A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
George1
To lancaIV.
Hi lancaIV,
Welcome to our team! :)
1) Thanks a lot for your last post. It contains extremely valuable information and straight-to-the-focus-directing questions and thoughts.
Please give me some time to consider your last post carefully. (By the way as if you have the ability and the gift to be an industrial manager. :))
2) We modified slightly the text of our previous post. Please look at item 6 of our next post. Some recommendations/instructions?
Looking forward to your answer.
Regards,
George1
LET US PUSH FORWARD TOGETHER THE TECHNOLOGY PROGRESS!
1) We (our team) have created 11 (eleven) technology breakthroughs.
2) Two of the above mentioned 11 technology breakthroughs (entitled "IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?" and "A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1", respectively) are released freely here in this forum.
3) Our third technology breakthrough is an entirely new and revolutionary electric technology, which increases many times (twice as a minimum and more than 15 (fifteen) times as a maximum) the capacity of any standard electric battery.
4) Our third technology breakthrough is experimentally proved. Our third technology breakthrough has a working prototype
(accompanied by a detailed description of its principle of operation).
5) Our third technology breakthrough is not patented. Instead we would like to sell our third technology breakthrough as a trade secret and/or to enter a suitable kind of collaboration of mutual benefit for production of our third technology breakthrough on a large industrial scale.
6) Besides we would like to enter a suitable kind of collaboration of mutual benefit for a practical realization and for an industrial production on a large industrial scale of our first two pieces of theoretical research, (a) which are entitled "IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?" and "A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1" and (b) which are released freely here in this forum.
7) Contact email address: randdgroup34@gmail.com.
George1
The text below is a slightly modified, shortened and more precise version of our post of March 09, 2021, 02:46:35 PM.
Have a look again at the book "Solved Problems in Physics", 2004, Volume 2, p. 876, solved problem 12.97. The author of this book is Prof. S. L. Srivastava (Ph.D.)
The same book can be found at the link https://books.google.bg/books?id=rrKFzLB9KQ8C&pg=PA876&lpg=PA876&dq=%22electrochemical+equivalent+of+hydrogen%22&source=bl&ots=tQ8PSMLet3&sig=ACfU3U2HOLB78XHl2o3q-JanapzSK-McJA&hl=bg&sa=X&ved=2ahUKEwjDpp2-zZXhAhWT5OAKHUfuBzUQ6AEwBHoECAkQAQ#v=onepage&q=%22electrochemical%20equivalent%20of%20hydrogen%22&f=false
For your convenience I am giving below the text of the problem and its solution.
12.97. In the electrolysis of sulphuric acid solution, 100 mg of hydrogen is liberated in a period of 20 minutes. The resistance of the electrolyte is 0.5 Ohm. Calculate the power consumed. Electrochemical equivalent of hydrogen is 1.044 x 10 -8 kg/C.
SOLUTION.
Prof. S. L. Srivastava's solution is given below.
Prof. S. L. Srivastava's solution consists of two lines only.
LINE 1. Current through the electrolyte is given by I = (m)/(Z x t).
LINE 2. Power consumed = (I) x (I) x (R) =  ((m)/(Z x t)) x ((m)/(Z x t)) x (R) = 31.86 W.
Prof. S. L. Srivastava stops here his calculations.
(The related solution's set of equations is not given here in order to save time and space. This set of equations however can be found in the book or in the link above.)
WE DEVELOPED FURTHER PROF. SRIVASTAVA'S SOLVED PROBLEM IN A NON-STANDARD MANNER.
OUR FURTHER DEVELOPMENT OF PROF. SRIVASTAVA'S SOLVED PROBLEM LED TO COP > 1.
HERE IS THE ESSENCE OF OUR APPROACH.
1) Let us calculate the inlet energy, that is, inlet energy = (31.86 W) x (1200 s) = 38232 Ws = 38232 J.
2) The Joule's heat, generated in the process of electrolysis is given by
Q = (I) x (I) x (R) x (t) =  ((m)/(Z x t)) x ((m)/(Z x t)) x (R) x (t) = (31.86 W) x (1200 s) = 38232 Ws = 38232 J = outlet energy 1.
