RUSSIAN Alexey Chekurkov MAGNET HIGH VOLTAGE ANTIGRAVITY spinner
Started by Acca, November 02, 2018, 06:58:33 AM
Acca
Here is an interesting subject as it brings in T.T. Brown effect and the J. Seral spinning magnetic disk as a combination of both.
There is some thing to this as the number of hits to the Youtube channel is very high..
Acca..
  p.s..Since the CC is enabled on his videos you might get a close English translation.
https://www.youtube.com/channel/UCzZxKT3BzBZOVVy8_YzP6Yw/videos
The technology channel from the garage is engaged in non-traditional experiments that go beyond standard science. Esoteric alternative energy is antigravity testing and attempts to recreate lost technologies not only of antiquity but also of modernity. requisites. PayPal alex_a.v@mail.ru Payoneer alex_a.v@mail.ru
by Gambeir; 10-06-2018 at 10:51 PM. From
"I have to watch the video's but what we have I've broken in to primary concepts and all of which may be operating at the same time in a round about way. So very broadly then;
First, we have the idea that the device is a kind of asymmetrical capacitor. Call this the Quartz balloon theory. In it the HF AC is feeding charges to the DC plates while opposing a flipping polarity in the DC plates. A possible association to this idea is that the magnets are creating a vortex to counterspace and grounding out; leading to a direct asymmetrical capacitor or a kind of electric balloon. These ideas don't really describe what is happening.
Second, we have a gravitational theory which is based around the the paper of Jerry Bayles and the thoughts of James Cox. This is the atomic vectored centrifugal force model of Bayles combined with James Cox's idea that this vectored force has to include an AC current operating inside of a non-uniform electrical field, and while being exposed to a Coriolis force. The question is why is this complexity necessary?
http://www.electrogravity.com/AVCFor...fugalForce.pdf
Notice that in the Otis Carr OXC-X1 the same vectored centrifugal force concept is employed in a macro scale electro-mechanical system. This is fundamentally the same concept as an atomic vectored centrifugal force, and while operating under a Coriolis Force which is simulated with gyroscopic precession. An electrical circuit every half cycle of rotation in the rotor system induces a flipping of the gyro system creating a vectored centrifugal force. This is all controllable through the multiple electrical contacts. Once you understand this idea then the OXC-X1 is revealed as a electro-mechanical gravitational flying saucer.
The Alexey is a gravitation system described by using a Bayles/Cox combination. That explanation describes a true atomic level gravitation system. A true gravitational system is one more complex than we probably understand at this time. It undoubtedly includes all of the above and more, and because there is a complexity in operation, not all of which is known, acknowledged, and some of which is even denied, and so the tuning of the Alexey machine is supposedly problematic and there is a need to understand what factors influence the machine that we already know about.
On one hand this makes sense. On the the other it makes no sense at all. If for example, gravity were so complex and require such tuning than how in God's green earth doth the planets and star's remain in the heaven's? So you see it isn't even logical in that sense. Logic would seem to say that there has to be a huge variable if frequency alone were the issue: Therefore this has to involve more.
More is all of the above and then some. The evidence we do have says that those rumored systems of highly advanced machines, like the Black Triangles for example, are creating a Super High Frequency and they are doing that also by operating an AC Current in a non-uniform electrical field. This non-uniform electrical field doesn't seem to be the same as the one which is being artificially created by the DC plates in the Alexey Machine. Instead the non-uniform electrical field is surrounding space itself, and for those systems to work the frequency of the AC current has to be much closer to the frequency of the non-uniform electrical field around it, which is the counterspace itself and which is billions and billions of times faster than the speed of light.
So now here is my conjecture; the ideas are similar but the Alexey is creating it's own local counterspace with the DC fields acting in conjunction with the rotating magnetic field and thereby it creates it's own local non-uniform electrical field: Effectively replacing counterspace in the immediate local space. Now if this is correct then there is a correlation between the DC and AC which has to be working together to create the same effects as the OTC-X1 (vectored centrifugal force) but since this is an electrical system there is a specific band length or region where the two electrical fields will work together to create this flipping in the gyroscopic spins of at an atomic level and at the right time, like say every half cycle at the atomic spin level: Understand? This flipping action takes place in the AC field. That's the field which is moving back and forth through a magnetic DC flow: The magnetic DC is the Coriolis force which induces this flip that creates the vectored centrifugal force at the atomic level: Understand? That's why the frequency of the AC has to match the DC created counterspace. So the magnets spin and the DC together determine what the AC cycle has to be for this vectored centrifugal reaction to take place. So the DC Magnetic Field is a Coriolis force field. This tells us then that counterspace is akin to this same energy field, only that field is moving at vastly higher speeds, so fast that the effects are instantaneous. This explains the near vanishing act of the Black Triangle I observed since the closer that machines frequency is to the surrounding space the greater capability it's speeds are. Now is that making sense to everyone now? Notice that your own surrounding space is a non-uniform electrical field.
