A Treatise on the Magnetic Vector Potential and the Marinov Generator
Started by broli, November 13, 2018, 05:30:17 PM
ayeaye
Ok, i try to explain these things only by movement of charged particles. This looks like a different effect than induction. At first it looks like that it shouldn't do anything, just move electrons along the side (call it sidewise) of the rotating cylinder, parallel to its axis. But there is one more thing to consider, the electrons in the cylinder move pass the atom in the magnet. This means that they are not just moved sidewise, but just tilted to the side, when still moving forward. What that causes is that after passing the atom, the electrons in the cylinder will be longer affected by the repulsive force of the electron in the atom, than before passing the atom. That should mean that the summary force to the electron in the cylinder supposed to be in one direction. As this is a different effect than the induction, then there also should be no Lenz effect back. I don't know more about forces that there may be. You indeed found a puzzle where is the most difficult to see what happens.
I don't know what happens when the electrons are pushed to the edge of the cylinder. Maybe make this rotating thing a sphere instead of a cylinder, then maybe this tilting might be continuous. The electrons supposed to go then, through that sphere, somewhat like in a vortex.
Quote from: ayeaye on November 24, 2018, 11:40:39 AM
It's about the change the charge particle sees in the A-field due to its own movement. Faraday's law of induction assumes that the charge particle is stationary while the A field is changing whereas the complete equation also considers the change of the A field due to the movement of the charged particle. We know this happens because when we move a coil to or from a magnet an EMF is induced. However this change in A-field can happen in all directions including longitudinal to the charge particle's movement  as you have in the previously shown setup.
I'm currently extending my simulation software to show the induced E field due to the rotation of charged particles around these type of magnets.
ayeaye
I think it's just said in the other words what i said. Because i believe that this is all only about movement of charged particles, in the atom and in the wire, cylinder or whatever. I think that there is really no magnetic field or any other special field, these are only emergent dynamic phenomena of the movement of charged particles and forces between them. Yes one thing coincides as you explain it or as i see it. It is indeed because of the movement of charged particles in the cylinder, without it there were no such effect. But i don't want to think only in the terms of magnetic fields, or other fields, without understanding what really happens. Like magnetic field, likely some time someone decided, we don't really understand what happens there, so let's call it magnetic field.
What i still cannot understand, it supposed to create opposite currents in both halves of the cylinder if the thing is completely symmetric, or not? How then can there be one current not zero, i still cannot quite comprehend it.
And then one heretic question, what if we don't rotate the cylinder, but let just a small current through it, might it then amplify the current? I don't know because i don't know everything that happens there, but as much i see it so far, i yet don't see why that cannot happen. Movement of charged particles, does it matter whether it's caused by rotation or by current? I'm sorry, that may well be naive, it is just as much as i can think by the limited way i see it so far.
There may be a caveat though, charged particles. In that there need to be many charged particles. In the wire there may not be many. Like i have this coil, a few turns, and a hard drive magnet on it, the one they say in Youtube to be overunity device. This is somewhat similar to Marinov, the magnet is oriented the same way at least. There is no voltage on it, there is 1 mV on me. But if there is a circuit, me, that coil, and the voltage meter, it measures 74 mV on me and the coil in series, and this is constant. Where does it come from, why does that coil with magnet increase voltage so much? I guess one possibility is, i am a great source of electrons, and when there are many electrons in the circuit, such things might generate current. So to warn you, don't expect much, unless you maybe include in the circuit something, that contains a lot of electrons.
Well boys and girls. Perhaps for the first time in history here is the calculated induced E field caused by a rotating velocity field around a split face magnet. I must say that I have stared at this for hours and still can't get enough of it. More exploration to come but I bet this will keep the mind occupied for the meantime.
Notice the lorentz force in such uniform loop is 0 everywhere :) .
Also might add that this explains and shows eddy currents quite nicely.
