frequencies and claimed associations
Started by Grumpy, December 06, 2006, 07:14:31 PM
Grumpy
I do not know what "wierd effects" or "majic window" means, but here is a list of frequencies
* 5 Hz: Alleged sphincter resonance (mechanical)(not good)
* 7 Hz: Mass aggregate frequency (can deaggregate matter), alleged to
resonate and rupture organs at excessive intensity
* 7.5 Hz: (?) Earth magnetic field frequency, useful theta (brain)
waves frequency
* 7.83 Hz: Earth resonance frequency
* 13 Hz: Alleged sphincter resonance (mechanical)(not good)
* 46.98 Hz (use with 62.64 and 70.47) Useful for weird effects
* 62.64 Hz (use with 46.98 and 70.47) Useful for weird effects
* 70.47 Hz (use with 46.98 and 62.64) Useful for weird effects
* 305 Hz: Rife frequency to kill Lyme disease
* 312 Hz: Rife frequency to kill Lyme disease
* 345 Hz: Rife frequency to kill Lyme disease
* 432 Hz: Rife frequency to kill Lyme disease
* 620 Hz: Keely Frequency (use with 630 and 12000)
* 630 Hz: Keely Frequency (use with 620 and 12000)
* 864 Hz: Main Rife frequency to kill Lyme disease
* 2000 Hz: Commonly used Rife frequency
* 2000 Hz (plus a small amount): Alleged to cure a cancer
* 2025 Hz: Proton precession/water resonance
* 3000 Hz: (approximate) Mentioned as a Rife frequency
* 5000 Hz: Commonly used Rife frequency
* 7270 Hz: Commonly used Rife frequency
* 7870 Hz: Commonly used Rife frequency
* 8000 Hz: Commonly used Rife frequency
* 10000 Hz: Commonly used Rife frequency
* 12000 Hz: Keely Frequency (use with 620 and 630)
* 38000-40000 Hz: Magic window
* 42800 Hz: Aetheric dissociation/water resonance (water -> aetheric
force)
* 150-160 kHz: Magic window
* 180 KHz: Ferromagnetism
* 1.1-1.3 MHz: Magic window
* 388 MHz: Alleged to cause damage/disruption of humans
* 488 MHz: Same as 388 MHz, but I think it was a mistake, and 388 was
meant
* 1.057 GHz: Magic window
* 2.450 GHz: Standard microwave oven frequency, but no resonance
* Somewhere in the Infrared: Magic window
* The life energy frequency (in the near ultraviolet): Magic window
Others:
172,500 Hz
500 KHz
@5.5 GHz
Have at it...
        -Frank Edwards
dean_mcgowan
A pretty good technical link to the "observed" resonances as opposed to the theoretical resonance of the earth. Please consider this when you do your investigations as the "observed" is a beta field and I have been informed that it does not carry as much energy, otherwise it would be widely used in the geological research fields as a source for information (energy). Though if you could wrap a coil around the eath itself it would be subsantial .. this gives you an idea of the scale of input you might expect to recieve by tapping into this field locally.
http://www.tony5m17h.net/Schumann.html
bocas
 The frequencies- 46.98, 62.64, and 70.47 when mixed.
70.47-46.98= 23.49
62.64-46.98= 15.66
70.47-15.66= 54.81
62.64-23.49= 39.15
70.47-39.15= 31.32
70.47-62.64= 7.83
62.64-54.81= 7.83
23.49-15.66= 7.83
54.81-46.98= 7.83
39.15-31.32= 7.83
31.32-23.49= 7.83
15.66-07.83= 7.83
46.98-39.15= 7.83
Jeff
Grumpy
QuoteThe frequencies- 46.98, 62.64, and 70.47 when mixed.
70.47-46.98= 23.49
62.64-46.98= 15.66
70.47-15.66= 54.81
62.64-23.49= 39.15
70.47-39.15= 31.32
70.47-62.64= 7.83
62.64-54.81= 7.83
23.49-15.66= 7.83
54.81-46.98= 7.83
39.15-31.32= 7.83
31.32-23.49= 7.83
15.66-07.83= 7.83
46.98-39.15= 7.83
Jeff
well, isn't that interesting...we got work to do
if earth resonant freq entrains collector that has same 7.83 heterodyne freq...might be very powerful effect
(EDIT)
46.98 Hz, 62.64Hz, and 70.47 Hz are the 3-6-9 series of 7.83 Hz - perhaps Tesla's 3-6-9
(EDIT 2)
In mystic teachings, 46.98, 62.64, and 70.47 form what is called a Yod (10th Hebrew letter which means "Finger of YHWH")
"What exactly is a Yod? It is an isosceles triangle resulting from two quincunxes (at 150 degrees each) linking two sextile planets (60 degrees apart) to a third. When dealing with planets, the degrees that make up this configuration must be concisely 150/150/60 degrees apart but in galactic space, a quincunx can have up to 8 degrees of variation and a sextile up to three. By definition, a Yod is the handiwork of indefinable and omnipresent forces of fate that can only manifest through unconstrained stress."
This combination is also referred to as the "finger of God" in this reference:
QuoteIn the lower audible range there is a group of notes in a ?yod? or quincunx pattern, 46.98 cps and the ?finger of God? notes of 62.64 and 70.47 cps. Although not fully researched, these notes together have a strange effect mentioned but not described by gravity and acoustics researchers.
Caution is advised until further research is done, although experimentation to date indicates that the effects may be due to unusual effects on the human auditory perception system, which seems to be sensitive to these harmonics. The significant point is that one of the notes is in fairly exact octave relationship to the Schumann Resonance, and is thus a three-octave overtone.
Another reference:
Quote50-60 Documented negative effects (associated with these three frequencies) too numerous to mention. There is no correlation given with signal strength or modality used, i.e. audio-visual, EMFmagnetic, electrostatic, gravitic.
Perhaps I will try these three frequencies - with coils positioned at 150, 300, and 360 degrees.
        -Frank Edwards
Pontifex
Maybe it's helpful:
QuoteHarmonics Theory - The Physics & Maths
This page discusses the fundamentals of physics in layman's terms, showing how present theory must inevitably lead to all waves losing energy and forming harmonically related waves, the end result is a very specific detailed structure that matches the observed universe and explains many previously mysterious observations.
http://homepages.ihug.co.nz/~ray.tomes/maths.html
Greetz, Pontifex