Lastly, if a local gravitational effect is the product of the Alexey machine, and I believe this is the case, then it is most probable that the machine would benefit from more mass and not less. This is precisely in line with what Mark McCandlish has said about the ARV, that the bigger and heavier they are the faster they can go, and this makes a great deal of sense if you have a mass creating it's own gravity field. I think more mass in the AC plate might be needed and might alone explain the evident difficulties.
PS: So frequency between the electrical systems and the materials in use are all significant because the Alexey, like the Nazi Flying Saucers which went before, artificially create a local counter space to operate in: The prosecution now rests its' case.
The Nazi Saucers, the ARV, and the Alexey are all similar. The Black Triangles work off the understanding of how the previous generations operated, but are an entirely new and more advanced machine, and which do not alter the surrounding space as the predecessors do, but rather interact directly with the same space/counterspace that you and I do and this is a huge difference. The surrounding space contains counter space which is an incoherent energy field that I've mistakenly called the dielectric field. Ufopolitics has tried to enlighten me but this has proved difficult.
Nevertheless there it is; counter space sitting right next to you, and that space is what James Cox called a non-uniform electrical field. Cox is talking about counter space and he also included the all important idea that this non-uniform field is moving, that it is influencing the AC field with a rotating magnetic field which he then called a Coriolis force. It's quite clear that James Cox is completely aware of how atomic vectored centrifugal force creates gravity and that's why he said what he did. Now hopefully this is somewhat clear enough to grasp how you then get back Otis Carr and the OCX-X1 because that's where all this spinning, twisting, and electrical shocks come home to roost in a more visible and physical form that end up creating a vectored centrifugal force that Jerry Bayles wrote about. So all this spinning, twisting, gyrating, is what is taking place at the atomic level resulting in the stuff we have naively called gravity. Well it is gravity except it's just that we have all been lead to believe dirt is born with it.
The Alexey machine has a rotating magnetic plate that's conducting an electrically charged magnetic circuit in a DC field through an AC field, and because it is AC that field is moving back and forth, and the DC field is also rotating as it moves being carried along by the magnetic plates spin. Again observe the Otis Carr OTC-X1 to gain some basic ideas about what takes place at an atomic level. Clearly Carr understood this idea. Also notice that the ARV has sectioned plates set in layers. It's working essentially the same way as the Alexey but with an entirely electromagnetic plate rotation process conducted through a pie plate pattern that's fired off sequentially; one after another as it were.
These machines are creating a sort of bubble to operate inside of, and which does change the relative relationship of energy, and because (as explained by John St. Clair) the effect of these interactions results in change in the relative speed of light inside that self created bubble. The result of which happens to be blurry images in photographs for one thing. Levitation and FTL Super Luminal travel being another. I want to point out here that it's important to not run ruff shod over this. Burred images in photographs prove what? That the immediate surrounding speed of light isn't the same as it is for everything else around in the same photograph. This is evidence strongly supportive of the idea that the speed of light has been manipulated by this process.
Now it actually makes sense if the upper and lower DC plates are moving together but maybe the upper plate doesn't even have to rotate. Maybe it could just be a floor like the crew compartment in the ARV since the magnetic field is actually creating a magnetic field across the space between the two plates, and maybe that field simply follows along without any assist same as attaching a block of steel or iron to any other magnet. It just assumes the magnetic. The ARV's crew compartment isn't providing the upper plate because it isn't necessary. More likely the base of the machine itself would serve that purpose or it has a triple plate system with the DC plates covering an AC between them.
