apecore
Some notes from Zeitmachine in a other Kap[anadze related thread.
A COLLECTION OF GUNTIS/COSMOLV STATEMENTS
1) Tariel said, the device is very simple;
2) 220V goes in and 220V goes out; 50Hz;
3) everything is in the coil setup - actually in windings; it is a bifilar coil but in non-standard way, closed looped by itself;
4) all magic happens between coils; trigger coil is the output power coil; try to put your mind back to those years; no semiconductors, no RadioShack - nothing, just wires and transformers;
5) most important thing is to generate sharp pulses;
6) device is not transformer but choke where high voltage - no more than 2000 volts - produces light ionization; what you need is little high voltage to give birth to new electrons and lots of electrons forming around the wires, the second thing is to activate these electrons;
7) a static field or ionization is also called a dead magnetic field, but we can convert this field to perform work;
8) high voltage in specific frequency creates a dead magnetic field; if we synchronize this high voltage with the low voltage half-wave, then we can turn the core in an electric generator and it works like a combustion engine;
9) high voltage is injector and low voltage is piston, magnetic field is combustion chamber;
10) when impulses are generated, a magnetic field is created in a bifilar coil, so in total you have one source, but in fact you have resonant magnetic generator with two fields;
11) it is not enough to loop electricity through coils, you need to interact with medium (make a bridge); but remember always and always this is manipulation with time;
12) ions are attracted by ionization, this high voltage field is magnetized with vibrations and we get a very powerful magnetic field and this field is the outside power; energy is received on coil through magnetic field, not electrical or electrostatic;
13) this device is not a toy, it has a great ability to change our lives and it needs to be done in a smart way; we need to think globally; if anybody release schematics government takes fast control of it, it will be turned as illegal immediately; actually the effect in this device is very specific magnetic field, the technology by itself is like atomic reaction, but without pollution of radiation; BUT ... this magnetic field, if you make it stronger, it can kill you in seconds or, if you make it stronger, it can cause an effect like an atomic bomb; you cannot change the world or change the rules of our governments. With this device YES you can! Free Energy is only one side of it, other side is the most powerful weapon in human history after Nuclear Power! By the way, nuclear power sits far back compared to this (Free Energy) principle; it generates its own magnetic field which is not dependent of earths fields, without earth grounding the device produces too much power, but this is different story which is not related to Free Energy, there are more things, not only Free Energy ...
apecore
Sergh
Quote from: stivep on May 27, 2018, 05:03:06 PM
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg521745/#msg521745
As of Today at  5 PM  Eastern Time I have made  addition to   material posted  previously.
Please visit link form above to see  changes.
there it is.
Coil Cpacitor  however  there is no need to build one just fallow instructions on picture below
Wesley
On this Kapanadze device presentation in Turkey is ordinary "cosinus" capacitors. This capacitors used in industrial electric equpment on 50 Hz. These capacitors allow a long-time alternating current through themselves to several tens of amperes without overheating. Not very much  amperes trought one, for example a capacitor of 20 kVar at 400 volts allows a current:Icap = 20 000 Var/400V* sqrt(3) = 29 A. These capacitors can be used in a resonant circuit at a low frequency, 10 to 500 Hz, with connecting many capacitors in parallel. These capacitors are not suitable for the Tesla coil due to overheating on the HF.
I think that this circuit with capacitors is needed by Kapanadze as a converter-"filter" of dirty nonsinusoidal current from his hidden X-Source into a pure sine current of 50 Hz, suitable for use in a conventional electrical network.
https://www.alibaba.com/product-detail/2017china-wholesale-market-three-phase-kvar_60684828500.html
PolaczekCebulaczek
Ok, Thanks Wesley, I think I do understand now, so just to be sure... before rolling the coil capacitor it should look like this: (side/ profile view)
and what frequency is recommended for 10m long, 5cm wide strips? and what type of impulses?
d3x0r
Re a coil capacitor....
This is a massive coil, wound just double layer (one inside, one outside).  Inside is a large neodymium magnet, when it rotates, it generates a current flow in the coils.  The coil ends independantly can be used as a + potential and a - potential, and thereby have a charge stored in the coil...  this charge can then be used to kick the magnet to continue to rotate.  There is very little drag effect because of lens when the coils are open...
https://www.youtube.com/watch?v=0xLFl5RhNgU
(I dunno it's been a work in progress for a while... this is somwhere in the middle... but towards the video leadin)
http://open-source-energy.org/?topic=3128.msg49555#msg49555
