Void
If someone really has something, they will be able to demonstrate it. That is for 100% certain.
If they are trying to protect a 'secret' they can simply place the secret part in a box to protect their 'secret'.
People who do not have anything can't demonstrate anything, because they have nothing. ;)
They will make excuses of why they can't demonstrate what they are claiming, such as they
are trying to keep a low profile because they are afraid of MIB's/evil secret agents, or they are trying to protect someone's
patent, etc. This is of course all nonsense. If they were trying to avoid getting the attention of MIB's/evil secret agents they
would say nothing at all, and if they want to protect a secret they can just simply place the secret part in a box, and then
they can demonstrate their amazing device with no issues. ;D
No demo? Then 100% for certain there is nothing there. It is very hard to demo something that doesn't
really work or which has never actually been tested on the bench and proven to work, unless it is just a scam
or a hoax. Hot air out equals hot air in.
stivep
https://www.youtube.com/watch?v=dOJfr_lz0jU
This guy exactly shows processes in  all  of known devices.
Two generators.
90 degrees.
and  rectangular impulse
that rectangular impulse can be generated by third  generator.
injected before the maximum of amplitude.
He  even shows how to calculate parameters
The only addition that I have made was to provide certain and convincing,  common  elementary structure to all. Akula Tariel Vasmus, Ruslan and  others.
in my video https://youtu.be/KLAPRNWuAn4
In addition to that:
I made conclusion that Viziv  surface wave can  interact with Shumann waveguide  with one if its polyphase components.
And that is till now the only explanation  pointing at energy origin used than by devices able to interact such Tariel Kapanadze based concept.
the  base for all of  it is Tesla Coil.
Viziv and FE  devices of Tariel Kapanadze concept  uses Tesla Coil.
I need to give credit to T-1000 My friend Arunas from England  for Lithuania Experiment.
Wesley
itsu
Quote from: Jeg on December 30, 2018, 02:38:30 PM
Lets spark some fire.
Following image is from Q topology.
Yellow is across the input capacitor.
Reference for both the probes is common and it is the ground of battery,
Blue is across Czero.
All caps are 470uf/400V
Input to my push pull is 24Vdc.
Load=40 and 70 watts incadesent which anyway shines bright.
Czero almost 37 volts when charges and 12 when discharges. This is a 25 Volts difference.
Input current from battery looks steady 2A with or without the Q-feedback topology.
Normally i would expect that during return cycle, input voltage to be increased over 24volts. Or at least the input current to drop down even a litle. I;ll check if i have any errors in connections.
Hi Jeg,
very nice, but:
What is the input cap?  C1?
Blue is across CZero?? You mean from common ground (battery) to CZero/L1 or to CZero/B1?
Load is 40 and 70W (110W), so 2 bulbs?  And what voltage (240V, 12V)?
Input current is 2A, so at 24V = 48W input?
I have a similar setup build, but with the requested 12V input, will post some details later today.
Itsu
itsu
I too build the Q device, but the bulb B1 (12v/21W) does not light up (without feedback).
CZero is 2x 10uF parallel / 400V bipolar, it has about 18V DC across it
C2 is 22uF / 250V electrolytic, it has about 35V DC across it
Below screenshots show:
gate signals (running at 10Khz)
drain signals
Signal across L1
Signal across B1  (nada)
Controller is TL494 with IR2113
MOSFETs are IRFP260N
(see  https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg474350/#msg474350)
Picture shows the setup.
Input is 12V from a stack of supercaps (6x 100F = 15F) and draws only about 90mA.
Am i doing something wrong?  Is the feedback needed?
Regards Itsu
itsu
Now with feedback.
B1 very dimly glows now.
Input current went up from 90mA to 400mA (12V).
Same screenshot as Jeg (i think):
yellow is across C1 (supercaps)
Blue is across common ground (minus supercaps) and L1/CZero.
Green is current through B1.
Running at 60Khz like jeg.
So the feedback leads are needed.
Itsu
