IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
lltfdaniel1
So yea the extraction process is at a loss and the entire system losses energy as well.
But if you put all of the cop 3 heat extracted back and is open loop at the extraction point otherwise this potential energy gets killed off meaning that whilst losing energy the energy from the extracted heat overcomes all loses to have energy to self run and with left over energy at same time which is excess energy where with excess energy real work can be done, so it is running fully off extracted energy and yes this is perpetual indeed with this process in a way.
Like a self running solar panel that is indeed perpetual in a way, so buy the possible perhaps perpetual in a way because of my ranting about what created the universe and power to create, it is perpetual in a way because it gets that fully from energy from the vacuum, the power creation force and interacts with it, if it doesn't get killed off so yea this method of a self runner with excess left over energy is possible as well if restrictions where not in place like a closed loop circuit.
So yea the push pull thinking does not apply with how it self runs with excess energy or thinking all forces are equal which means that the excess energy bit does not comply with forces being equal which fits nicely with my thinking about power to create or what created the universe etc,
So the whole system is a loss, and the efficiency does not get in the way if you improvise to get past the bit where this potential energy does not get killed off like a fully open circuit, so the only thing it can run from is the cop over 1 which is 3.
So start the heat pump and then works and then use the extracted energy back in again and repeat the process and because energy diminishes due to the losses it will output through those losses to be able to fully self run with left over power.
See it is indeed perpetual being proven here because if it wasn't it would not work and also the universe would not exist because of power to create.
The perpetual force to get it to self run with excess power undeniably is banging on the door but with known electric circuit methods and what to do would kill off the perpetual force from being used.
This perpetual force ultimately does exist but with the way electronic circuits are done it fully ignores this perpetual force and using a method where none of this perpetual force can be used.
So if you see it as i do about heat pump self running off extracted heat with left over excess energy so from what you can plainly see here is the character of the unequal power to create force unlike what most people can see which is all forces being equal, just to help you in a way to think outside of the box.
Regarding the equilibrium where a wave of energy or hertz as it accelerates gains amplitude but is within the equilibrium which means that the power is equal and can never achieve power to create, where as the equilibrium for power to create the equilibrium well let's just say the power to create exists outside the known limits of the equal equilibrium, some scientists theory that this could be the case where it exists outside of known limits and the limits fully prevent power to create process.
Regarding the entire understanding of the equal equilibrium right means that nothing can create or destroy ok so i believe there would be a power to create equilibrium or a power to destroy equilibrium, because well if the equilibrium was equal the universe would not exist at all and if tested there would be some evidence to say there is indeed a unequal equilibrium, ponder with this as well as taking my theory with a pinch of salt.
An unequal equilibrium going at the same rate as power to create so the equilibrium it self gains power and amplitude as it accelerates and perpetually increases, unlike a wave confined in a equal equilibrium where it accelerates and gains amplitude similar really but yes.
Between fully testing all equilibrium or the balanced equilibrium there would be evidence that would mean that there is a unequal equilibrium as well as other discovery's.
If the universe was created with a equal equilibrium something out of bounds that violates the limits or laws of the equal equilibrium would be detected fully and breaking all the laws of the equal equilibrium and this out of bounds means the unequal power of it all as to how the creation process works and the power creation is the holy grail of free energy.
I think zero point was detected like that, this out of bounds power means zero because it violates the equal equilibrium fully which it was tested on and is breaking all the known laws of it as well, well both complying and breaking it same time , it is the same when detecting something that goes faster than the speed of light which also was detected but sadly scientists resign over it but would have been a game changer and a winner at same time.
I already know zero point is the backbone of power to create or destroy but scientists are clued up and do not know it fully, the nature of the known zero point is bypassing the limits of the equal equilibrium, next comes is how is that so? well it is unequal power by nature breaking the equal equilibrium and if discovered further will discover the perpetual power to create or destroy in that, because zero is a wave bypassing the impossible to break equal equilibrium simply put, and is a alien different breed of energy.
