0 Members and 46 Guests are viewing this topic.
#2074 James Corum 1980 priority year patent to citing documents
https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=4751515A&KC=A&FT=D&ND=&date=19880614&DB=&locale=
with newest 2018 entry from CPG Technologies ( not to promote only to compare 1980 knowledge with 2018 technical standart)
Void
Quote from: stivep on January 04, 2019, 08:41:32 PM
Yes please do it.
We may  assign his coil to one of concepts of Corum brothers.
Thank you.
By the way I did not list Daly
Look also at word: combined.
from text above.
Wesley
Hi Wesley. OK, after reviewing the pictures of Daly's coil disassembly, there was not
any special counter windings like Akula and Ruslan used that I can see. Daly did have have two
to three layers of wire for his output coil on one end of the coil form, but all the turns seems to have
been in the same direction for his output coil. He just seems to have wound it that way to be able to
fit all the turns he wanted for his output coil on there, and there was extra room at one end of the coil form
since the coax he used for the high voltage impulses didn't run the full length of his coil form.
I believe Akula first copied Daly's setup, and then made his own variations after that, of which Ruslan later copied.
I believe I see a common general approach in all these devices, and therefore I think I have the general idea of how
to try to replicate these devices. Once I finish my experiments with my current test setup not related to these devices,
I will try to do a proper replication of these type of devices based on the way I think these devices need to be configured.
If I get anything working, I will try to make a demo video. :)
I would say it is definitely still unknown where the extra energy is coming from for these devices, assuming they really work
as claimed and shown, and I am inclined to think Kapanadze may be sincere when he says he thinks the energy comes from the
'surrounding ambient environment'. In other words, I think no one is really quite sure where the actual energy is coming from, is my guess.
First a person has to get a setup of this type working, and then you can let the propeller-head physicists argue over where the energy
is really coming from. ;)
Hoppy
Quote from: stivep on January 04, 2019, 06:34:57 PM
look at  picture 12a you have series  connection.
just cut out impedance matching box as if it  did not exist.You use it only if you need it.
You can do  the same with 12b
There you go
You may still call it parallel but  it is series with respect to ground
You may say there is no ground.
Than think about counterpoise.
Kapanadze concept was much more advanced but it was very unstable and highly reactive.
Kapanadze was trying to move his device only in vertical axis Y. Walking with it would ruin his show.
I did the same here with placing dielectric on the top of another.
https://youtu.be/KLAPRNWuAn4?t=1174
and not to much.
Wesley
Yes, with 12a but not with 12b.
"You may say there is no ground."
"Than think about counterpoise."
"Walking with it would ruin his show."
So, its an inductive coupling from a TX ground coil??
 Definition : Macro Regime and Quantum Regime ! https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4720642A&KC=A&FT=D&ND=3&date=19880119&DB=EPODOC&locale=en_EP#
Definition : Schumann resonances !  https://en.m.wikipedia.org/wiki/Schumann_resonances
Pardon me, but let me become ( very, common ?) vulgar/" ordinaer" : Me interests a BS neither which NAME the energy to useable power spectrum has(ZPE,Vacuum,Near/Far, et cet.)   nor how the device ( at first) has to be constructed : common Tesla antenna, flat antenna,mesh/ array,
macro-/micro-machinery ..... !
  The first target is to reach a sustainable development aspect bewaring device which shall satisfy the first interests stage : available environmental energy conversion !
Wesley,  yes resonance is suppressed in the grid network(as to read in the Dinnan/Meta-C papers), but begin to
think for example about small fluorescent bulb ballast and their ( "interference, mismatch)net grid distortion and think then bigger : industrial by 100 KW and more electric devices inertia/ inrush voltage or current phase !
Maxwell- Wien displacement laws ! The comercial world pays for " Blindstrom/ apparent current" compensation !
Off-grid (" island-solution) we can experiment with all physical possibilities ( caution : chance/ risk ratio ), on grid there are clearly physical and technical ( by concept) restrictions and limitations ! Which has to be respected ! By free will and law !
About Nikola Tesla : a great inventor ( honor : Physics Unit  : Tesla ) for the other side : how had been N. Tesla without the creative partnership with Charles, " Prometeus", Steinmetz ?How many " creative thinker" in the Tesla Labs saw their work later as " INVENTOR : Nicola Tesla, assigned".
                                             Loud thinking without reflex ex(s)pectation
                  "Denkmal des unbekannten Inventors" , Schweigesekunde (Minute , dafuer :P ,zu lang )
                                   DIE S(ch)AU MUSS GO ON ( or OFF)
Sincerely
  OCWL
   https://de.m.wikipedia.org/wiki/W%C3%A4rmerauschen
          Quantentheoretische Erweiterng
       Boltzmann : What is a " black" what is a " white" body,  STRICT BLACK or STRICT WHITE : dB,nm,eV !
     ( what is in Quantum Physics : body)    "Ultra-Violett"- Katastrophe ,
      is to enter a " Katastrophe"- stage a need , to preserve from ?
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FW%25C3%25A4rmerauschen
magpwr
Hi everyone,
I am curious if kapanadze coil(maybe input coil) itself needs to emit ions during kacher interrupter off state.Akula or someone had mentioned about this few years ago but information stored became fragmented. :'(
After watching Tariel first video taken from bedroom and Akula older device.I noticed that both devices operated from high dc voltage after rectified 220volts main as provided from inverter.
It wouldn't make sense to use high voltage WIMA or microwave oven capacitor after 3 turns from yoke if we are using low voltage 12 or 24volts to power the yoke or toroid.
The last time(few years ago) I tried using rectified dc voltage from 12volts to 220volts inverter using typical pwm generator without kapanadze coil attached and found out after 3..4 turns from my large nanocrystalline toroid  produce around 210Vpp.
Base on recent experiment with div by 3 circuit prev attached-Achieving higher stable frequencies from kapanadze coil after kacher was power on did not produce any high enough voltage <30Vpp to even power up a isolated A/C to dc converter.
This is something to consider why high voltage capacitor was used in the first place.
Screenshot attached from my old video to reveal voltage from 3turns  in which the toroid was powered by high voltage dc supply using pwm circuit.
https://www.youtube.com/watch?v=cGRPKNhC_TE
