Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
gyulasun
Hi erfandl,
From your description it comes that the charging battery cannot feed your inverter + the 3W LED because the charge it receives from the circuit cannot make up for the discharging process the inverter + the LED represents.
Whether this is a problem in your circuit or not, this cannot be said for sure, there is certainly one thing you can improve in the circuit: replace the bolt cores of the coils with ferrite or laminated cores, to minimize eddy current losses.
But this may still not solve this problem, unfortunately.
I would suggest the followings: if you have not done so, check with a DMM the AC output voltages of the individual 'blue' coils one by one to see if there are more than 10-15 % difference between them. Also, check the total AC across all the 6 coils whether they add up to the sum of the individual AC voltages, this is a check also for the correct series connection of the coils.  If there is a big difference, then try to check two or three coils only at a time whether they add up correctly.
You may wish to check the induced AC output voltages of the blue coils also when you disconnect the gate drive to the 2nd IRF840 to stop it switching. Does this disconnection changes the motor RPM?
Gyula
doktorsvet
if neodymium is close to the core, the ferrite will heat up because it will saturate
erfandl
Quote from: gyulasun on December 04, 2018, 05:21:37 PM
Hi erfandl,
Gyula
thanks for reply. OK I'm measuring the blue coils with DMM and AC mode it's showing 33 volt AC for each coils ! I disconnect the coil number 8 but the motor continuous running without any changes the motor rpm
gyulasun
Quote from: erfandl on December 05, 2018, 05:08:50 AM
Well, then just check AC voltage across any 2 blue coils in series like say coils 6 and 8 or say across coils nr 10 and nr 2: if they show less than say 55-60 volts then it is not good to connect them in series because their phase angle differ and start working against each other.  If you find say 10-15 volts only across two blue coils, then try to flip the wires of one of the coils to see if you get the sum of the two, and so on.
Instead, try to use individual full wave diode bridges across each blue coil to collect their 33 V into individual puffer capacitors while they remain in series connection.  It is possible that when you try to load the DC outputs of the individual puffer capacitors the RPM of the motor will be reduced (normal Lenz).
Question: when you disconnect the coil nr 8, how the induced 33 volt changes across the individual blue coils? Does it change?
Gyula
erfandl
Quote from: gyulasun on December 05, 2018, 05:36:39 AM
Gyula
thanks. the AC voltage between the 6 and 8 coil is 1.2 volt :( I'm re wiring the motor and connecting the coil 1 and 4 to the plus of the circuit the RMP is now higher. but the AC output voltage is now 24 volt.
here is my coil. all 10 coil are winding Clockwise.
also the motor will not starting automatically. I must handle the motor with hand. also the motor rotating to both sides
