A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
George1
Hey lancaIV,
Thank you for your reply.
Welcome to our team of inventors-enthusiasts!
Your last post is very, very interesting! Please give us some time to consider it carefully! (Part of your last post's information was as if considered in some previous posts on this topic but I am not sure. I'll check this.)
I will write to you in the nearest future.
Regards,
George
George1
Hey again lancaIV,
And what about the link below?
https://overunity.com/16302/hho-as-real-uo-system/msg469903/#msg469903
Seems to be interesting and workable?
(Title "HHO as a real UO system", author John.K1, December 31, 2015. I wrote to this man many times, but he did not answer me.)
What do you think? What is your opinion about his suggestion?
Looking forward to your answer.
Regards,
George
George1,
without to be or wishing to become member of your team :
the John.K1 idea is for me to " huge designed", probably usefull in mountains zones, beginning with 2000 and more meters the basic station and several hundreds or thousands meters higher by tubes the conversion station.
In small :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19760115&CC=DE&NR=2429086A1&KC=A1#
George1
Hi lancaIV,
Yes, an obvious disadvantage of John.K1's idea is that it is a "huge designed". Let us concentrate again then on the "small designed". We started considering already your penultimate post. Very interesting! I will write to you in the nearest future.
Regards,
George
What is invention ?
Invention is design of improvement and new technical standart or utility.
Free design :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2013011125A1&KC=A1&FT=D&ND=3&date=20130110&DB=EPODOC&locale=en_EP#
[0010] water heat function
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5130608A&KC=A&FT=D&ND=3&date=19920714&DB=EPODOC&locale=en_EP#
Ohms law is guilty ,4 Watt from 100 Watt guilty , pulse duration= law duration : fractional second !
J/s to J/ fractional second= J/pulse duration or J/signal