As the zero point wave propagates further in a balanced equal equilibrium meaning it is not confined to all the laws of energy of the equal equilibrium but bypasses this, the wave of zero point propagates further because it is unequal power within a equal equilibrium and this is how it generates power or what created the universe and is perpetual.
The way the potential energy which causes zero point to propagate further is because it is unequal perpetual power which created and powers the universe and it is where all energy comes from because zero point is the backbone of creation and is behind every single creation and if zero point can't create it self then the universe would not exist in a equal equilibrium, so if the big bang that created the universe happened in a equal equilibrium the universe would not exist, because it can't create it self in a equal equilibrium, because the equal equilibrium is cannot create or destroy and this foundation cannot be rocked whatsoever but the nature of zero point would rock it fully with proof it bypasses the equal equilibrium.
Regarding that equal equilibrium it would both be possible and impossible as in confined in the equal equilibrium to break the laws of energy within the equal equilibrium, because the zero point propagation wave shows it won't stop expanding they have to stabilise the circuit by cutting the potential of this energy fully so it cannot well behave as it does in a perpetual nature, where if it bypasses you would not need to, the perpetual nature of it causes it to have no limit as to how much this energy expands, it is unlimited and perpetual indeed by nature and within it's ability to be unlimited they might just find the key of unlimited power and discover it's perpetual power because as it expands within the expand process a unequal perpetual force would be there.
Zero point it self will never measure equal equilibrium because it violates all known laws of physics that corresponds with the equal equilibrium but if it did this force won't be called zero point, and that is due to the perpetual nature of it.
So if scientists with their science equipment that can detect speeds that go faster than light then the same can be applied to the measurement of zero point in various factors and somewhere will pinpoint the unequalness of it which breaks the all known laws of the equal equilibrium, i would say to them that they have found a unequal perpetual power to create force which is the backbone of all creations and is the holy grail it self.
Hopefully does not get suppressed.
Either way to me regarding the self running heat pump i am on about, this is translated everywhere in the science world where devices solely run off extracted energy with cops greater than 1 but the efficiency and overall design losses energy every way but the cop greater than one overcomes all these losses all together and works as a self runner with excess left over unity energy but in a wasted manner because that is where the power torque or work can be done and can be possible to work fully.
So like a self running solar panel in everything, see it that way and it would be easy to understand and work if they can make it work but is not impossible though.
Yep running like a self running solar panel, running off cop greater than 1 which sustains and gives left over excess power to fuel a load even with all losses which don't prevent this process just a lesser cop but still over 1 when energy exits from the circuit self running as well as excess energy even with the supposed efficiency which prevents this fully but no because you need to do nothing about that as in the energy process it solves that, either with a zero point device that harvests subatomic energy in that manner or a heat pump which is what i was on about with heat, exact same principle with the self running heat pump i was talking about but with zpe subatomic interaction all of this, same principle but with electronics etc, the whole system at a loss, but the cop greater than 1 enables it to self run with a loss and with left over energy at a loss to power a load and actually work like that which is a self running solar panel with excess power in the process and yea it is indeed perpetual in a way because it gets its energy from zero point or power to create or the perpetual process.
Dan
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
The energy dissipation it self at the heart of it where it causes the circuit to get hot is ultimately not caused by a equal force where all forces are equal, but is the opposite of equal and thus causes the circuit to get hot and leads in a unbalanced unequal perpetual state going all the way down to zero point it self, and in zero point it has that perpetual power, i mean it was thought zero point had no energy but it does, and if you yank it or cause a vibration etc , it will cause energy to appear and be extracted within the vacuum it self whether balanced or not perpetual or not it will cause the vacuum to vibrate and get energy maybe getting the energy created by a perpetual power to destroy which is hot and is what zero point so where on earth would the energy come from if you cannot create or destroy and if all force being equal if it was all forces being equal you would never get energy from the vacuum whatsoever but was ultimately proven in science that energy does come from the sole power of zero point so yea meaning from a self powered perpetual state of energy where it is the back bone behind it all and returns back to it, meaning what i have said about all my rantings about power to create or power to destory, it self generates giving more out than in which is power to create or negative electric or power or the dead opposite of that is power to destory.
