apecore
Quote from: Void on June 30, 2018, 01:49:03 PM
Apecore, it sounds like a good experiment approach to me.
I have conducted a number of experiments along this line already in the past,
so I am now taking a bit of time to review some of the basic setups by Kapanadze, Prentice, Daly, Akula again
and thinking about it all some more. As soon as I get some time I will continue with more experiments.
I am still reviewing info and thinking more about it all right at the moment. Trying to think
of some different approaches to take based on what I have already tried in my previous experiments. :)
Ok i m fine with that.
I will see if i can make a setup running on either a sub harmonic (primairy side)..  in order to tune the secundairy at the approx. 10Mhz.
Getting it running and stable...   should be the first goal.
And of coarse frequenty adjustable in order to tune the secundairy frequenty in most efficient way
Greetings
stivep
Negative resistance generator: Chua's Circuit Presentation and Applications chaotic generator.
some reference material.
We are interested with impedance  generator  based on  resistance generator.
http://www.analogzoo.com/2018/01/negative-impedance-converters/
http://www.jestr.org/downloads/Volume6Issue4/fulltext11642013.pdf
https://www.youtube.com/watch?v=ezIBFuuJiy4
https://www.youtube.com/watch?v=m-XsyeFfp-U (#0124) Relay Relaxation Oscillator with Negative Resistance
Wesley
mkjekyll
With a grounded system one is looking at something similar to the lightening return stroke. The earth echos back a reciprocal of the E wave which needs to be converted from it's conjugant state by plasma coupling or inductance. Each bolt of lightening has up to six strokes one to the earth one back from the earth etc.   http://apollo.lsc.vsc.edu/classes/met130/notes/chapter14/stroke3.html
look here, can you see the quandry of this Tesla device?
It is also negative resistance and what he used to record lightening strikes:
https://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes02.htm#Colorado%20Springs%20Notes%20-%20June%201-30,%201899
Void
Hi Wesley. While the two separate earth ground approach may very possibly be a viable
way to achieve COP > 1 (Frank Prentice used two separate earth ground connections on his transmitting long wire, for example),
in all the Kapanadze demos videos I have seen, Kapanadze appeared to use only one earth ground connection (at a time). You have
seen Kapanadze's setup operating up close in person once or twice right? Do you agree that it only used one earth ground connection?
Just want to see if we are on the same page on at least that particular detail. :)
Void
Quote from: stivep on June 30, 2018, 08:46:43 PM
Interesting video!
