0 Members and 25 Guests are viewing this topic.
Acca
Wesley that long NMR post is really good as I have been a supporter of the "inter-atomic" model and it's NO theory..
Italians have discovered through audio ultrasonics cavitation that iron chloride goes nuclear in 2008, and since that
discovery I know that the same effect is responsible for the extra electrons in the yoke core ferrite radiation that you
have been exposed to that gave you that radiation sickness..  See low energy nuclear radiation..
As to members who post anti- free energy posts I always see these distractors as fools or spies who spend allot of
effort to stop any progress through the "dogmatic science" leverage ... and there is many here of such anti-free
energy efforts shills, spies and total nut jobs..
Keep on and God speed in your efforts..
Acca..
Belfior
"In L'Évolution de la Matière (1905), Le Bon anticipated the mass–energy equivalence, and in a 1922 letter to Albert Einstein complained about his lack of recognition. Einstein responded and conceded that a mass–energy equivalence had been proposed before him, but only the theory of relativity had cogently proved it.[36] Gaston Moch gave Le Bon credit for anticipating Einstein's theory of relativity.[37] In L'Évolution des Forces (1907), Le Bon prophesised the Atomic Age.[38][39] He wrote about "the manifestation of a new force—namely intra-atomic energy—which surpasses all others by its colossal magnitude," and stated that a scientist who discovered a way to dissociate rapidly one gram of any metal would "not witness the results of his experiments ... the explosion produced would be so formidable that his laboratory and all neighbouring houses, with their inhabitants, would be instantaneously pulverised."[40][41]"
forest
Belfior
Quote from: forest on September 10, 2018, 06:25:02 AM
Ok. Theoretically is is simple. Let me explain. There is law of conservation of energy , true. However thee is no law of conservation of work done. In other words it's up to you how much work you can do with the amount of energy you have - mostly it depends on how good you can eliminate loses like friction.
So ? I think you start to see the picture. ...
Analogy to water. If you direct a stream of high pressure water into a still pool of water, there is more water moving than just the stream. Voltage we can just create.
Also you can create special situations where Nature will do the work for you.
magpwr
Hi Wesley,
Upon searching "ionization accelerates transmutation" gave me interesting results which you may find it interesting related to acceleration.
Nuclear tranmutation to Nuclear fission 1932...1939         **(Nothing to do with actual Nuclear around late 1920s)
https://books.google.com.sg/books?id=rk5uBwAAQBAJ&pg=PA55&lpg=PA55&dq=ionization+accelerates+transmutation&source=bl&ots=OnWKIofSVO&sig=Ry9cTNZ_1myoQr5NUENVOVh5xQs&hl=en&sa=X&ved=2ahUKEwio7svPt7DdAhWBNI8KHUBoC9gQ6AEwAXoECAkQAQ#v=onepage&q=ionization%20accelerates%20transmutation&f=false
The above is the early version way before NMR was mentioned anywhere. :)
---------------------------------------------------In the meantime completed improving my circuit to produce "ultra stable" interrupted frequency in Mhz for the tesla coil without the use
of mica capacitor for one of the 3 tesla coil driver embedded circuit,pulse generator.
Received parts to assemble the Antenna which i threw away sometime back along with tesla primary driving coil after failing to see OU.Accelerator with sine-wave 80khz will be shown once ready as it is before further modification to resolve existing "impedance issue".