Every time you cause energy to be extracted from the vacuum every time you do that activates the perpetual power at the same time and due to the perpetual power it enables power to be extracted from the vacuum/zero point with whatever method, the perpetual power it self when active enables energy to be extracted from vacuum/zero point, if not then you can't extract energy from vaccum/zero point.
The perpetual power nature of it, is the catalyst or key which it self enables power to be extracted from the vacuum whether the extracted energy is equal or perpetual science with its non perpetual thinking thought it had no power which is dead opposite as to what they have found, it ultimately does have energy.
So getting energy from zero point is getting energy from the sole perpetual power of it in whatever form i.e. balanced equal force where all forces are equal or not unequal force.
It can be hot or cold, as in hot electric (unequal positive perpetual power to destroy where all circuits get hot) or cold electric (unequal negative perpetual power to create where all circuits get cold) regarding energy dissipation the momentum or potential of it is perpetual.
For one the collapsing field technique right is utilising the perpetual power process the collapsing field is unequal perpetual nature based way to get perpetual power, like in the same way you vibrate the vacuum to gain energy which is established in science and works the same way regarding the casmir effect, the only way it can self run with excess energy is the self running with excess energy heat pump i am on about regarding the cop over 1 regarding the collapsing field technique and forget the limits of efficiency it wont disable this potential to self run with losses with excess energy with losses so design it that way.
The collapsing field of course will draw energy from the environment and is indeed perpetual in a way because of the laws of energy converting or conversion which does not add in as to what created the universe and the way this converting conversion law works means that is wastes the energy in the process where as if you did not waste it will be banging on the door of negative cold electric power to create force , the collapsing field enables it to tap into the vacuum and it externally gets rescued and externally put back in to save it from the conversion/conserving law effect and this conversion or conserving law effect is different between a closed loop circuit where it cuts of the extraction ability or open where it does not cut off the extraction ability so with negative perpetual power to create cold electric the same can be applied to work fully, in a parallel fully open circuit which enables the energy extraction but then comes the problem of negative power to create force so it will enable it self to self run with excess power which can be done just like the problem of efficiency preventing it to self run with excess power which can be solved and i already know and in same way to allow negative power to enter so with power externally saved before the potential gets cut off right which will bang on negative cold electric power to create ok before it does it gets fully rescued and then externally put in again, this is all part of reusing the energy which recycles and the potential bangs on negative energy so with external energy put out then in, it harvests that energy to give it potential which it does and would exceed in power which is negative again so the circuit has to be parallel path fully open looped system so it does not get cut off, exactly the same with the self running heat pump with excess power or a self running solar panel with excess energy powered by the power to create force which created the universe and is negative cold electric power with losses every in the circuit and the losses in the entire circuit can't cut off the potential perpetual power to create energy anywhere which is cold and negative and alien at same time because the circuit is fully open and parallel at same time so it will work same with the self running heat pump with excess left over energy as a self running solar panel with a perpetual process.
So if you manage to achieve a self running solar panel with excess energy, with the whole system at a loss, like the heat pump i am on about, it is perpetual in a way and the potential this the perpetual force will be there and is an alien negative power to create energy right out of the box, so if you understand positive hot circuits it will be hard to understand the opposite equivalent of this and the electronic parts needed will be hard to get due to understanding of electronics etc which is parts designed for hot circuits not cold.
So yea regarding energy dissipation, this energy dissipation whether it is hot or cold, exists in a non equal perpetual equilibrium unlike a non perpetual equal equilibrium where every person understands so to understand better this better is wave propagation and how this force manifests, especially working out wave propagation with energy dissipation and maybe just find the key of perpetual power.
