IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
George1
Any comments related to the basic Bessler's wheel concept?
lltfdaniel1
Well people would think friction would make it not work but if it has a spike of precision torque then it can work all the time even with friction, but if there is a load then it will not work, it only self sustains it self.
People know that spins of atoms alone would correspond with the Bessler wheel it self, so i view this wheel to abide by with the spin of an atom.
If you can reverse engineer how motion works then i know it can work.
I do have faith in these sorts of ideas regarding Bessler wheel by looking and reason with the obvious but the bit where it gets baffling is understanding each process.
You have to know how the atom alone can spin all the time and then apply the process idea to the bessler wheel, when i mean that processes that self sustain the atom is going to be alien with the way we know electronics because there are signs of no energy dissipation etc with what maintains the atoms spin, so if the atom can spin then this bessler wheel can spin round and round as well which would never stop.
Also the atoms keeps on spinning where there is electric resistant and all of the losses it still spins which is the atom, so what is going on, but again baffling to understand the detailed physics.
Argument or not the obvious is how the motion of the atom does spin, reason with that and why it is unaffected.
If the atom and electron is not supported by a perpetual source then why doesn't the atom or electron get wasted as in how nothing is perpetual and gets consumed away, if does not so there is an opposite of non perpetual which is perpetual, how can the electron survive and not get wasted, these are obvious signs and can be translated into the bessler wheel etc,
I am open to reason and want to hear why it wouldn't work.
Anyways use Ockham's razor reasoning and apply it to never ending spins atoms and everything else,
Occam's razor, Ockham's razor, Ocham's razor, or law of parsimony is the problem-solving principle that "entities should not be multiplied without necessity", or more simply, the simplest explanation is usually the right one.
https://i1.wp.com/marketbusinessnews.com/wp-content/uploads/2017/10/Ockhams-razor-image-with-explanation-and-example.jpg?w=925&ssl=1
So the momentum of atom spin never ending translated into bessler wheel, things behind how it spins more importantly.
Ultimately is possible to have a seemingly perpetual element powered device i say, just copy how the atom spins and all of its unknown and know processes, you may end up with a device that self sustains it selfs and the more you know maybe just maybe power a load if you can see past the sustainable process, but again the detailed physics will be baffling.
I understand if mastered with how the atom spins and you apply it, it will eventually slow down and stop very understood but there is a way it can run and fully work even with friction.
I know why it would slow down and eventually stop but to solve that sort of problem there ultimately is a way for it to work and never stop spinning any educated person would know how to do exactly that, because it has a by process in friction and will not stop.
Very easy to think why it will slow down eventually and stop but i know there is a solution for that, even as what caused it to slow down and stop.
Dan
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
George1
To lltfdaniel1
Hi Dan,
Interesting analysis, dear colleague. Need some time to consider it carefully.
Regards,
lltfdaniel1
Quote from: George1 on February 23, 2021, 08:37:33 AM
To lltfdaniel1
Hi Dan,
Regards,
Yes, your welcome, with your time to consider then consider the perpetual motion holder > https://leedskalnin.com/LeedskalninsPerpetualMotionHolder.html
