r2fpl
This is my concept for closing the magnetic path.
Why to change the path you can simply turn it on, activate.
Ferrite core or even the coil itself closes the flow of the stream by connecting the top and bottom together. If you have a ferrite it must be far enough away not to connect the rings and activated only when the voltage is turned on. In the case of the coil itself it does not matter.
stivep
Thank you for your comments my dear friends.
I have some  positively shocking revelation in area of Ted device.
I  must:
- check if I'm authorized to publish it.
- decide   if I want to  make  another video  or just publish it.
- decide  which forum is technically  the most  interested with Ted technology .
Down here is some preview.
This is photo not drawing.
descriptors   are the addition  that was written  later on the picture
That what you see it was fax copy .
Wesley
Void
Hi Wesley,
Sorry I have been busy and haven't following this thread that closely.
By 'Ted device', do you mean the TED device from these guys:
https://www.tedmagnetics.com/
"U.S. Patent 9,742,252 was issued on August 22, 2017 for the PMIG with rotary reluctance switches.
A US patent application was filed in December 2016 for the PMIG with electromagnetic reluctance switches.
The application for the PMO is in process."
https://patentimages.storage.googleapis.com/18/91/dd/7a7068f79f2d64/US9742252.pdf
The topic of this thread seems to be jumping around all over the place. :D
r2fpl
I suggest combining streams in such a simple way. Why shouldn't it work? We don't have to change the polarization just to enable one field.
stivep
- US20070242406A1  2007/10/18  by Annis and Eberly?
Electricity generating apparatus utilizing a single magnetic flux path
Wesley