The way i see the casmir effect is it can be adapted to run solely off extracted energy with left over energy which is excess energy (and this excess energy potential is negative unlike where every circuit is hot and wastes energy)and i view the casmis effect device to be working like the same principles of the overunity meg device and it works fully like a self running solar panel with excess energy exactly like the self running heat pump i am on about and the excess energy potential is negative power electric (power to create) like the heat pump, if they ever find waves which they can to achieve this with the wave length, i mean studying the wave length of the self running heat pump with excess energy which is negative and they have to find that negative power to create energy for that to happen using the power creation process that created the universe which is fully alien negative energy.
You can clearly see the potential of the cold negative electric(power to create) force within reasoning thinking that a cop over 1 can indeed self run with excess energy so there you go, negative energy banging on the door and this is one way out of many to tap negative cold energy/electric unlike the opposite hot circuits and i believe that both hot or cold energy dissipation is incompatible with each other but take that with a pinch of salt.
Even if the potential of cold negative electric(power to create) force which is hard to understand is likely to be interpreted as some alien force and with current understanding of hot heat electrical dissipation, so the potential is undeniably there which is the cold negative electric(power to create) force and is trying to manifest in your circuit so it really does exist as that despite not manifesting could be interpreted as a unstable phenomena where the potential is polar opposite compared to a hot force when this is polar opposite cold force, the current understanding of laws of energy is not fully complete.
lltfdaniel1
I think single wire transmission is the key to tap into energy much more easy to understand.
Not much is known about single wire transmission well not to me anyways.
You could tune single wire transmission like a radio to suck in energy to whatever source of energy be it earth etc and the return i think will obviously harvest energy coming back in.
I think Tesla himself intended to use the simple physics of the single wire transmission to tap into energy sources and the process will indeed gather energy and suck it in the process.
Instead of thinking of using something else that is not single wire i think tesla did not treat it this way.
Using single wire transmission will solve a lot of problems and the dream of free energy is better accomplished this way, this single wire transmission works like an energy pump tapping into whatever source of power when it returns back to the single wire because it is open loop half in and half out.
Electrons attract electrons simple to understand with the single wire transmission and putting that energy into earth will do just that with single wire, it is like tapping into electrostatic of the earth which can power many city etc.
Or tapping into wheel work of nature via single wire transmission simple to understand.
If you apply single wire physics into everything then free energy devices will be much better understood so take that with a pinch of salt but yeah.
It would tap into the invisible electric network of the earth with invisible moving stator's and the like which is the wheel work and it in harmony with single wire transmission.
We need to know the full physics of single wire etc, because i can see that it has big potential to set us free from oil gas coal etc,
Yea big potential and very realistic free energy extraction and the like.
In the world of free energy all the designs etc, if it is not possible that it will run and exhausted every option, just apply single wire physics to it then it will be much more understandable.
Like a open ended receiver where you input energy and get energy out via single wire, and this way you have tapped into whatever energy source because energy in causes energy extraction and then outputs all of that and can self run with excess power at same time within the circuit that is, just like this self running heat pump with excess power and this does not break any known laws of energy at all really.
The limitations of electric is i think overcome with single wire physics and enables power extraction much more easy.
Dan.
George1
Hi IItfdaniel1,
Hi Dan,
Thank you for your reply.
You are obviously an educated person but you have written a whole textbook, my friend! :) You really tell us many interesting facts which are true by themseves but which are not related to the present topic however. Please focus on the topic, if possible.
Looking forward to your answer.
George
lltfdaniel1
Thank you yes, i could not help my self.
Anyways i went on about that because giving food for thought, to discover possibly how this alien energy works which is power to create and how it behaves because it isn't a well known source of potential power but is would be easy to identify what it is with simplified physics.
I might be wrong but, scientists believe zero point won't go beyond zero point, if that was the case then the getting energy from it is impossible, no? - this confirms in someway that i am correct > https://phys.org/news/2019-10-quantum-vacuum-energy.html this energy is a different kettle of fish because zero point is sustained by positive as in positive to positive perpetual that is fully frozen as it amounts to zero and cannot self perpetuate on it's own and idle energy transfer and fully positive to positive.
