Pulsing an iron-core by running electrical-current through it ?
Started by postingsite, August 07, 2018, 10:33:20 PM
forest
Po you have very good thouthts been there saw things but its limited by the money you have and support. IT ends always the same
marathonman
I am wondering if you have considered putting the iron on the outside of the coil as Walter Russel has stated many times that man winds his coils wrong. i think Bob teal used this technique in his magnetic motors and was the reason they were so powerful.
only tests will prove otherwise.
AlienGrey
How do you bend quarts it's like glass, let alone mount it in iron ?
marathonman
And your contribution has WHAT ? to do with his project. hes talking about coils on a core so what planet are you on AlienGrey.
Regards,
Marathonman
postingsite
My previous post had 4 suggestions,  of possible simple  power-amplification-methods .
- One of them a solid-state-self-powered-generator idea .
Another self-powered-generator idea could be,  a motor( motor-1 ) turning another identical-motor( this one to function as generator ),  and then  add  permanent-magnets to  motor-1  to make it more powerful,  and spin faster .
   When you add  permanent-magnets to a motor, you not only increase it's torque output, you also increase it's speed .
How to get this design running -
  The simplest solution to make this device function would be :
       -  First,  power motor-1 ( which is intended to rotate the generator ) by using an  'external power source'
       -  And then,  when the generator is generating power,   gradually mix the output of the generator with the current of the 'external power source',  and then gradually decrease the  'external power source',  until the device is self-powered
   THE SIMPLEST WAY TO DO THAT
    -  This could be as simple as two variable-rotary-resistors/potentiometers, connected together via two cog wheels,  so that when you increase one, you are also decreasing the other,   their combined output-power going to motor-1 .