As Bayles states, the magnetic field also moves/projects very slowly, and then W. J. Hooper says they can detect an unknown slowly moving field with his device.
http://www.rexresearch.com/hooper/NewHorizons.pdf
John St. Clair say's in his patents that his creations are altering the speed of light in a local environment. Obviously he has to explain this in Einsteinian terminology or the patents would never have been granted. Alexey's machine is creating a change in the local environment by changing the velocity of counter space which acts on all of us, and which we think is gravity, and it does that by making a kind of electromagnetic bubble about itself where the speed of this counter space is now controllable. It is a gravitational machine but it's an artificial gravity machine and as soon as the artificial space it's created collapses the machine drops back to earth. Nevertheless, that collapse isn't immediate, which seems mysterious but that's why this machine sits there without power until the field it's created collapses.
I'd suggest start by looking over at this machine designed by Otis Carr.
Schematics & Information on the OTC-X1 | Clandestine Disclosure
The reason you want to look at this is to see what takes place at the atomic level. This way you have an idea what creates a vectored centrifugal force at the atomic level. You don't have go deep. You just need to see the machine as a macro scale atom with it's field of spinning electrons, because that's the model I'm sure Otis used and which makes complete sense.
The key to understanding the machine is that the so-called Ultrons (gyro's) are made to abruptly alter their spin which produces a centrifugal force. How they do that, all the other complexities of what's involved in making it happen, how to direct the energy and so forth are all helpful. I've not studied it in detail myself either having not previously comprehended what made it tick, and so like many others it looked like some contraption which I've seen contrived by others, but I did know some of the history behind the machine and I have listened to Ralph Ring so I know this machine has some very solid work behind it.
Now the Otis Carr OCX-X1 is basically an analog centrifugal force inertial drive system which is modeled on atomic spin state gravitational theory. It is an all mechanical system for the most part. It is designed to act in the local environment just like an airplane, or car, or the space shuttle and it is designed to mimic the same sort of propulsion force as described by Jerry Bayles paper on vectored atomic centrifugal force.
The Alexey is a combination analog and solid state gravitation machine. It's different because (I think) it is altering an area of space around the machine and this is unlike the OCX-X1. It is still using the same general idea described by Jerry Bayles to produce a motive force or gravity field, but how it does this is not direct as it is with the Otis Carr OCX-X1.
The Alexey is making/creating an artificial environment for itself in the same air space we are in, but which is significantly different. It is, in effect, creating an area of altered space time which then significantly changes what the machine is capable of doing and may be doing: At least according to Einsteinian Physics.
I'm saying this partly because of the known effects of so called UFO's, which include lost time, slowed time, teleportation and others as predicted by alterations in space time, but space is not what Einstein thought. Rather space is what Tesla thought, but it is still a space which can be monkeyed with, and essentially this is what I think the Alexey machine does do. I think this for a number of reasons. I'm not positive of it but I suspect it is creating an kind of artificial space around itself.
To understand Tesla's idea of what space really is you should read Stevens on the Aether Theory. Only a page or so.
http://free-energy-info.co.uk/Stevens.pdf
The reason you need to read Steven's explanation is so that you can then understand that the Alexey probably cannot create a frequency high enough to interact directly with space time, or our own natural space, and so it creates an artificial space of it's own, or a bubble if you will that allows it operate as a kind of proxy to a higher frequency gravity inducing energy field. This bubble of altered reality is most probably the cause of the associated anomalies encountered around UFO's.
We can be pretty sure this is likely as machines such as the Black Triangles are using a fully digital sort of gravity creation process that creates a super high frequency which allows for a direct connection to the same energy field which creates gravity as we know it.
First, the video which shows Alexander Ivanovich's levitation demonstration is naturally interesting; more information on this so called geopathogenic miner/harmonizer is needed. Alexey obviously thinks there is reason to believe levitation is possible. If so, it is likely to be associated with an ingested substance, it is likely to be associated with aging, and it is likely to exist on both accounts. https://i2.wp.com/aetherforce.com/wp...herforce_1.png
Second, spacecase0 brings up the valid important understanding for recognizing fundamental differences between the quote: "2 things we see as voltage, one is electrostatic, and the other is induced by a moving magnetic field."
Thirdly, aljhoa correctly directs our attention to super-fluidity and the statement by TheoriaApophasis (Ken Wheeler). Which like all of Ken's stuff is filled with humor.
Quantum science seems to be a misunderstanding of the energy field which Ken is talking about. Our own Star is standing in a pond flapping its arms. Light and energies associated by that flapping are the result of perturbations to the energy field our Star is standing in and nothing more.
