Free Energy is IMPOSSIBLE without this, why everyone fails!
Started by aether22, July 24, 2018, 12:32:48 AM
marathonman
A standard generator would be OU or self sustaining if it wasn't for the cogging effect from the Lenz Law pulling the rotor back into register.
when the system is up and running the primary draw is reduced to just the IR2 losses. part of the secondary is fed back to the system to maintain the field. the amperage to the primaries is still being circulated through the exciting system but not being used by the primaries.
the electricity is the Aether pulled from counter space dimension caused by the polarization of the primaries. the whole free electron in the copper wire is the biggest joke of them all. if you pull electrons from a copper atom then it becomes NOT copper.
generators are Aetheric accumulators pulling in electricity that is basically a pressure system. this is brought on by the polarization of the Aether as magnetism cancels out two dimensions of gravity leaving one dimensional electric flow from counter space into space. when a load is presented to a standard generator the current is increased to the exciters until the output is producing enough for the exciters and the load. that is the pressure in the system is increased until it can maintain the exciters and the load. it takes time for the pressure to build up as in a few seconds. Aether pressure from counter space.
the whole key i think for OU is to preserve the power to the primaries as in recycle the energies and for opposing primaries. if the losses to power the primaries are reduced to just the IR2 losses them you are well on your way to an OU device.
a standard off the shelf transformer conforms to the conservation of energy but the motional electric field does NOT as it is non- conservative therefore if one was to use these principals a device can and will provide the power to it's self and the load once started.
preserve the power used to the primaries not expend it.
Regards,
Marathonman
AlienGrey
Quote from: marathonman on July 26, 2018, 05:26:42 PM
Regards,
Marathonman
That's not really true the thing you refer to as a generator doesn't generate any thing it's a contradiction in terms !
it's a device that generates BEMF and forces + and - potentials further apart the heat is produced by the BEMF and the way it is internally wired make some electronics to make it more efficient and your in business.
aussiebattler
Faraday's law of induction is a basic law of electromagnetism predicting how a magnetic field will interact with an electric circuit to produce an electromotive force (EMF)—a phenomenon called electromagnetic induction.
aether22
Pretty words marathon man, but there is no truth to them.
Generators are MOSTLY explained correctly by convention, by Lenz Law.
There is however a degree of truth, electricity is not a flow of aether, it is a flow of valence electrons (or ions outside of metal) due to either a change imbalance or due to an EMF, and an EMF is like an electric field/force that pops into being due to some change or movement or time varying nature of a magnetic field.
Curiously this EMF exists as with Hooper-Moonstein even where the magnetic field is not detectable because it sums to zero, but it turns out despite summing to zero magnetic fields still exist, this is also how a transformer works despite there being potentially no detectable magnetic field where the secondary turns are.
Now, there are some clever ideas like that of the MEG and switched flux paths there it seems maybe Free Energy should happen, but it never seems to, but I digress, it is however hard to analyze these systems.
Fact is, conventional physics accurately and almost completely explains most things to very high degrees of accuracy, even to parts per million!
Free Energy does not just happen, and when it does happen there is more that just Free Energy going on, there is almost every time other anomalies observed!
Ok, so back to generators, you see there are a bunch of ways that generators can involve the aether, this is a secondary current, it can be generated by a generator and it flows though a wire, and it can even be sort of like electricity, this stuff often won't read on a meter, sometimes it seems loads can actually burn this stuff, but most of the time there is too little of this stuff to do anything.
And it is this aetheric current, this radionic like energy that flows through the wires, can easily flow out the end of a wire because unlike electrons that move slow, this stuff moves like a high speed fluid.
You description is somewhat fitting for this.
And it could be that this energy somewhat increases the efficiency of motors and generators.
marathonman
You; "Pretty words marathon man, but there is no truth to them."
Me: you have absolutely no clue what so ever as to the truth.
Me; the electricity is the Aether pulled from counter space dimension caused by the polarization of the primaries.
You; "That's not really true the thing you refer to as a generator doesn't generate any thing it's a contradiction in terms."
who said anything about generating but you. it is YOU who is wrong and stop putting words in other people mouths and read what they say not what you thought they said. it is you that does not know how a standard generator works. they are Aetheric pressure systems all day long.
You; "Generators are MOSTLY explained correctly by convention, by Lenz Law."
Me; WRONG again and not even close. living in a fantasy land explained with incorrect assumptions.
You; "it is a flow of valence electrons (or ions outside of metal)"
Me; Completely wrong again. typical Dogma taught College School BS grasping for straws handed down from generation to generation.
You; "Fact is, conventional physics accurately and almost completely explains most things to very high degrees of accuracy"
Me; OMG !  i can't stop laughing, that is like watching Feynman explaining a magnetic field and squirming on a hot pan.
"Faraday's law of induction is a basic law of electromagnetism predicting how a magnetic field will interact with an electric circuit to produce an electromotive force (EMF)—a phenomenon called electromagnetic induction."
WOW ! now i never would of thought of that if you were not here. thank you so much and thank you for sharing.
Not much learned here but very comical though. needs a few more years to ripen.
Regards,
Marathonman