What i am trying to say regarding nature of zero point, is that positive follows positive, and is fully positive with nothing negative in it what so ever, unlike conventional electric where positive follows negative.
But if it comes in contact with negative energy then it cannot utilize the negative energy whatsoever (but for it to go beyond zero however it has to interact with negative and this is the only way of doing it as in techniques of communication between positive and negative and must be explored) because the nature of the energy with this cannot be positive follows negative it ultimately does not work like that if not then science would be able to get energy but have not, even super intelligent extra terrestrial ruler of the universe will agree as to how incompatible it really is, even he would have great trouble with it as in trying to get it to work etc but then if quantum mechanics energy interchange works between the positive and negative forces then there is a possibility (incompatible because when positive collides with negative this is the only process i know of same way it causes it to go under zero)because energy does actually appear to zero point but there is no known way as to how to get energy from it, as in getting energy solely from zero point, but if they identify negative energy then they would make some progress to tackle this hard reality because the energy that appears to zero point (energy that comes and goes out of existence which comes from the negative)is coming from the negative incompatible force obviously so in some way mainstream science knows about negative energy which is power to create and its energy dissipation is cold unlike hot circuits that most of mankind uses.
I whole heartily do not recommend going beyond zero because the understanding of zero point or quantum mechanics, zero point is the ultimate prison for energy and i am right about that.
I with my theory i think it goes beyond zero point in the process gets energy interaction (where both negative and positive cannot collide in a way where positive and negative in electric circuits and create a anti lenz force so in that way)that way in a perpetual way when negative collides with positive it causes some interesting effects, take that with a pinch of salt but has to be tested, i believe it that zero point is positive explosive energy perhaps and the dead opposite is incompatible with it which is the negative opposite equivalent of it, and the way it gets energy regarding zero point gets it from the perpetual power to create where as zero point is power to destroy and thus incompatible but vibrates in a perpetual fashion against the negative implosive energy.
The perpetual power of zero point which is hot explosive positive power to destroy energy, cannot perpetuate on it's own (because it is a mimic of a force) and if it can't then energy from zero point is impossible and this is what science fully believed in the first place, so it has to get the perpetual power from the negative power to create force by vibrating the dormant perpetual power of zero point it against the perpetual negative power to create to get it to perpetuate and thus get energy with the inter exchange of energy between positive explode zero point and the incompatible power to create.
So when the two incompatible forces vibrate causing a perpetual effect, within the inter exchange of energy where it cancels each other in a way just to make it easier to understand out actually causes a perpetual effect so negative and positive can work like that and all other unknown methods just like that, instead of getting no energy regarding cancelling of positive and negative regarding magnets (regarding anti lenz law effect) but if you do this with zero point positive and power to create negative instead of cancelling each other out due to the nature of zero point would actually create a perpetual effect indeed well the effect ultimately would have caused something for sure unlike being completely landlocked because zero point is the ultimate prison of energy.
The energy potential of going below zero is a fully perpetual effect, if all energy being equal then well it would never go below zero.
So change of subject, regarding broken symmetry from http://www.cheniere.org/references/brokensymmetry.htm is crucial to enable the solar panel effect but instead of the sun but receiving energy from the vacuum like the sun, and if you excite energy in this manner regarding broken symmetry it would knock on negative energy power to create potential and work like a solar panel but with that potential.
So regarding zero point (positive power to destory) and the (negative power to create) like when two forces cancel each other out regarding electronic magnets, but with this different kettle of fish where the nature of beyond zero is fully a completely unequal force that breaks the all forces being equal right in the bin ok science that treats the interaction between positive and negative right, they cannot do any energy interaction because they do not believe in perpetual power and are using the converting or conserving energy and they can't get anywhere with that regarding understanding the sole power of zero point.
Anyways,
I can't add anything to the current topic so i will be quiet now,
Dan.