This substance, which has been called the Aether and counterspace, is a Super Luminal energy field which is billions and billions of times faster than light, it exhibits a Super-fluid capability and penetrates all matter without resistance for the greater part. For the most part, only the matter it passes through does itself react to the passing of this energy field, and only those parts of matter which react to the field create a perturbation in that energy field. Light is a product of this energy field passing through the Star. Gravity is a product of this energy passing through matter.
Quantum science is a misunderstanding of this energy field. Particles don't exist, they don't pop in to and out of existence, rather what has been mistaken for particles are snapshots, glimpses of this energy field passing at the fantastical speeds it does through our own matter, and we are evidently gathering this idea that "stuff" is created by our thoughts out of a quantum field of energies and so if we can figure it out we can think in to existence anything, but there are no particles popping in and out of reality as some think there are. There is only this other realm which is creating the reactive forces that give life, gravity, and light to humanity. This all reminds me of Einstein's ideas which have now so screwed natural logic that the most absurd ideas are thought possible or even real.
It's no wonder Telsa called him an idiot. Let me give an example. Suppose you wanted or needed to get from say Seattle to Tokyo in 5 minutes or less. Now which would do; would you go about trying to create a worm hole or would you instead build a machine that could do the job? My guess is you'd do the most practical, which is to build the machine to do the job, and this illustrates how sickeningly mind controlled we all are. I know, I'm not any different from anyone else in this area.
Now what do we have for evidence which supports the two? We have evidence for machines is what we have. Not worm holes but machines which can now cross the galaxy. Space is nothingness as Tesla said it was. Nothingness doesn't cause the Star to glow. Energy passing though nothingness interacting with matter does. I repeat; this energy is moving at fantastical speeds: It seems to be a fluid because of this, it seems to be a solid because of this, it's been mistaken for both. Isn't it a wonder why a Tetrahedron shaped Star Destoryer is featured in Star Wars going and coming out of hyper-space? What is hyper space then if not counter space? Don't ya see now that jumping to hyperspace means jumping on to the counter spacial energy field. This is where the technology behind the Black Triangles is designed lead and to latch on to, it's designed to create Super High Frequencies, and to then broadcast that frequency to the matter which makes up the Star Ship and so that the entire outer hull does itself vibrate in the same frequency band of counter space. Now there's no way we are remotely close to what is possible even with these ships, but compared to my 1941 dodge pick up it's a big step up and outwards.
If space is nothingness then counter space is everything which makes nothingness react as if it was not dead matter which includes us.
This would seem to suggest that seemingly wacky ideas like flying levitating humans are not beyond the realm of sane thinking. "
F6FLT
Chekurkov's experiments are obviously interesting. But as written in several comments about the video at https://www.youtube.com/watch?v=VBrx4O10XkI , there is suspicion of fraud. So before any theoretical investigation, a good practice is to verify the facts. Unfortunately I don't find schematics to duplicate his experiments. Did someone find them and can point a link?
The article "Atomic Centrifugal Force by Vectored and Synchronized Electromagnetic and Acoustic Waves" by Jerry E. Bayles is based on a misinterpretation of a field. A field is only a set of values associated with points in space. Replacing actions at a distance from a source with local properties in particular locations simplifies calculations. Except EM waves, a "moving" field is only a view of the mind without reality: nothing really moves, there are only changes in the field strength that make it appear as a movement. For example, field values decrease in one place and increase in another, giving us the impression that the field is "moving". It is the same as a "moving" light spot projected on a wall. There are only photons whose arrival point is changed along the wall but the photon comes from the projector, they do not move along the wall, nothing moves along the wall.
To know that avoids serious errors of reasoning, such as the idea that energy from a field would move with it. It is only removed from one place and put to another one from the source. Of course, I am talking about a non-radiating field, such as the field of a permanent magnet or the field of a coil at low-frequency so that the radiated field is negligible (EM waves are in contrary real autonomous field carrying energy).
ramset
Thanks Grandma
Acca
I am building this model as if it is possible,  the effect was banned in research after 1952, no money was given by the national science foundation for research.  Sorry no money for this.. Seems that there is an effort to prevent this effect to be accepted by science, and only as fake impossible technology... This is not a real effect?  yhea....like the Seral magnetic spin..
Acca
penno64
