IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
https://www.youtube.com/watch?v=xX14NK8GrDY
The link above clearly shows how a few simple experiments, carried out in your garage, (1) can be the basis for designing of a simple mechanical reactionless drive machine and (2) can solve your personal energy problems (as well as the energy problems of the world as whole).
Let us popularize the link above as much as possible in internet (and anywhere else and in any other way).
LET US PUSH FORWARD TOGETHER THE TECHNOLOGY PROGRESS!
George1
EXPERIMENTALLY PROVED reactionless drive and perpetual motion are described in the link below:
https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe
The link above describes a few simple reactionless drive and perpetual motion experiments. You can easily carry out these simple experiments in your garage as many times as you want.
Looking forward to your opinions, recommendations, questions.
nix85
this is not the best thread for this but it's ok. i mentioned this superposition OU
principle before, there was a study in russia that claimed experimental confirmation
principle is logical, energy content of the wave is amplitude squared
if we add two same waves together, that is, superimpose them,
amplitude will be double, but energy is ampiltude SQUARED
so energy is now x2 squared or x4
here is a copy past of whole article from keelynet
https://keelynet.wordpress.com/category/gravity-control/page/4/
Free energy from wave-fields
Posted by keelynet on September 9, 2010
There is an engineer in Hungary Janos Vajda who dedicated his whole life to the science, specifically to the microwave technology. He worked with radio locators mainly for the military forces, and had several inventions in the field of microwave technology.
Since many of his measurements proved that the energy preservation thesis is not generally valid in wave-fields, he started to seriously research this "unbelievable" phenomena also from theoretical point of view, to see where is the mistake in the official scientific approach that upholds the validity of energy preservation under all circumstances.
The title of the study written by Janos Vajda is "Violation of The Energy Thesis in Wave-Fields ". Since primarily it was meant for the people of science – as an exact scientific paper – it contains a lot of equations, which might discourage many people from reading it (since for its understanding the knowledge of higher mathematics is required).
But even if you can not understand the mathematical demonstration now, it is worth saving the complete study to your computer for later reference, as it has great scientific significance which will become evident only later. You can use it as a scientific evidence about the invalidity of the energy preservation in wave-fields, and as a firm base that justifies and urges further investigations in the field of free energy research. It is enough to read the explanations and very important conclusions (leaving the mathematics aside) in the study, to get a picture about the essence of the discovery.
Mr. Vajda has invented a free energy device based on these principles and a patent application has been filed (Title: APPARATUS FOR GENERATING AND UTILIZING SURPLUS ENERGY BY MEANS OF ELECTROMAGNETIC WAVES, Number: P9601424, Application filed: 05/28/1996). If anyone wishes to invest into the full development and utilization of that invention, (or into book-format publishing of his study) please contact us.
The basic principle of deriving free energy from wave-fields can be understood even without higher mathematics. If we would have to summarize the essence of Mr. Vajda's discovery in few sentences without maths, the following explanation could be given:
When two waves with identical polarization, frequency, phase and amplitude propagate in the same direction and meet (and merge) in free space, then their amplitudes will add together and the amplitude of the resultant wave will be double that of a single input wave. This physical phenomenon is called superposition or interference of the waves, when (under the above conditions) the amplitude of the resultant wave is calculated by simply adding together the amplitudes of the incoming waves.
The energy content of a wave is directly proportional with the square of its amplitude. This fact has a profound impact on the energy balance of the wave-fields.
Calculating the energy balance of the above example, we get that if two units of energy enter the system, then the energy of the output resultant wave will be (calculated as the square of the resultant's amplitude, that is) four times that of one single input wave (and not only double). As we see, two units of energy enter the system and four units leave, that means we have gained two times more energy then what we have feed into it. If we take two units of energy from the output and feed it back into the input, then there are still two units remaining for utilization and the process can go on continuously.
A further question is that if an excess of energy appears, or an existing energy disappears as the result of the interference of waves, then from where does it come from, or to where does it disappear? In the case of longitudinal waves propagating in a medium one might imagine that the excess of energy is derived from the heat of the medium and the energy that disappears is transformed into heat (although this is not the complete truth).
But the case of electromagnetic waves is a bit more mysterious. If we stick to the idea that when the electromagnetic waves propagate in vacuum, in that empty space there is no medium, then there is certainly no explanation for the question. But if we suppose that there is a medium that fills even the vacuum, which might be called ether (it does not have to be a static medium), then we get some base for the explanation.
If we make a positive feedback, then the initial external energy source can be disconnected from the apparatus without stopping the generation of free energy. Naturally the divider and regulator should feed back enough energy to continuously keep up the process and also to cover the losses in the feedback loop. The schematic illustration of the process is shown in fig. 2.
Although at first sight the less than 50% of energy gain of the interference chamber seems to be unimpressive in our example, with such an arrangement the maximum available output energy is limited only by the energy conducting capacity of the parts.
After starting the device the input energy source can be disconnected, and the energy generation process will be self-sustaining. During the startup process the regulator feeds back more energy to the input then what has started the amplification cycle.
Consequently the amplitude and energy of the wave circulating in the system will continuously increase from few watts of the starting input to the several kW to be utilized at the output. Since there is no further need for input energy, the coefficient of performance of the device will be infinite. The level of output energy can be adjusted through the regulator, and it does not depend on the strength of the starting energy source.
While few watts of input power can start the process, the device can provide several kW of power continuously at the output, even with the external starter energy source disconnected. Using sound waves in practice it might be difficult to achieve noteworthy outputs, since the practical limit of energy density is quite low in such arrangements. But using electromagnetic microwaves it is possible to make very efficient, relatively cheap and compact devices, without any moving parts.
The output of such generators can vary from several kW to the range of GW depending on the size and types of the components. As you can see, this is a real free energy principle that works, and it has been confirmed by measurements and scientific analysis.
It is based on the law of interference and on the equations for calculating the energy density of a wave, that are already accepted by science. No new theory has been created, only the existing knowledge clarified and interpreted in the correct way, and its possible new applications suggested. / In 2009, Dr. Janos Vajda, Founding father of Energetics in wave fields, passed away in Budapest, Hungary.
Please note that these over unity devices almost all of them work based on constructive interference. This means that you emit EM pulses from a minimum of 2 places and phase their interference in a way (superimpose) that excessive energy is extracted from the ether during the interference called interferometry.
Basically, this means that there is no free energy since the device simply "nicks" (extracts) energy from the sorrunding environment by applying constructive interferometry in 3D space.
nix85
also
A quote from April 1993 Extraordinary Science;
"There is a second kind of RF (radio frequency) produced which appears as a stair-step waveform. The frequency of this RF energy seems to be related to the time required for the energy pulse to travel through the entire length of the copper coil. The second kind of RF is somewhat mysterious and is, as yet, largely undefined.
According to oscilloscope measurements made by Dr. Hastings and Mr. Hartwell, the generation process appears to operate in a laser-like fashion in that the wave front of the energy produced seems to BOUNCE back and forth through the length of the coil winding, with the amplitude of the energy pulse GAINING additional energy with EACH BOUNCE through the coil."
