Free Energy is IMPOSSIBLE without this, why everyone fails!
Started by aether22, July 24, 2018, 12:32:48 AM
e2matrix
I believe the aether or zero point energy or whatever you may want to call it may be important in tapping OU.   Given your experience and research into the aether have you built anything that can be considered OU or COP >1 ?   While I find the possibility of 'feeling' the energy interesting as I have been sensitive to such in the past I consider it still a very subjective thing. I would only be interested in building something if it could achieve a usable energy level - even if it is to just power an LED light.   Suggestions?
aether22
Quote from: e2matrix on July 25, 2018, 02:21:01 PM
Hi e2matrix...
So no, I don't have something that can light an LED, but that is because I really have not tested this to create Free Energy.  I don't tend to do experiments with electrical energies.
The why of that is that I mostly want to focus on the aetheric side, and as soon as I have to make electric circuits I have a complicating factor that can interfere and and has different requirements, also it slows things down, also I don't like the feeling of the energy as much, at least until I found that electrons were eating up the negative energy, basically the moving electrons recombine that energy as they flow.  This can be easily fixed i have since learnt.
Also, MOST of my experiments have not been physical at all!  A lot have been images, because the principles of aetheric energy are somewhat (but not entierly) invariable to the energies used to embody them!    So I can make unpowered circuits with wire fast, images faster.  but electrical circuits where I have to worry about both disciplines much less.  And for what it's worth, as much as I like the idea of Free Energy, I am much more pumped for Antigravity and that is my true focus.
Oh, and finally, failed experiments bum me the fuck out!  If you don't try you can't fail!  I know that is super lame of me, but the great thing about experimenting with the aether is that I can feel what is happening so it never occurs as a failure, and failures teach me a lot too as I get great feedback.
The problem with seeking Free Energy is often it just "didn't work" and there is no real feedback other than that.
At any rate, I understand you would rather I had something empirical to show, something that seems a bit more obvious, but the thing is if it could only faintly light an LED it would likely be of little use, this stuff is as often as not all or nothing!   It either works fully, or doesn't, if something is weak seldom has that sort of thing been upscaled.
So no, I can't give you something that can create a reliable physical effect, because I have done few experiments that do such.  Physical effects have been...
#1 a few experiments have lead to glass breaking without conventional cause (nothing touching it and synchronized to some action), and not by chance.  I have not sought to replicate this.
#2 Some images have caused monitors to play up, but not that reliably.
#3 Healing.
So, it just so happens that the experiments with broken glass used physical energies, magnets or chemicals and batteries, most others have not used any energy.
The healing makes sense, massive healings have taken place and bio-energy is the main energy around these things.
So what I have found is that if you want a certain effect, the energy you use should be related to that, so don't expect electrical energy without using electromagnetism.
So Free Energy would not have been possible with hardly any of the experiments I have done to date.  Also I have found that aetheric bandwidth is critical, meaning you want a wide range of aetheric energies to create a more complete effect.
And if I had Free Energy working, I would not be sharing it here, I would share it with the world in some way that cannot be stopped.    If you aren't interested, that's fine, but I am coming here because I think that I have techniques that could trip stubborn devices with FE potential into operation with little cost and effort, it costs nothing to try.
stevie1001
Ok. I am in.
Eather22, tell me the way you experienced that energy.
Lets go from there.
Maybe we can find a way to make something work.
best regards
loner
Joule thief can power 1,8v led with a 1,5v battery using magnetic back emf.
aether22
Good!
Ok, so the first the first thing, there are 2 ways to do this...
One is I could tell you techniques to use, and you could apply these techniques to promising Free Energy circuits, maybe ones you made before that didn't work as expected, and see if they now show any signs of Free Energy, or any signs of anomalies such as cold currents, arc's at strangely low voltages and the like.
The other thing is you could see if you can feel the energy, this is not necessary, but it will be a HUGE help!
If we want to focus on that possibility first, then you could consider either trying to feel energy from an image, yes, I know that sounds weird, but it turns out light can do more than just burn circuits into silicon, it can burn circuits into the aether that it manifests in, quite reasonable when you think about it like that, light can also push matter around and start fires, so it is more physical that we tend to think.
The other thing is you can make a coil, this has even higher odds of working, or should have but everyone is different, still I have fund some people that feel energy from images and not from coils.
So if you want to do either one, go to the Aether transformer/inductor thread where there are instructions on both, the best version of the image is not in the first post but further down.
If you want I can email you also.  feel free to pm me, just be aware the message might be wiped out before I get to read it if Stefan finally updates the forum.
