What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
Temporal Visitor
Quote from: memoryman on January 17, 2019, 10:26:39 AM
Mike, you seem to 'feel' attacked a lot. Happy with that?
Of course magnetism is a field that exhibits a force. So is gravity. And?
"And?" : as previously written; the rest escapes you.
"Have fun playing with it" yourself.
skywatcher
Now i have finished my build.
The external magnet can not be seen on the picture because before making a magnet holder i first wanted to test it with a hand-held magnet, to see where the optimal position for the external magnet is. But the tests were completely disappointing and worse than i had expected. I tested it with several magnets: one bar magnet (the same as in the ones in the rotor), two bar magnets, and one or two very strong cube magnets.
I was not able to get any rotation whatsoever. In the best cases it rotated some 30 degrees and then it stopped.
It's not even 'almost working', it's not working at all.
1 Rotation is for the rotor the maximal freedoms degree limited by the shaft fixation.
You fixed the magnets  ! And their magnetic force field near/ far effect!
1 Rotor( or Stator) dividing this 360° circle in chamber,  where the - each magnet/ its- chamber can  moves with or against the outer Ring !?
At first 4d modelling !
But your work : really fine, too clean !
IN GERMAN , military advice : " Stillgestanden !"  Later : " Ruehren !"
wmbr
OCWL
p.s.: "flywheels" as energy storage and recuperation devices( older : also trolley busses) : principle, function
          drawbacks
         f.e.: AEG " Magnet Motor"- development, included in a MAN-Citybus :
         before 200 KW only Diesel-engine
        after       20 KW Diesel-engine + Magnet-Flywheel
ARTMOSART
Quote from: skywatcher on January 20, 2019, 07:11:02 AM
Hi skywatcher,
nice bwuild and thank for doing the experiment ,if you can, i suggest to you to reduce the number of magnet to half or les ,just an idea?
