmKgVnrP4
Instead of the coil connected to PL259 (and affected by  two  other coils connected to modulator interacting with Earth Magnetic Field. -like in NMR ( one of the methods.
The second one is cryogenic.))
I have connected generator and I was modulating manually by frequency shift of   +/- one of then thousand of 1 HZ !!!!
I have got enormous  amplitude of interactive-resulting pick 10 times of amplitude of the primary signal.
Please look  at spectrum analyzer and correct me with lower window setting.I put that window as Frequency domain.
The upper one is analog.  Look at other parameters of that window
This was my video showing
strange impulses from generator ( mixer of two signals) made  by  CREATECH
http://freeenergylt.narod.ru/index/0-36  Russian  link  related to FE and NMR 9 that is similar to   setup used in my video  from  above. with CREATECH.
https://youtu.be/NBXMG72gfqs?list=PL42F201860665F11A&t=474 interesting phenomenon in plasma.
http://www.rexresearch.com/meyernmr/meyer.htm  the old and much known
This PDF is for me very entertaining http://122.physics.ucdavis.edu/course/cosmology/sites/default/files/files/CW%20NMR/CWNMR012009.pdf
but you may disagree
Plasma:
http://www.aetherometry.com/Patents/US5502354A1.pdf
http://aetherometry.com/Patents/US5449989A1.pdf
http://www.aetherometry.com/Patents/US5416391A1.pdf
\http://www.rexresearch.com/correa/correa.htm  opinion about Correa.
http://www.aetherometry.com/Labofex_Plasma_Physics/Archive/CorreasUSPAbstracts.html
Abstracts
http://www.aetherometry.com/Labofex_Plasma_Physics/aspden_opinion.php
additional material  published by me at overunity.com
Lakhovsky Multiple Wave Oscillator original device http://www.youtube.com/watch?v=rRttn7xb0y8&feature=channel&list=UL
some links  posted by me in the past : (Wesley: you do not need to  read this articles)
Watch this: NMR in room temperature using Earth magnetic field. No Cryogenic!!
http://www.youtube.com/watch?v=7aRKAXD4dAg
http://www.youtube.com/watch?v=F2BED9aDEYw
and this:
http://patft.uspto.gov/netacgi/nph-Parser?Sect2=PTO1&Sect2=HITOFF&p=1&u=%2Fnetahtml%%2FPTO%%2Fsearch-bool.html&r=1&f=G&l=50&d=PALL&RefSrch=yes&Query=PN%2F4291255 http://www.rexresearch.com/meyernmr/meyer.htm
additional material TESLA book:
http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf (link does not work but can be found if needed)
http://jnaudin.free.fr/html/mmcgen.htm
http://freenrg.info/TESLA/Tesla_Switch/D3.pdf
http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/ (link does not work but info is on overunity)
http://jnaudin.free.fr/html/paraform.htm
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296310
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296308
http://www.youtube.com/watch?v=b2n1-nvo7d4&authuser=0
https://www.youtube.com/user/diggitydev/videos  Doc Schuster videos
Wesley
nelsonrochaa
Quote from: v8karlo on September 05, 2018, 03:54:07 AM
Hello everyone!
I've been looking at some old videos of Igor Moroz. First part  https://www.youtube.com/watch?v=FFg9h_gGrFg  and second part   https://www.youtube.com/watch?v=IpAuvTBCugs  Basically, in second part, he is telling that he is returning same amount of energy to grid and in process using few hundred watts of light. He is using bifilar coil as the secondary in his transformer. So, the net consumption would be very little or nothing, frequency is grid frequency 50Hz. Looks very similar to Kapanadze.
Lost energy in close circuit could be recovered but not created . In this case the feedback of output power is injected again in system input .
Myself made some experiments about that point .
Example how could be possible recharge the same input source in same time . The video have 21 minutes is easy to see how much the input lower since start.
https://www.youtube.com/watch?v=I_eja4gmpcY&t=665s
https://youtu.be/Te7NcDY-afQ?t=35
Nelson Rocha
Kator01
Now,
concerning the video about Ohms Law broken with HV Negative Resistor ( https://www.youtube.com/watch?v=RRp2nipT-S0)
I found these two demonstrations of Fred B´s Tech Channel very interesting especially part 2 because of a good working sparg-gap simulation model. It clarified many questions I had:
https://www.youtube.com/watch?v=wU8LYiLLpGs
https://www.youtube.com/watch?v=N7gPeIVVy0A
Mike
