stivep
Quote from: blueplanet on January 02, 2019, 08:56:33 AM
Good stuff.
Thank you my friend
Wesley
I do not  take any responsibility for your action .
to make  your understanding  clear  I say  do not do it ever.
That applies to all post of mine and all videos of mine.
stivep
So guys the whole  trick is in that so called  "mirror reflection of the ground phase"
At certain point you trapping  electromagnetic wave inside of that interface between air and ground.
but  in reverse  we may say that we are dealing  with Schumann waveguide having one of its boundaries shared with our receiver.
that is the earth.
All lightnings and all energy  fluctuations are  affecting that boundary .
Now what we need is the receiver. that matches exactly phase  dependent energy inside of that interface.
- Kapanadze receiver.
- Akula receiver
- Ruslan reciver
- SR193 receiver
- Vasmus receiver
- Chibanidze receiver
When Corum brothers where talking about  protecting their energy send by their Viziv tower  they  said that
It is impossible for anyone to be able to steal this  energy because  algorithm requires
exact phase match of that polyphase   components.
Yes they are right.
They can create zillions of polyphase components.
Their problem is:
That they do not know that nature does not care about their polyphase.
Wesley
Legal Note: I do not  take any responsibility for your action .
stivep
Quote from: forest on January 02, 2019, 03:16:46 PM
"Read  my  post again.[/size]the energy is extracted from  Schumann  waveguide."
only in this case I think, it's still not explanation at all
I'll try again:
In traditional approach:
You have suspended  sphere in the air
You can move  sphere up down
The mast is telescopic structure made from PCV
The  HV of Tesla coil  is right below
The primary winding of Tesla Coil is at the bottom.
However that coil is not on the ground.
This is your transmitter.
The height of the sphere is your tuning factor.
The diameters and  other vital structure  elements are given on the picture.
The receiver can be exactly the same  if you already phase matched it.
So how to do it;
Legal note : never do it. :)
1.Make two identical structures
2.the first one is your transmitter. Tx
3.the second one is  your receiver. Rx
4.place  both of them at the distance of 20 meters.( so Rx is not in Near Field in Tx)
5.Try to tune  the transmitting structure  primary  coil using at first regular function generator.It is tricky as you need right polyphase.
it should be close to 90 degrees ( not exactly  90) but I got it at 45 degrees.
6.Try to adjust your receiving  structure  similarly and have oscilloscope connected ( at best spectrum analyzer) to the low  voltage primary coil of Receiving structure.
7."Blindly" play with frequency of transmitting function generator and height of the  sphere.
8. make sure that your Tesla coil  works on its resonance frequency. So you must calculate or measure its  highest point of resonance.
NOT ITS HARMONIC resonance!!!!!!!!!!!!!
9. observe  using another person what is going on  at the receiver side.
10. than minimize the power   from generator to 50% ,retune both  the Rx and Tx
11. than minimize the power to 10% and retune .
Wesley
Void
Hi Wesley. In my experience in this area of research only the test bench can tell you what actually works
and what does not. What might seem easy in theory often doesn't work out that way when put to the actual test. :)
Nature has a tendency of getting in the way of our ideas. Here is reminder of what Kapanadze's basic 2004 setup looked like.
stivep
Quote from: lancaIV on January 02, 2019, 04:33:15 PM
No concern that this "transmitter" technology is probably restricted in use by
a. https://www.itu.int/en/Pages/default.aspx  International frequency band use or national b. Genfer Konvention : acoustic weapons/instruments
c. health-regulations: electro-magnetic compatibility
We have had in the last thirty years sufficient discussions ( studies ? ) about electro-smog.
No my friend:
Acoustical wave is longitudinal wave that is property of classical physics.
Zenneck wave is in area of quantum physics and is electromagnetic TEM that has nothing to do  with acoustics.
It is also non radiative. -  After the Near Field   it disappear . It does not exist in Far Field. Well sort of...
If your Tx is not transmitting omnidirectional  electromagnetic wave,  but flat surface wave than there is no way  for any agency or anyone to find its presence.
We are talking about not radiating TEM and its TM ( transverse magnetic mode ) not  about  EM Wave.
There are no receivers in the  world  for it known to me.
Think about non polluting flat wave like flat  squashed elephant, or
flat ant squashed by   bulldozer and now in the interface.
- the elephant is your 1000W
- the ant is your 1W
Viziv  license  expired.
if you want to  be  on  line with regulation you can check your local regulations.
Wesley
