A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
Please send to me, if possible, any other similar links containing companies/institutions, involved in hydrogen-generating activities :
https://www.google.com/search?q=hydrogen+symposium&rlz=1C1AVFC_enPT930PT930&oq=hydrogen+symposium&aqs=chrome..69i57j0i22i30l9.7825j0j4&sourceid=chrome&ie=UTF-8
all Universities global
all car manufacturer
Air Liquide,Linde ( Linde is a global leader in the production, processing, storage and distribution of hydrogen. )
https://link.springer.com/article/10.1007/s11090-016-9766-6
but related hydrogen-rich Syngas ,not pure hydrogen
type of electrolysis comparison.KWh/Kg input :
https://link.springer.com/article/10.1007/s11090-016-9766-6/tables/1
LENR or " cold fusion" paper :
https://www.researchgate.net/publication/237276063_COLD_FUSION_BY_PLASMA_ELECTROLYSIS_OF_WATER
http://panacea-bocaf.org/kanarevelectrolysis.htm
His tests show at least 10 times the capacity but his data also suggests 4,000 times more hydrogen than the Wh input would predict. He also has measured very significant hydrogen generation when his cell is not powered.
from an inventor in the Lebannon :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2004156779A1&KC=A1&FT=D&ND=3&date=20040812&DB=EPODOC&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021121&CC=US&NR=2002170292A1&KC=A1
ramset
Thanks Grandma
kolbacict
What is the chicken skeleton formed from?
The protein and yolk obviously do not contain so much calcium. ;)
George1 :
https://patents.google.com/patent/US4747925A/en
C.O.P average 3 for electric input and hydrogen energetic value
by cited/citing documents you will see different applicators and institutions
https://patents.google.com/patent/US4014777A/en  "Brown gas" or oxy-hydrogen inventor/promotor
A good argument 1973 :  The generation of cheap gas, up to 6 to 7 times cheaper than normal gas supplies.
this inventor (now R.I.P.) worked also with Kanarev
https://patents.google.com/patent/US20070065765A1/en
https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2006108198&tab=PCTBIBLIO
https://patents.google.com/patent/US20190186022A1/en
priority: 2011  publication : 2019  8)
[0082]
During this example, water was hydrolyzed into hydrogen and oxygen gas (HHO) at a measured rate of 17.9 grams of water consumer per minute. Given that a mole of water has a mass of 18.0 grams, it follows that 0.994 moles of water were generated per minute. Since an ideal gas has a volume of 22.4 liters per mole, it also follows that the reactor generated 0.994×22.4=22.26 liters per minute or 1335.6 liters per hour of HHO. If a mole of hydrogen is 1.0794 grams, and if 1335.6×2/3/22.4=moles per hour of hydrogen are generated, this equates to 39.75 grams per hour of generated hydrogen. Recalling that the reactor and vacuum pump consume 0.5555 kilowatts (Kw) to generate 0.03975 kilograms (Kgs) in one hour, it follows that the reactor requires about 13.97 KwH to generate one kilogram of hydrogen. At a typical off-peak rate of about $0.17 per KwH for external power, the reactor can generate hydrogen for about $2.37 per kilogram, which has been found to be competitive.
13,97 KWh electric power input for 33,3 KWh hydrogen energetic value = C.O.P. ?
13,97 KWh electricity x 0,17 USD = 2,37 USD
They only calculated the electricity costs per Kg hydrogen,not the total investment costs per Kg !
near future :
water to hydrogen as heat source to high efficient heatelectric converter :
https://judbarovski.livejournal.com/173410.html?utm_source=3userpost
C.O.P. 3 electrolysis x 0,8 ( for 80% conversion efficiency) = total 2,4 water to electricity system C.O.P.
conventional ic-engines actually    C.O.P. 0,15    in average
But : innovative,standarts changing, ideas are not ever successfull,an example  :   https://www.axionpower.com/the-battery/
https://www.greentechmedia.com/articles/read/energy-storage-setback-as-two-firms-fail
" ...... Axion invested about $50 million in adopting it for use in batteries  .... "
The company was a veteran of the energy storage industry, having been founded in 2003. As reported in GTM back in 2009,  Axion aimed to give lithium-ion a run for its money with an advanced lead-acid battery equipped with carbon electrodes.
The electrode technology, from a Russian company that had been developing it for superconductors, was supposed to give the battery a lifespan three to four times longer than batteries using traditional lead negative electrodes.
" Needing a long breath" and good, contract warranted,partners !
ramset
And how does browns gas melt exotic metals?
5000C ?? Or....titanium and other?
What is the hottest temp hydrogen gas can reach as " heat flame" ?
Under enuff heat all is consumed ... safely ( for atmosphere??
Could solution for plastic problem be remediated ? Heat to power plant ?
Would make plastic garbage into gold for needy areas ... if truly made environmentally friendly by extreme hydrogen temps?
Temperatures?
Cogen?
Clean up the plastic mess with SUPER high heat ( all toxic consumed??
And generate power?
Thanks Grandma
