Finsrud perpetual motion machine
Started by hartiberlin, April 02, 2005, 11:55:21 AM
0 Members and 656 Guests are viewing this topic.
Kysmett
I wonder.  How did you employ the magnets in the armature?  What was your pole orientation.  Is there anyway you could post a sketch of your configuration?
freeenergyman2005
Picture a vertical axle supported by ball bearings at each end with a hub in the center from which four arms, each supporting a mass (brass weight with a ceramic block magnet mounted top and bottom) perpendicular to the axel and spaced 90 degrees to each other. The ramps are parallel and horizontal to each other and, as I mentioned, are off set split rings forming 360 degree helixes in mirror image. The armatures move on a horizontal plane and parallel to the plane of the ramps.
The easiest way to view the configuration I used is to visit freeenergyforever.com and open the Real Player entitled 'The case for free energy' and scroll nine and a half minutes into the video.
A close friend and engineer, Bob Bailey, told me the reason Dennis Lee stoped the armature after one revolution was not, as I had thought, to prevent me from seeing continuous motion, but rather to prevent me from seeing that it didn't have sustained motion. He was right. After every variation I've tried it simply will not maintain revolutions.
Consequently, I've dismantled the machine to use the magnets in a different configuration. Don Adsitt's site, http://www.theverylastpageoftheinternet.com/menu/adsitt.htm has hidden nothing in his videos. He succinctly demonstrates the method of closing the loop through the use of stepped ramping with a free rolling magnet over a track that is contoured to the height of the magnets; very simple and easy to build. I suppose you might say it is a variation of the SMOT device.
I had thought I would use my rotor/stator unit to generate electricity by placing an iron core coil inline to the motion of the armature. Instead, I will use the motion of a free rolling magnetic cylinder over a circular track to induce current in an inline coil; much more simple and virtually without friction loss.
Howard
vectortan
Quick thought, magnetic ramps are great and all, but to enter or exit a ramp (depending on which poles you use) any energy gained is lost. If you gain 4MPH through the ramp 4MPH will be lost entering or exiting the ramp for each and every arm you use. I would think that using an electromagnet for the entry or exit (again depending on pole orientation) to pulse so you don't lose all your inertia you gained may help solve your problem.
Furthermore, I'm thinking a set of capacitors and diodes could pass that electromagnetism onto another electromagnet for a different arm on its own ramp which would need to be timed properly, and so on until a full circle is complete (which would require a lot of arms and ramps - electricity flows at he speed of light).
Only problem with timing it for it's 'sweet spot' is it would have a difficult time working properly while it's speeding up. The triggers would need to move further away from the electromagnet as the armature speeded up, but I think the process would function properly if there is little or no variation on speed.
Does this make sense to anyone?
freeenergyman2005
Well, I'm not sure I want to start playing with electromagnets and triggers. From what I've seen of the last experiments posted, from which I posted the URL, of the Adsitt ramp the solution is purely magnetic attraction and mechanics. I was wrong, though, about virtually no friction loss; it does exist. However, the force of magnetic attraction is so strong as to accelerate despite such losses.
I am no inventor. On the other hand, I'm not too bad a tinkerer, and I like stuff I can replicate from materials available at the hardware store. Below is the URL of the stepped ramp.  The travel is from left to right. I hope it will come up for you, as I don't know how to post it otherwise. It takes Gorilla Glue to set and hold the magnets once they are stacked in close proximity like this. The videos show a magnetic button cylinder traversing a track configuration of mutiple steps, completing a circle and gaining height. I certainly don't see why it couldn't be joined as is end to end and keep running.
http://www.theverylastpageoftheinternet.com/magneticExp/adsitt/photos/topview.jpg
Howard
vectortan
I watched most of the videos from the URL you posted. It is hard to see, but the reason it can't be joined end to end is because while the cylinder magnets are 'being pulled' along the track, it is moving closer to the magnets underneath the plexiglass and you can only get so close before the magnets would be touching the underside of the plexiglass. The one video that irritated me the most was the half circle one with the pathetic excuse that they didn't have a full size sheet available to use for the experiment, when the actual reason was they did use a full circle one and there was no way they could get it to work. I watched very closely and replayed several times the 'break away' video, where it went along the track then disconnected and rolled off the end and noticed that it was actually lower in height when it was free from the magnet track. Nothing special there. No extra energy can gained from this. Even if you did get the perfect setup with no friction and it was able to spin round and round, you wouldn't be able to get any energy out of it because it would be expending ALL of it's energy just to keep going and there would be nothing special about that because an object in motion will continue to stay in motion until an outside force interferes with it. I do admit it is an impressive trick that is done with magnets, but nothing more than that.
I mean, I can lift a 1lb. rock 5 feet off the ground and let it go, it will move downward and actually accelerate until it hits the ground. Then I can take a 1lb. piece of rubber and drop that 5 feet from the ground, when that one hits the ground it will move away from the ground and fall again. Does that mean that the peice of rubber expends less energy than the rock? More? The correct answer is it expends the same amount of energy.
What I'm trying to say is that it is IMPOSSIBLE to get more energy out of a system than what you put in. However, Bedinni claims that he is utilizing an unknown form of fuel (Aether energy) for his device which from simple observation and measurements would look like overunity, the only thing bothering me about his device is that he won't let an outside party investigate it, just like that Gray guy, and that smells like fraud to me.
Finsrud, on the other hand has, and I have the utmost respect for him that he did not claim to acheive PM or overunity (he referred to it as a moving sculpture; art) and DID allow an outside party investigate it and they did find that it is expending a minute amount of energy and would eventually stop on it's own (they actually calculated the exact amount of energy it was expending to several decimal places) and everyone was and still is happy. But if you where to place it in a perfect vaccuum and put the ball on a frictionless track and replaced the bearings with magnetic bearings, it would keep going, but so would a toy top.
So am I saying we should give up on attempting to acheive overunity? No, because someone could mess up in their experiment and stumble upon a new form of energy that is abundant and exchangeable into electricity... plus it's fun to try too.
What am I working on? I am kind of in the wrong area here I see, but I am in the process of building the Bedinni motor/generator and have a few ideas to change on it that I havent heard anyone mention about yet. After reading about Tesla, I believe he figured out a way to convert Aether energy into electricty in mass quantities and was intending to build a power station for the entire world out of a warehouse until he was 'persuaded' to stop, so I do believe there is another form of energy out there that no one has been able to undeniably prove of it's existence yet, yeah, kinda like God.
If I unlock the secret and do find a way to acheive 'free energy' the first thing I will do is spread the designs to build it all over the internet before I do anything else because I don't think the oil barons and those with high stakes in electricity production will idly stand by and let me or anyone profit on something that groundbreaking, causing their stocks to drop like that 1lb rock. We do need something like that because we are all viscously addicted to electricity and the resources to make it in mass quantities are limited and greed is on the rise, plus I can't take it with me!
To those of you attempting it, I wish you the best of luck, I hope you mess up and in the process accidently discover the incredible!
Vectortan
