A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
George1
Hi Gyula,
Thanks a lot for your reply.
1) Yes, I perfectly agree with you. Yes, we tried to shortcut the path to the target, but you are right that this is not the correct approach. We will do these experiments trying to be in a constant touch with you for consultations and recommendations.
2) We have to see if it is possible to find somewhere here such a PEM electrolyzer and consider it carefully.
I will write to you in the nearest future.
Regrds,
George
P. S. By the way do you have some friend/colleague who is an expert in the field of computer simulation of real mechanical systems? I will be extremely grateful to you if you find for me such an expert. Looking forward to your answer.
George1
Hi again Gyua.
Only a small addition to the P. S. of my last post. The expert must be able to do things similar to the ones that are shown in the links below:
https://www.myphysicslab.com/springs/collide-spring-en.html
https://www.myphysicslab.com/springs/dangle-stick-en.html
https://www.myphysicslab.com/springs/collide-blocks-en.html
Please help, if possible.
Regards,
George
George1
Hi Gyula.
Two members of our team seriously undertake to perform the water-splitting experiments. It will take some time however.
While waiting for the experimental results let us recapitulate again all theoretical (ONLY THEORETICAL!) considerations until now.
1) A standard DC voltage source of voltage V is connected to a standard solid resistor of ohmic resistance R. We can write down the following equalities:
V = I x R  (1)  <=>  V x I x t = I x I x R x t  (2)
where
V is the voltage of the DC source;
I is the current flowing through the resistor;
R is the ohmic resistance of the resistor;
t is time.
Simple and clear.
2) The situation changes a little however if we replace the solid resistor of ohmic resistance R with a liquid resistor (electrolyte) of the same ohmic resistance R. In this case we have to adapt a little equalities (1) and (2). We can write down the following equalities and inequalities:
V - v = (I - i) x R  (3)  <=>  (V - v) x (I - i) x t = (I - i) x (I - i) x R x t  (4)  <=>  (V - v) x (I - i) x t < ((I - i) x (I - i) x R x t) + (Z x (I -i) x t x (LHV))  (5) <=>
<=>  V -v < ((I -i) x R) + (Z x (LHV))  (6)  <=>  0 < Z x (LHV)  (7)  <=>  0 < 1.2  (8)
where
v is the "counter-voltage" due to electrode potential/overvoltage; (V - v) is practically equal to V because v is much smaller than V and can be neglected;
i is the current decrease due to v; (I - i) is practically equal to I because i is much smaller than I and can be neglected;
Z is the electrochemical equivalent of hydrogen; Z = 0.00000001 C/kg;
LHV is the lower heating value of hydrogen; LHV = 1.2 x 100000000 J/kg.
The "magic":) inequality (8) unambiguously shows COP > 1. Do you have any theoretical (ONLY THEORETICAL!) objections against inequality (8)?
Regards,
George
George1
Hi Gyula.
where
t is time.
Simple and clear.
where
The "magic" inequality (8) unambiguously shows COP > 1. Do you have any theoretical (ONLY THEORETICAL!) objections against inequality (8)?
Regards,
George
George1
Hi Gyula.
where
t is time.
Simple and clear.
where
The "magic" inequality 0 < 1.2 (8) unambiguously shows COP > 1. Do you have any theoretical (ONLY THEORETICAL!) objections against inequality 0 < 1.2 (8)?
Regards,
George