3) HHV of hydrogen is 142 000 000 J/kg. Therefore the heat H, generated by burning/exploding of 0.0001 kg of hydrogen, is given by
H = (HHV) x (m) = (142 000 000) x (0.0001) = 14200 J = outlet energy 2,
where
m = mass of the released hydrogen
HHV = higher heating value oh hydrogen
4) Therefore we can write down the equalities:
4A) outlet energy 1 + outlet energy 2 = 38232 J + 14200 J = 52432 J
4B) inlet energy = 38232 J.
5) Therefore COP is given by
COP = 52432 J/38232 J = 1.37 <=> COP = 1.37 <=> COP > 1.
IMPORTANT NOTE. Constant pure water and cooling agent supply could keep constant the electrolyte's temperature, heat exchange, mass and ohmic resistance, respectively. Besides 0.0001 kg of hydrogen (and the related amount of the already split pure water) is small enough and can be neglected as a factor influencing the electrolyte's temperature, mass and ohmic resisitance.
And one more interesting fact.
Literally the same solved problem can be found in an old Russian (still from the Soviet times) book "Сборник задач и вопросов по физике", 1986, p. 130, solved example problem 71. The authors of this book are Р. А. Гладкова and Н. И. Кутиловская. In the Russian version the data is a little different, that is, time is 25 minutes, the amount of generated hydrogen is 150 mg, Ohmic resisitance is 0.4 Ohm and the calculated power is 37 W.
Russians also stopped their calculations at 37 W.
Our further development of the Russian version led to the same COP = 1.37, that is, we have again the same COP > 1.
Acca
kk So "you" want 20 times overunity HHO.. here it is....
Here is a new (4 years ago still active) company from New Zeland with locked down HHO tech,
they claim 20 overunity...I think these guys are just greedy bastards... get this,  thay want to
partner up with a "major organisation with the financial strength"... what wankers...
Acca ...
https://www.h2innovativelab.com/
[/font]
[/font]
Due to the nature of this highly disruptive technology the full identity of the parent company is
discreetly concealed from the public. However patent numbers are provided to approved
applications.
Galvanic Enhanced Electrolysis energy generation provides clean, safe, self-
sustaining electricity unlimited to geographic location.
A sustainable hydrogen based energy bridging the gap for hydrogen to become the ultimate fuel
of the future.
Our objective is to assign the patents and concealed intellectual property to a major
organisation with the financial strength.
H2IL discovered a method of combining energy at an ionic level, enabling the release of bound
hydrogen by harvesting a natural galvanic energy stored in abundant and low cost metals. The
energy content of the hydrogen is many time greater than the input catalyst electricity. This has
proven to enable self-sustaining energy generation with very little metal consumption.
The H2IL generation method also uses an energy stored in certain metals but abundant in supply.
A small amount of self generated electricity will excite and sustain a hydrogen generating
reaction.  Energy is not being created, which is impossible, but simply transferred from one form
to another and supporting the laws of thermodynamics.
Conventional electrolysis of water with a 60% efficiency is not new. However, Galvanic Enhanced
Electrolysis is breaking through the efficiency barrier, enabling self-powering energy generation
and paving the way for the clean fuel of the future.
H2IL Galvanic Enhanced Electrolysis technology is fully developed over a 14 year period with
confidential I/P supporting the secured intellectual property for a robust technology acquisition.
Who Are We:
'H2 Innovation Lab' is a subsidiary branch of a manufacture and exporting company based in
Auckland New Zealand. Since 1996 the parent company had successfully patented and exported
specialized electronic analytical equipment into 71 major countries. Receiving product and
leadership awards, hosting international seminars and popular presence at trade shows
throughout the world. Since 1980 this innovative research and development company have
been dedicated to providing solutions to many technical challenges.
It is not the C.O.P. number which imports !
Yes,it is the hydrogen production price and gram(m) per minute/second process time and hydrogen purity !
What happens here ,water (mainly hydrogen + oxygen ) + tab substance
https://www.youtube.com/watch?v=Y4X2h6YTv80
next factor : temperature
https://www.youtube.com/watch?v=tgbrP8q9lYA
next factor : active area
https://www.youtube.com/watch?v=BWN8xVuzuFI
active material in use :
water + palladium/platin/silver or chem-alloy ?
grain = active surface per gram,powder = active surface per gram ,nano-powder = active surface per gram
water in movement / electrolyt in movement     ( s/whirl,centrifuge)
