Electromagnetic device to create the energy
Started by activ25, October 25, 2018, 07:25:16 AM
activ25
Maybe it is a resonant circuit ... RLC on the green coil
And to replace the capacitor it is possible to use a phase angle transformer, I can use it with 2 devices.
activ25
The capacitors must realized the angle. The is to use the mechanics equation to build the analogy electric device.
activ25
I think the device must change the inductance of C1 so it is easy with the electronics: G1 can be an ondulor with variable frequency but must recover the energy and reduce the harmonics espcially if the device works at higher frequency like 300 Khz for example. It is also use a capacitor but ... the capacitor must change ! it is not a device with fixed value for the RLC circuit. And I hope the values are in the good direction when I change of the half period. For the first half period it is ok, but for the next, it is possible the device wants to increase the frequency again. I will think about that.
Note, the frequency must change in a half of period ! not in several periods. So it is very quick. To test, and without build an ondulor, it is better to use a varicap, just need to find where to place it.
activ25
I need to add the flux in return to C1. What is was important to understand: it is necessary to change the capacitance or the inductance, I mean in a half period. The best efficiency will be with the capacitance but there are for now small it is only some nF.
activ25
I simulate the transformer, the input gives nothing in comparaison with the energy inside the inductance. And in comparaison with the mechanical device it is in relation with the kinetic energy the mechanical device wins. The result change when I change the varicap but there is a limit, because the inductance are limited too. I need to change one paramater I supposed it is important at start but after not... not so easy to understand the analogy electric.
I can have a transcient energy negative (and I didn't count the energy inside the coil) but it is difficult to integrate it with my device. I used another method than the varicap.
